[PATCH 20/23] bsps/m68k/mvme147s: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Mon Jul 11 22:36:50 UTC 2022
Updates #3053.
bsps/m68k/mvme147s/include/bsp.h | 25 ++++++++++++++++++++++---
bsps/m68k/mvme147s/mpci/addrconv.c | 25 ++++++++++++++++++++++---
bsps/m68k/mvme147s/mpci/getcfg.c | 25 ++++++++++++++++++++++---
bsps/m68k/mvme147s/mpci/lock.c | 25 ++++++++++++++++++++++---
bsps/m68k/mvme147s/mpci/mpisr.c | 25 ++++++++++++++++++++++---
bsps/m68k/mvme147s/start/bspstart.c | 25 ++++++++++++++++++++++---
bsps/m68k/mvme147s/start/linkcmds | 25 ++++++++++++++++++++++---
7 files changed, 154 insertions(+), 21 deletions(-)
diff --git a/bsps/m68k/mvme147s/include/bsp.h b/bsps/m68k/mvme147s/include/bsp.h
index 6c285f9e6c..a5eb48982f 100644
--- a/bsps/m68k/mvme147s/include/bsp.h
+++ b/bsps/m68k/mvme147s/include/bsp.h
@@ -1,3 +1,5 @@
* @file
@@ -13,9 +15,26 @@
* COPYRIGHT (c) 1989-1999.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
* MVME147 port for TNI - Telecom Bretagne
* by Dominique LE CAMPION (Dominique.LECAMPION at enst-bretagne.fr)
diff --git a/bsps/m68k/mvme147s/mpci/addrconv.c b/bsps/m68k/mvme147s/mpci/addrconv.c
index 0ed0fdbed1..2e3c3a216e 100644
--- a/bsps/m68k/mvme147s/mpci/addrconv.c
+++ b/bsps/m68k/mvme147s/mpci/addrconv.c
@@ -1,3 +1,5 @@
/* Shm_Convert_address
* This MVME147 has a "normal" view of the VME address space.
@@ -12,9 +14,26 @@
+ * are met:
diff --git a/bsps/m68k/mvme147s/mpci/getcfg.c b/bsps/m68k/mvme147s/mpci/getcfg.c
index c549a9fcea..40c4910582 100644
--- a/bsps/m68k/mvme147s/mpci/getcfg.c
+++ b/bsps/m68k/mvme147s/mpci/getcfg.c
@@ -1,3 +1,5 @@
/* void Shm_Get_configuration( localnode, &shmcfg )
* This routine initializes, if necessary, and returns a pointer
@@ -16,9 +18,26 @@
+ * are met:
diff --git a/bsps/m68k/mvme147s/mpci/lock.c b/bsps/m68k/mvme147s/mpci/lock.c
index 129de01fd0..1301ef0581 100644
--- a/bsps/m68k/mvme147s/mpci/lock.c
+++ b/bsps/m68k/mvme147s/mpci/lock.c
@@ -1,3 +1,5 @@
/* Shared Memory Lock Routines
* This shared memory locked queue support routine need to be
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/bsps/m68k/mvme147s/mpci/mpisr.c b/bsps/m68k/mvme147s/mpci/mpisr.c
index 0669538e1b..8f7b8c2a4f 100644
--- a/bsps/m68k/mvme147s/mpci/mpisr.c
+++ b/bsps/m68k/mvme147s/mpci/mpisr.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
* COPYRIGHT (c) 1989-1999, 2016.
+ * are met:
diff --git a/bsps/m68k/mvme147s/start/bspstart.c b/bsps/m68k/mvme147s/start/bspstart.c
index 497b644150..dd007b70d6 100644
--- a/bsps/m68k/mvme147s/start/bspstart.c
+++ b/bsps/m68k/mvme147s/start/bspstart.c
@@ -1,3 +1,5 @@
* This routine does the bulk of the system initialization.
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/bsps/m68k/mvme147s/start/linkcmds b/bsps/m68k/mvme147s/start/linkcmds
index 01be6d93b2..dee9593f97 100644
--- a/bsps/m68k/mvme147s/start/linkcmds
+++ b/bsps/m68k/mvme147s/start/linkcmds
@@ -1,3 +1,5 @@
* This file contains directives for the GNU linker which are specific
* to the Motorola MVME147s boards.
@@ -7,9 +9,26 @@
* COPYRIGHT (c) 1989-2007,2016.
+ * are met:
2.24.4
