[PATCH 11/35] bsps/no_cpu/no_bsp: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Mon Jul 11 22:36:33 UTC 2022
Updates #3053.
bsps/no_cpu/no_bsp/btimer/btimer.c | 25 ++++++++++++++++++++++---
bsps/no_cpu/no_bsp/btimer/timerisr.c | 25 ++++++++++++++++++++++---
bsps/no_cpu/no_bsp/clock/ckinit.c | 25 ++++++++++++++++++++++---
bsps/no_cpu/no_bsp/console/console.c | 25 ++++++++++++++++++++++---
bsps/no_cpu/no_bsp/include/bsp.h | 25 ++++++++++++++++++++++---
bsps/no_cpu/no_bsp/mpci/addrconv.c | 25 ++++++++++++++++++++++---
bsps/no_cpu/no_bsp/mpci/getcfg.c | 25 ++++++++++++++++++++++---
bsps/no_cpu/no_bsp/mpci/lock.c | 25 ++++++++++++++++++++++---
bsps/no_cpu/no_bsp/mpci/mpisr.c | 25 ++++++++++++++++++++++---
bsps/no_cpu/no_bsp/start/bspstart.c | 25 ++++++++++++++++++++++---
bsps/no_cpu/no_bsp/start/linkcmds | 25 ++++++++++++++++++++++---
bsps/no_cpu/no_bsp/start/setvec.c | 25 ++++++++++++++++++++++---
12 files changed, 264 insertions(+), 36 deletions(-)
diff --git a/bsps/no_cpu/no_bsp/btimer/btimer.c b/bsps/no_cpu/no_bsp/btimer/btimer.c
index e9b59dc756..e1b64bbce8 100644
--- a/bsps/no_cpu/no_bsp/btimer/btimer.c
+++ b/bsps/no_cpu/no_bsp/btimer/btimer.c
@@ -1,3 +1,5 @@
/* timer.c
* This file manages the benchmark timer used by the RTEMS Timing Test
@@ -11,9 +13,26 @@
* COPYRIGHT (c) 1989-1999.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
diff --git a/bsps/no_cpu/no_bsp/btimer/timerisr.c b/bsps/no_cpu/no_bsp/btimer/timerisr.c
index 5ca7152a54..1590902a73 100644
--- a/bsps/no_cpu/no_bsp/btimer/timerisr.c
+++ b/bsps/no_cpu/no_bsp/btimer/timerisr.c
@@ -1,3 +1,5 @@
* @file
@@ -19,9 +21,26 @@
+ * are met:
diff --git a/bsps/no_cpu/no_bsp/clock/ckinit.c b/bsps/no_cpu/no_bsp/clock/ckinit.c
index ef24c8fbe0..600b7eee02 100644
--- a/bsps/no_cpu/no_bsp/clock/ckinit.c
+++ b/bsps/no_cpu/no_bsp/clock/ckinit.c
@@ -1,3 +1,5 @@
* This file provides a template for the clock device driver initialization.
@@ -9,9 +11,26 @@
* COPYRIGHT (c) 1989-2014.
+ * are met:
diff --git a/bsps/no_cpu/no_bsp/console/console.c b/bsps/no_cpu/no_bsp/console/console.c
index 41c17c29ef..267d29ee66 100644
--- a/bsps/no_cpu/no_bsp/console/console.c
+++ b/bsps/no_cpu/no_bsp/console/console.c
@@ -1,12 +1,31 @@
* This file contains the template for a console IO package.
+ * are met:
#define NO_BSP_INIT
diff --git a/bsps/no_cpu/no_bsp/include/bsp.h b/bsps/no_cpu/no_bsp/include/bsp.h
index 46a20fc831..7ae85b95b5 100644
--- a/bsps/no_cpu/no_bsp/include/bsp.h
+++ b/bsps/no_cpu/no_bsp/include/bsp.h
@@ -1,3 +1,5 @@
* @file
@@ -17,9 +19,26 @@
+ * are met:
#ifndef LIBBSP_NO_CPU_NO_BSP_BSP_H
diff --git a/bsps/no_cpu/no_bsp/mpci/addrconv.c b/bsps/no_cpu/no_bsp/mpci/addrconv.c
index 2656bc1ccf..ebb65b1a70 100644
--- a/bsps/no_cpu/no_bsp/mpci/addrconv.c
+++ b/bsps/no_cpu/no_bsp/mpci/addrconv.c
@@ -1,3 +1,5 @@
/* Shm_Convert_address
* No address range conversion is required.
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/bsps/no_cpu/no_bsp/mpci/getcfg.c b/bsps/no_cpu/no_bsp/mpci/getcfg.c
index 2179838b4b..02ed93e377 100644
--- a/bsps/no_cpu/no_bsp/mpci/getcfg.c
+++ b/bsps/no_cpu/no_bsp/mpci/getcfg.c
@@ -1,3 +1,5 @@
/* void Shm_Get_configuration( localnode, &shmcfg )
* This routine initializes, if necessary, and returns a pointer
@@ -24,9 +26,26 @@ XXX: FIX THE COMMENTS BELOW WHEN THE CPU IS KNOWN
+ * are met:
diff --git a/bsps/no_cpu/no_bsp/mpci/lock.c b/bsps/no_cpu/no_bsp/mpci/lock.c
index 5b53df8d38..26f51c4c19 100644
--- a/bsps/no_cpu/no_bsp/mpci/lock.c
+++ b/bsps/no_cpu/no_bsp/mpci/lock.c
@@ -1,3 +1,5 @@
/* Shared Memory Lock Routines
* This shared memory locked queue support routine need to be
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/bsps/no_cpu/no_bsp/mpci/mpisr.c b/bsps/no_cpu/no_bsp/mpci/mpisr.c
index 19939ec81c..a21cafd765 100644
--- a/bsps/no_cpu/no_bsp/mpci/mpisr.c
+++ b/bsps/no_cpu/no_bsp/mpci/mpisr.c
@@ -1,3 +1,5 @@
* @file
@@ -8,9 +10,26 @@
* COPYRIGHT (c) 1989-2012.
+ * are met:
diff --git a/bsps/no_cpu/no_bsp/start/bspstart.c b/bsps/no_cpu/no_bsp/start/bspstart.c
index b77b971ca1..350d1a0f31 100644
--- a/bsps/no_cpu/no_bsp/start/bspstart.c
+++ b/bsps/no_cpu/no_bsp/start/bspstart.c
@@ -1,3 +1,5 @@
* This routine starts the application. It includes application,
* board, and monitor specific initialization and configuration.
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/bsps/no_cpu/no_bsp/start/linkcmds b/bsps/no_cpu/no_bsp/start/linkcmds
index 6f2fda7b41..46b670d133 100644
--- a/bsps/no_cpu/no_bsp/start/linkcmds
+++ b/bsps/no_cpu/no_bsp/start/linkcmds
@@ -1,3 +1,5 @@
* This file contains directives for the GNU linker which are specific
* to the NO_CPU NO_BSP BOARD.
@@ -5,9 +7,26 @@
+ * are met:
MEMORY
diff --git a/bsps/no_cpu/no_bsp/start/setvec.c b/bsps/no_cpu/no_bsp/start/setvec.c
index 270fa445ac..ca1484f8b2 100644
--- a/bsps/no_cpu/no_bsp/start/setvec.c
+++ b/bsps/no_cpu/no_bsp/start/setvec.c
@@ -1,3 +1,5 @@
/* set_vector
* This routine installs an interrupt vector on the target Board/CPU.
@@ -15,9 +17,26 @@
+ * are met:
