[PATCH 07/23] m68k/bsps/av5282: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Mon Jul 11 22:36:25 UTC 2022
Updates #3053.
bsps/m68k/av5282/start/bspstart.c | 25 ++++++++++++++++++++++---
bsps/m68k/av5282/start/linkcmds | 25 ++++++++++++++++++++++---
bsps/m68k/av5282/start/linkcmdsflash | 25 ++++++++++++++++++++++---
bsps/m68k/av5282/start/linkcmdsram | 25 ++++++++++++++++++++++---
bsps/m68k/av5282/start/start.S | 25 ++++++++++++++++++++++---
5 files changed, 110 insertions(+), 15 deletions(-)
diff --git a/bsps/m68k/av5282/start/bspstart.c b/bsps/m68k/av5282/start/bspstart.c
index c2dd362a6d..1f95474f2f 100644
--- a/bsps/m68k/av5282/start/bspstart.c
+++ b/bsps/m68k/av5282/start/bspstart.c
@@ -1,3 +1,5 @@
* This routine does the bulk of the system initialisation.
@@ -10,9 +12,26 @@
* COPYRIGHT (c) 1989-1998.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#include <bsp.h>
diff --git a/bsps/m68k/av5282/start/linkcmds b/bsps/m68k/av5282/start/linkcmds
index 0c0b3df561..e74c30c7b6 100644
--- a/bsps/m68k/av5282/start/linkcmds
+++ b/bsps/m68k/av5282/start/linkcmds
@@ -1,3 +1,5 @@
* This file contains directives for the GNU linker which are specific
* to the Arcturus uC DIMM ColdFire 5282
@@ -5,9 +7,26 @@
* COPYRIGHT (c) 1989-2007.
+ * are met:
diff --git a/bsps/m68k/av5282/start/linkcmdsflash b/bsps/m68k/av5282/start/linkcmdsflash
index 83d761bc56..b7670e5134 100644
--- a/bsps/m68k/av5282/start/linkcmdsflash
+++ b/bsps/m68k/av5282/start/linkcmdsflash
@@ -1,3 +1,5 @@
@@ -5,9 +7,26 @@
* COPYRIGHT (c) 1989-1999.
+ * are met:
diff --git a/bsps/m68k/av5282/start/linkcmdsram b/bsps/m68k/av5282/start/linkcmdsram
index 354a26c383..a28c402eaa 100644
--- a/bsps/m68k/av5282/start/linkcmdsram
+++ b/bsps/m68k/av5282/start/linkcmdsram
@@ -1,3 +1,5 @@
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/bsps/m68k/av5282/start/start.S b/bsps/m68k/av5282/start/start.S
index 1142316877..47c5c7fde9 100644
--- a/bsps/m68k/av5282/start/start.S
+++ b/bsps/m68k/av5282/start/start.S
@@ -1,3 +1,5 @@
* uC5282 startup code
@@ -11,9 +13,26 @@
* COPYRIGHT (c) 1989-2014.
+ * are met:
#include <bsp.h>
2.24.4
