[PATCH] samples/cdtest: Test execeptions during system init
Wed Jul 13 08:42:46 UTC 2022
On 01/07/2022 12:02, Sebastian Huber wrote:
> +static void early_exception()
> +    try
> +      throw "early exception";
> +    catch( const char *e )
> +      rtems_test_assert(strcmp(e, "early exception") == 0);
> +      throw "early exception 2";
> +static void test_exceptions_during_system_init()
> +    TEST_BEGIN();
> +    try
> +      early_exception();
> +      rtems_test_assert(strcmp(e, "early exception 2") == 0);
> +RTEMS_SYSINIT_ITEM(
> +    test_exceptions_during_system_init,
> +    RTEMS_SYSINIT_IDLE_THREADS,
> +    RTEMS_SYSINIT_ORDER_LAST
Actually, on targets which use the DWARF2 unwinder (for example sparc),
this doesn't work since the exception frames are no yet registered. They
are registered during global construction. This also means that C++
exceptions can only be used once the global construction completed on
these targets.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
