[PATCH 18/35] bsps/powerpc/psim: Change license to BSD-2
Mon Jul 11 22:36:47 UTC 2022
Updates #3053.
 bsps/powerpc/psim/console/console-io.c | 25 ++++++++++++++++++++++---
 bsps/powerpc/psim/mpci/addrconv.c      | 25 ++++++++++++++++++++++---
 bsps/powerpc/psim/mpci/getcfg.c        | 25 ++++++++++++++++++++++---
 bsps/powerpc/psim/mpci/lock.c          | 25 ++++++++++++++++++++++---
 bsps/powerpc/psim/mpci/mpisr.c         | 25 ++++++++++++++++++++++---
 bsps/powerpc/psim/start/bspstart.c     | 25 ++++++++++++++++++++++---
 bsps/powerpc/psim/start/linkcmds       | 25 ++++++++++++++++++++++---
 7 files changed, 154 insertions(+), 21 deletions(-)
diff --git a/bsps/powerpc/psim/console/console-io.c b/bsps/powerpc/psim/console/console-io.c
index 512b90dde2..85565ad3d0 100644
--- a/bsps/powerpc/psim/console/console-io.c
+++ b/bsps/powerpc/psim/console/console-io.c
@@ -1,3 +1,5 @@
  *  This file contains the hardware specific portions of the TTY driver
  *  for the simulated serial port on the PowerPC simulator.
@@ -7,9 +9,26 @@
  *  COPYRIGHT (c) 1989-2004.
  *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
 #include <bsp.h>
diff --git a/bsps/powerpc/psim/mpci/addrconv.c b/bsps/powerpc/psim/mpci/addrconv.c
index 2656bc1ccf..ebb65b1a70 100644
--- a/bsps/powerpc/psim/mpci/addrconv.c
+++ b/bsps/powerpc/psim/mpci/addrconv.c
@@ -1,3 +1,5 @@
 /*  Shm_Convert_address
  *  No address range conversion is required.
@@ -11,9 +13,26 @@
  *  COPYRIGHT (c) 1989-1999.
+ * are met:
diff --git a/bsps/powerpc/psim/mpci/getcfg.c b/bsps/powerpc/psim/mpci/getcfg.c
index 6be42f8b9c..8df93288f3 100644
--- a/bsps/powerpc/psim/mpci/getcfg.c
+++ b/bsps/powerpc/psim/mpci/getcfg.c
@@ -1,3 +1,5 @@
 /*  void Shm_Get_configuration( localnode, &shmcfg )
  *  This routine initializes, if necessary, and returns a pointer
@@ -15,9 +17,26 @@
  *  COPYRIGHT (c) 1989-2008.
+ * are met:
diff --git a/bsps/powerpc/psim/mpci/lock.c b/bsps/powerpc/psim/mpci/lock.c
index 6c0907e30f..a8917f1fa7 100644
--- a/bsps/powerpc/psim/mpci/lock.c
+++ b/bsps/powerpc/psim/mpci/lock.c
@@ -1,3 +1,5 @@
 /*  Shared Memory Lock Routines
  *  This shared memory locked queue support routine need to be
@@ -9,9 +11,26 @@
- *  The license and distribution terms for this file may in
- *  the file LICENSE in this distribution or at
+ * are met:
diff --git a/bsps/powerpc/psim/mpci/mpisr.c b/bsps/powerpc/psim/mpci/mpisr.c
index 8987a5a272..9f1964bf30 100644
--- a/bsps/powerpc/psim/mpci/mpisr.c
+++ b/bsps/powerpc/psim/mpci/mpisr.c
@@ -1,3 +1,5 @@
  *  NOTE: This routine is not used when in polling mode.  Either
  *        this routine OR Shm_clockisr is used in a particular system.
@@ -5,9 +7,26 @@
  *  COPYRIGHT (c) 1989-1997.
+ * are met:
diff --git a/bsps/powerpc/psim/start/bspstart.c b/bsps/powerpc/psim/start/bspstart.c
index 2cff2ff353..5862fb2156 100644
--- a/bsps/powerpc/psim/start/bspstart.c
+++ b/bsps/powerpc/psim/start/bspstart.c
@@ -1,3 +1,5 @@
  *  This set of routines starts the application.  It includes application,
  *  board, and monitor specific initialization and configuration.
@@ -7,9 +9,26 @@
+ * are met:
diff --git a/bsps/powerpc/psim/start/linkcmds b/bsps/powerpc/psim/start/linkcmds
index a9226a2eda..9d63966a08 100644
--- a/bsps/powerpc/psim/start/linkcmds
+++ b/bsps/powerpc/psim/start/linkcmds
@@ -1,10 +1,29 @@
+ * are met:
 EXTERN (__vectors)
2.24.4
