[PATCH 16/23] bsps/m68k/mvf5235: Change license to BSD-2
Mon Jul 11 22:36:42 UTC 2022
Updates #3053.
 bsps/m68k/mcf5235/start/bspgetcpuclockspeed.c | 25 ++++++++++++++++---
 bsps/m68k/mcf5235/start/bspstart.c            | 25 ++++++++++++++++---
 bsps/m68k/mcf5235/start/linkcmds              | 25 ++++++++++++++++---
 bsps/m68k/mcf5235/start/linkcmdsflash         | 25 ++++++++++++++++---
 bsps/m68k/mcf5235/start/linkcmdsram           | 25 ++++++++++++++++---
 bsps/m68k/mcf5235/start/start.S               | 25 ++++++++++++++++---
 6 files changed, 132 insertions(+), 18 deletions(-)
diff --git a/bsps/m68k/mcf5235/start/bspgetcpuclockspeed.c b/bsps/m68k/mcf5235/start/bspgetcpuclockspeed.c
index 548caaa9b8..d6331fa8aa 100644
--- a/bsps/m68k/mcf5235/start/bspgetcpuclockspeed.c
+++ b/bsps/m68k/mcf5235/start/bspgetcpuclockspeed.c
@@ -1,10 +1,29 @@
  *  COPYRIGHT (c) 1989-2008.
  *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
 #include <bsp.h>
diff --git a/bsps/m68k/mcf5235/start/bspstart.c b/bsps/m68k/mcf5235/start/bspstart.c
index 744d4c9142..2d9a347dde 100644
--- a/bsps/m68k/mcf5235/start/bspstart.c
+++ b/bsps/m68k/mcf5235/start/bspstart.c
@@ -1,3 +1,5 @@
  *  This routine does the bulk of the system initialization.
@@ -6,9 +8,26 @@
+ * are met:
 #include <bsp.h>
diff --git a/bsps/m68k/mcf5235/start/linkcmds b/bsps/m68k/mcf5235/start/linkcmds
index fe2ebd26d2..9cdddcd38f 100644
--- a/bsps/m68k/mcf5235/start/linkcmds
+++ b/bsps/m68k/mcf5235/start/linkcmds
@@ -1,3 +1,5 @@
  *  This file contains directives for the GNU linker which are specific
  *  to the Freescale ColdFire mcf5235
@@ -5,9 +7,26 @@
  *  COPYRIGHT (c) 1989-1999.
+ * are met:
diff --git a/bsps/m68k/mcf5235/start/linkcmdsflash b/bsps/m68k/mcf5235/start/linkcmdsflash
index 2c25105134..7e796ceaff 100644
--- a/bsps/m68k/mcf5235/start/linkcmdsflash
+++ b/bsps/m68k/mcf5235/start/linkcmdsflash
@@ -1,3 +1,5 @@
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/bsps/m68k/mcf5235/start/linkcmdsram b/bsps/m68k/mcf5235/start/linkcmdsram
index 25e0f9b093..057da6745f 100644
--- a/bsps/m68k/mcf5235/start/linkcmdsram
+++ b/bsps/m68k/mcf5235/start/linkcmdsram
@@ -1,3 +1,5 @@
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/bsps/m68k/mcf5235/start/start.S b/bsps/m68k/mcf5235/start/start.S
index cf33070d16..8ffcb78ecc 100644
--- a/bsps/m68k/mcf5235/start/start.S
+++ b/bsps/m68k/mcf5235/start/start.S
@@ -1,3 +1,5 @@
  *  mcf5235 startup code
@@ -9,9 +11,26 @@
  *  COPYRIGHT (c) 1989-1998.
+ * are met:
 #include <rtems/asm.h>
2.24.4
