[PATCH 09/23] bsps/m68k/gen68340: Change license to BSD-2
Mon Jul 11 22:36:28 UTC 2022
Updates #3053.
 bsps/m68k/gen68340/btimer/btimer.c     | 25 ++++++++++++++++++++++---
 bsps/m68k/gen68340/clock/ckinit.c      | 25 ++++++++++++++++++++++---
 bsps/m68k/gen68340/console/console.c   | 25 ++++++++++++++++++++++---
 bsps/m68k/gen68340/console/m340uart.c  | 25 ++++++++++++++++++++++---
 bsps/m68k/gen68340/include/bsp.h       | 25 ++++++++++++++++++++++---
 bsps/m68k/gen68340/include/m340timer.h | 25 ++++++++++++++++++++++---
 bsps/m68k/gen68340/include/m340uart.h  | 25 ++++++++++++++++++++++---
 bsps/m68k/gen68340/start/dumpanic.c    | 25 ++++++++++++++++++++++---
 bsps/m68k/gen68340/start/start.S       | 25 ++++++++++++++++++++++---
 9 files changed, 198 insertions(+), 27 deletions(-)
diff --git a/bsps/m68k/gen68340/btimer/btimer.c b/bsps/m68k/gen68340/btimer/btimer.c
index 23cddd95b0..4fff208c55 100644
--- a/bsps/m68k/gen68340/btimer/btimer.c
+++ b/bsps/m68k/gen68340/btimer/btimer.c
@@ -1,3 +1,5 @@
  * ATTENTION: As MC68349 has no built-in Timer, the following code doesn't work
  *            in a MC68349. You can't use FIFO full mode for the moment, but
@@ -22,9 +24,26 @@
  *  COPYRIGHT (c) 1989-1999.
  *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
diff --git a/bsps/m68k/gen68340/clock/ckinit.c b/bsps/m68k/gen68340/clock/ckinit.c
index adbb14a399..8ca30426b7 100644
--- a/bsps/m68k/gen68340/clock/ckinit.c
+++ b/bsps/m68k/gen68340/clock/ckinit.c
@@ -1,3 +1,5 @@
  * This routine initializes the MC68340/349 Periodic Interval Timer
@@ -19,9 +21,26 @@
  * COPYRIGHT (c) 1989-2014.
+ * are met:
 #include <stdlib.h>       /* for atexit() */
diff --git a/bsps/m68k/gen68340/console/console.c b/bsps/m68k/gen68340/console/console.c
index b10ad953c5..34c18bc129 100644
--- a/bsps/m68k/gen68340/console/console.c
+++ b/bsps/m68k/gen68340/console/console.c
@@ -1,3 +1,5 @@
  *  68340/68349 console serial I/O.
@@ -15,9 +17,26 @@
+ * are met:
 #include <termios.h>
diff --git a/bsps/m68k/gen68340/console/m340uart.c b/bsps/m68k/gen68340/console/m340uart.c
index 56ad29c256..d8207ea757 100644
--- a/bsps/m68k/gen68340/console/m340uart.c
+++ b/bsps/m68k/gen68340/console/m340uart.c
@@ -1,3 +1,5 @@
  *  M68340/349 UART management tools
@@ -15,9 +17,26 @@
+ * are met:
diff --git a/bsps/m68k/gen68340/include/bsp.h b/bsps/m68k/gen68340/include/bsp.h
index 6bc0f74a19..d455f51eaf 100644
--- a/bsps/m68k/gen68340/include/bsp.h
+++ b/bsps/m68k/gen68340/include/bsp.h
@@ -1,3 +1,5 @@
  * @file
@@ -18,9 +20,26 @@
+ * are met:
 #ifndef LIBBSP_M68K_GEN68340_BSP_H
diff --git a/bsps/m68k/gen68340/include/m340timer.h b/bsps/m68k/gen68340/include/m340timer.h
index 35d2406ecc..2c3d00e818 100644
--- a/bsps/m68k/gen68340/include/m340timer.h
+++ b/bsps/m68k/gen68340/include/m340timer.h
@@ -1,3 +1,5 @@
  * @file
@@ -22,9 +24,26 @@
+ * are met:
 #ifndef __m340timer_H__
diff --git a/bsps/m68k/gen68340/include/m340uart.h b/bsps/m68k/gen68340/include/m340uart.h
index 624856a078..c7991089ab 100644
--- a/bsps/m68k/gen68340/include/m340uart.h
+++ b/bsps/m68k/gen68340/include/m340uart.h
@@ -1,3 +1,5 @@
  * @file
@@ -23,9 +25,26 @@
  *  COPYRIGHT (c) 1989-2008.
+ * are met:
 #ifndef __m340uart_H__
diff --git a/bsps/m68k/gen68340/start/dumpanic.c b/bsps/m68k/gen68340/start/dumpanic.c
index 7f82ab3a77..2569550dd5 100644
--- a/bsps/m68k/gen68340/start/dumpanic.c
+++ b/bsps/m68k/gen68340/start/dumpanic.c
@@ -1,3 +1,5 @@
  *  M68340/349 registers and stack dump if an exception is raised
@@ -13,9 +15,26 @@
+ * are met:
 #include <bsp.h>
diff --git a/bsps/m68k/gen68340/start/start.S b/bsps/m68k/gen68340/start/start.S
index 1e00804b87..94d9ee0a36 100644
--- a/bsps/m68k/gen68340/start/start.S
+++ b/bsps/m68k/gen68340/start/start.S
@@ -1,3 +1,5 @@
  *  This file contains the entry point for the application.
  *  The name of this entry point is compiler dependent.
@@ -9,9 +11,26 @@
- *  The license and distribution terms for this file may in
- *  the file LICENSE in this distribution or at
+ * are met:
  * Based on the `gen68360' board support package, and covered by the
  * original distribution terms.
2.24.4
