[PATCH 06/23] bsps/lm32/shared: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Mon Jul 11 22:36:22 UTC 2022
Updates #3053.
bsps/lm32/shared/btimer/btimer.c | 25 ++++++++++++++++++++++---
bsps/lm32/shared/clock/ckinit.c | 25 ++++++++++++++++++++++---
bsps/lm32/shared/clock/clock.h | 25 ++++++++++++++++++++++---
bsps/lm32/shared/console/console.c | 25 ++++++++++++++++++++++---
bsps/lm32/shared/console/uart.c | 25 ++++++++++++++++++++++---
bsps/lm32/shared/console/uart.h | 25 ++++++++++++++++++++++---
bsps/lm32/shared/start/bspreset.c | 25 ++++++++++++++++++++++---
bsps/lm32/shared/start/bspstart.c | 25 ++++++++++++++++++++++---
8 files changed, 176 insertions(+), 24 deletions(-)
diff --git a/bsps/lm32/shared/btimer/btimer.c b/bsps/lm32/shared/btimer/btimer.c
index e1980a7077..86bd8dbd1e 100644
--- a/bsps/lm32/shared/btimer/btimer.c
+++ b/bsps/lm32/shared/btimer/btimer.c
@@ -1,3 +1,5 @@
/* timer.c
* This file manages the benchmark timer used by the RTEMS Timing
@@ -12,9 +14,26 @@
* COPYRIGHT (c) 1989-1999.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
* Jukka Pietarinen <jukka.pietarinen at mrf.fi>, 2008,
* Micro-Research Finland Oy
diff --git a/bsps/lm32/shared/clock/ckinit.c b/bsps/lm32/shared/clock/ckinit.c
index 4c64d4770f..f4bd395eb6 100644
--- a/bsps/lm32/shared/clock/ckinit.c
+++ b/bsps/lm32/shared/clock/ckinit.c
@@ -1,3 +1,5 @@
* Clock device driver for Lattice Mico32 (lm32).
@@ -6,9 +8,26 @@
* COPYRIGHT (c) 1989-2009.
+ * are met:
diff --git a/bsps/lm32/shared/clock/clock.h b/bsps/lm32/shared/clock/clock.h
index fa61e1d58e..989c8deb21 100644
--- a/bsps/lm32/shared/clock/clock.h
+++ b/bsps/lm32/shared/clock/clock.h
@@ -1,3 +1,5 @@
* @file
* @ingroup lm32_clock
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/bsps/lm32/shared/console/console.c b/bsps/lm32/shared/console/console.c
index d49ca346b6..7747d42033 100644
--- a/bsps/lm32/shared/console/console.c
+++ b/bsps/lm32/shared/console/console.c
@@ -1,3 +1,5 @@
* Console driver for Lattice Mico32 (lm32).
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/bsps/lm32/shared/console/uart.c b/bsps/lm32/shared/console/uart.c
index 9adbd4063d..ef01a27e34 100644
--- a/bsps/lm32/shared/console/uart.c
+++ b/bsps/lm32/shared/console/uart.c
@@ -1,3 +1,5 @@
* Uart driver for Lattice Mico32 (lm32) UART
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/bsps/lm32/shared/console/uart.h b/bsps/lm32/shared/console/uart.h
index 6a3706a537..1388a34634 100644
--- a/bsps/lm32/shared/console/uart.h
+++ b/bsps/lm32/shared/console/uart.h
@@ -1,3 +1,5 @@
* @file
* @ingroup RTEMSBSPsLM32Shared lm32_uart
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/bsps/lm32/shared/start/bspreset.c b/bsps/lm32/shared/start/bspreset.c
index 0c41dc6f41..16bc6b238d 100644
--- a/bsps/lm32/shared/start/bspreset.c
+++ b/bsps/lm32/shared/start/bspreset.c
@@ -1,3 +1,5 @@
* @file
@@ -8,9 +10,26 @@
* COPYRIGHT (c) 1989-2015.
+ * are met:
#include <bsp.h>
diff --git a/bsps/lm32/shared/start/bspstart.c b/bsps/lm32/shared/start/bspstart.c
index 6a419e869e..8fd915b014 100644
--- a/bsps/lm32/shared/start/bspstart.c
+++ b/bsps/lm32/shared/start/bspstart.c
@@ -1,3 +1,5 @@
* This routine starts the application. It includes application,
* board, and monitor specific initialization and configuration.
@@ -7,9 +9,26 @@
+ * are met:
2.24.4
