[PATCH 17/23] bsps/m68k/mcf5329: Change license to BSD-2
Mon Jul 11 22:36:44 UTC 2022
Updates #3053.
 bsps/m68k/mcf5329/start/bspstart.c    | 25 ++++++++++++++++++++++---
 bsps/m68k/mcf5329/start/linkcmds      | 25 ++++++++++++++++++++++---
 bsps/m68k/mcf5329/start/linkcmdsflash | 25 ++++++++++++++++++++++---
 bsps/m68k/mcf5329/start/start.S       | 25 ++++++++++++++++++++++---
 4 files changed, 88 insertions(+), 12 deletions(-)
diff --git a/bsps/m68k/mcf5329/start/bspstart.c b/bsps/m68k/mcf5329/start/bspstart.c
index d5a258da47..7684af0589 100644
--- a/bsps/m68k/mcf5329/start/bspstart.c
+++ b/bsps/m68k/mcf5329/start/bspstart.c
@@ -1,3 +1,5 @@
  *  This routine does the bulk of the system initialisation.
@@ -10,9 +12,26 @@
  *  COPYRIGHT (c) 1989-1998.
  *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
 #include <bsp.h>
diff --git a/bsps/m68k/mcf5329/start/linkcmds b/bsps/m68k/mcf5329/start/linkcmds
index 8b017c06a8..1578dc6c60 100644
--- a/bsps/m68k/mcf5329/start/linkcmds
+++ b/bsps/m68k/mcf5329/start/linkcmds
@@ -1,3 +1,5 @@
  *  This file contains directives for the GNU linker which are specific
  *  to the Freescale ColdFire mcf52235
@@ -5,9 +7,26 @@
  *  COPYRIGHT (c) 1989-1999.
- *  http://www.rtems.org/license/LICENSE.e
+ * are met:
+ * POSSIBILITY OF SUCH DAMAGE.e
diff --git a/bsps/m68k/mcf5329/start/linkcmdsflash b/bsps/m68k/mcf5329/start/linkcmdsflash
index aacaca7b47..437852b7e4 100644
--- a/bsps/m68k/mcf5329/start/linkcmdsflash
+++ b/bsps/m68k/mcf5329/start/linkcmdsflash
@@ -1,3 +1,5 @@
@@ -5,9 +7,26 @@
+ * are met:
diff --git a/bsps/m68k/mcf5329/start/start.S b/bsps/m68k/mcf5329/start/start.S
index 7a61ffc998..102a88beae 100644
--- a/bsps/m68k/mcf5329/start/start.S
+++ b/bsps/m68k/mcf5329/start/start.S
@@ -1,3 +1,5 @@
  *  mcf52235 startup code
@@ -9,9 +11,26 @@
+ * are met:
 #include <rtems/asm.h>
2.24.4
