[PATCH 14/23] bsps/m68k/mcf52235: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Mon Jul 11 22:36:38 UTC 2022
Updates #3053.
.../m68k/mcf52235/start/bspgetcpuclockspeed.c | 25 ++++++++++++++++---
bsps/m68k/mcf52235/start/linkcmds | 25 ++++++++++++++++---
bsps/m68k/mcf52235/start/start.S | 25 ++++++++++++++++---
3 files changed, 66 insertions(+), 9 deletions(-)
diff --git a/bsps/m68k/mcf52235/start/bspgetcpuclockspeed.c b/bsps/m68k/mcf52235/start/bspgetcpuclockspeed.c
index 563044394a..3d6c365109 100644
--- a/bsps/m68k/mcf52235/start/bspgetcpuclockspeed.c
+++ b/bsps/m68k/mcf52235/start/bspgetcpuclockspeed.c
@@ -1,10 +1,29 @@
* COPYRIGHT (c) 1989-2008.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#include <bsp.h>
diff --git a/bsps/m68k/mcf52235/start/linkcmds b/bsps/m68k/mcf52235/start/linkcmds
index e20d3031d7..efe48117d0 100644
--- a/bsps/m68k/mcf52235/start/linkcmds
+++ b/bsps/m68k/mcf52235/start/linkcmds
@@ -1,3 +1,5 @@
* This file contains directives for the GNU linker which are specific
* to the Freescale ColdFire mcf52235
@@ -5,9 +7,26 @@
* COPYRIGHT (c) 1989-1999.
- * http://www.rtems.org/license/LICENSE.e
+ * are met:
+ * POSSIBILITY OF SUCH DAMAGE.e
diff --git a/bsps/m68k/mcf52235/start/start.S b/bsps/m68k/mcf52235/start/start.S
index c71f4fed8a..f5dcfb53da 100644
--- a/bsps/m68k/mcf52235/start/start.S
+++ b/bsps/m68k/mcf52235/start/start.S
@@ -1,3 +1,5 @@
* mcf52235 startup code
@@ -9,9 +11,26 @@
* COPYRIGHT (c) 1989-1998.
+ * are met:
#include <rtems/asm.h>
2.24.4
