[PATCH 1/2] sptests: Disable Newlib reentrancy
Sebastian Huber
Wed Jul 13 09:28:39 UTC 2022
From: Matt Joyce <matthew.joyce at embedded-brains.de>
Update #4560.
testsuites/sptests/sp01/system.h | 7 +++++++
testsuites/sptests/spstkalloc02/init.c | 7 +++++++
testsuites/sptests/spstkalloc02/spstkalloc02.doc | 2 +-
testsuites/sptests/sptls03/init.c | 7 +++++++
4 files changed, 22 insertions(+), 1 deletion(-)
diff --git a/testsuites/sptests/sp01/system.h b/testsuites/sptests/sp01/system.h
index 46fa76f1e4..782fd929a7 100644
--- a/testsuites/sptests/sp01/system.h
+++ b/testsuites/sptests/sp01/system.h
@@ -48,6 +48,13 @@ rtems_task Task_1_through_3(
#define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
+ * This test requires full control over the present thread-local objects. In
+ * certain Newlib configurations, the Newlib reentrancy support may add
+ * thread-local objects.
+#define CONFIGURE_DISABLE_NEWLIB_REENTRANCY
#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
diff --git a/testsuites/sptests/spstkalloc02/init.c b/testsuites/sptests/spstkalloc02/init.c
index 5e5db20f0f..3613a6a563 100644
--- a/testsuites/sptests/spstkalloc02/init.c
+++ b/testsuites/sptests/spstkalloc02/init.c
@@ -138,6 +138,13 @@ static rtems_task Init(rtems_task_argument argument)
+ * This test requires full control over the present thread-local objects. This
+ * is necessary for the custom stack allocator below. In certain Newlib
+ * configurations, the Newlib reentrancy support may add thread-local objects.
#define CONFIGURE_MAXIMUM_TASKS TASK_COUNT
#define CONFIGURE_TASK_STACK_ALLOCATOR_INIT task_stack_init
diff --git a/testsuites/sptests/spstkalloc02/spstkalloc02.doc b/testsuites/sptests/spstkalloc02/spstkalloc02.doc
index a2dd0357ba..f4c09b4558 100644
--- a/testsuites/sptests/spstkalloc02/spstkalloc02.doc
+++ b/testsuites/sptests/spstkalloc02/spstkalloc02.doc
@@ -26,7 +26,7 @@
This file describes the directives and concepts tested by this test set.
-test set name: spstkalloc01
+test set name: spstkalloc02
The test expects that no thread-local object is present.
diff --git a/testsuites/sptests/sptls03/init.c b/testsuites/sptests/sptls03/init.c
index 2b60828808..6625327f45 100644
--- a/testsuites/sptests/sptls03/init.c
+++ b/testsuites/sptests/sptls03/init.c
@@ -68,6 +68,13 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_MAXIMUM_TASKS 1
2.35.3
