[PATCH 10/35] bsps/nios2/nios2_iss: Change license to BSD-2
Mon Jul 11 22:36:31 UTC 2022
Updates #3053.
 bsps/nios2/nios2_iss/include/bsp.h | 25 ++++++++++++++++++++++---
 1 file changed, 22 insertions(+), 3 deletions(-)
diff --git a/bsps/nios2/nios2_iss/include/bsp.h b/bsps/nios2/nios2_iss/include/bsp.h
index 17a89a0ef9..51c2bc51db 100644
--- a/bsps/nios2/nios2_iss/include/bsp.h
+++ b/bsps/nios2/nios2_iss/include/bsp.h
@@ -1,3 +1,5 @@
  * @file
@@ -15,9 +17,26 @@
  *  COPYRIGHT (c) 1989-1999.
  *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
 #ifndef LIBBSP_NIOS2_NIOS2_ISS_BSP_H
2.24.4
