[PATCH 30/35] bsps/sh/shsim: Change license to BSD-2
Mon Jul 11 22:37:04 UTC 2022
Updates #3053.
 bsps/sh/shsim/console/console-debugio.c | 25 ++++++++++++++++++++++---
 bsps/sh/shsim/console/console-io.c      | 25 ++++++++++++++++++++++---
 bsps/sh/shsim/start/cpu_asm.c           | 25 ++++++++++++++++++++++---
 bsps/sh/shsim/start/sysexit.c           | 25 ++++++++++++++++++++++---
 4 files changed, 88 insertions(+), 12 deletions(-)
diff --git a/bsps/sh/shsim/console/console-debugio.c b/bsps/sh/shsim/console/console-debugio.c
index 0a81dbe45b..24d37dcc49 100644
--- a/bsps/sh/shsim/console/console-debugio.c
+++ b/bsps/sh/shsim/console/console-debugio.c
@@ -1,3 +1,5 @@
  *  @file
  *  @brief Stub printk() support
@@ -7,9 +9,26 @@
  *  COPYRIGHT (c) 1989-2014.
  *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
diff --git a/bsps/sh/shsim/console/console-io.c b/bsps/sh/shsim/console/console-io.c
index 71b089fdf7..ee4fadca0c 100644
--- a/bsps/sh/shsim/console/console-io.c
+++ b/bsps/sh/shsim/console/console-io.c
@@ -1,3 +1,5 @@
  *  This file contains the hardware specific portions of the TTY driver
  *  for the simulators stdin/out.
@@ -7,9 +9,26 @@
  *  COPYRIGHT (c) 1989-2011.
+ * are met:
 #include <bsp.h>
diff --git a/bsps/sh/shsim/start/cpu_asm.c b/bsps/sh/shsim/start/cpu_asm.c
index db5171b17a..e92b8dd87b 100644
--- a/bsps/sh/shsim/start/cpu_asm.c
+++ b/bsps/sh/shsim/start/cpu_asm.c
@@ -1,3 +1,5 @@
  *  Support for SuperH Simulator in GDB
@@ -6,9 +8,26 @@
  *  COPYRIGHT (c) 1989-2008.
+ * are met:
 #include <rtems/score/cpu.h>
diff --git a/bsps/sh/shsim/start/sysexit.c b/bsps/sh/shsim/start/sysexit.c
index dde20f35e8..fcb888d9af 100644
--- a/bsps/sh/shsim/start/sysexit.c
+++ b/bsps/sh/shsim/start/sysexit.c
@@ -1,3 +1,5 @@
  *  This file contains the simulator specific exit trap.
@@ -6,9 +8,26 @@
+ * are met:
 #include <bsp.h>
2.24.4
