[PATCH 0/5] NOEL-V BSP
Daniel Cederman cederman at gaisler.com
Thu Jul 14 07:59:58 UTC 2022
Hello,
This patch set adds support for the NOEL-V RISC-V processors.
Currently there is a problem linking the ts-validation-cache.exe test
for 64-bit configurations. It fails with the following error message:
bsps/riscv/shared/start/start.S:100:(.bsp_start_text+0x70): relocation
truncated to fit: R_RISCV_GPREL_I against symbol `bsp_section_bss_size'
defined in *ABS* section
Anyone have an idea of what could be causing this?
Test results for the noel64imafd configuration in QEMU:
Failures:
 smpipi01.exe
 exit03.exe
 rtmonuse.exe
 cdtest.exe
 minimum.exe
 smpload01.exe
 smpschededf02.exe
 ts-validation-one-cpu-0.exe
 ts-validation-intr.exe
 ts-validation-smp-only-2.exe
User Input:
 capture.exe
 fileio.exe
 monitor.exe
 termios.exe
 top.exe
Timeouts:
 sprbtree01.exe
 ts-unit-no-clock-0.exe
 ts-performance-no-clock-0.exe
 ts-validation-no-clock-0.exe
 ts-validation-smp-only-0.exe
Invalid:
 spextensions01.exe
Benchmark:
 linpack.exe
 dhrystone.exe
 whetstone.exe
Is there an official list of tests that are expected to pass on RISC-V?
Martin Aberg (5):
  apbuart_termios: use bsp/irq.h
  bsp/riscv: Add NOEL-V BSP
  bsp/riscv: Work area size based on stack pointer
  bsp/riscv: Add NOEL-V BSP build specification
  bsp/riscv: Add NOEL-V configuration files
 bsps/riscv/include/bsp/start.h                |  65 ++++++
 bsps/riscv/noel/config/noel32im.cfg           |   9 +
 bsps/riscv/noel/config/noel32imafd.cfg        |   9 +
 bsps/riscv/noel/config/noel64imac.cfg         |   9 +
 bsps/riscv/noel/config/noel64imafd.cfg        |   9 +
 bsps/riscv/noel/config/noel64imafdc.cfg       |   9 +
 bsps/riscv/noel/console/console-config.c      | 209 ++++++++++++++++++
 bsps/riscv/noel/include/bsp.h                 |  76 +++++++
 bsps/riscv/noel/include/bsp/irq.h             |  75 +++++++
 bsps/riscv/noel/include/tm27.h                |   1 +
 bsps/riscv/noel/start/bsp_fatal_halt.c        |  46 ++++
 .../shared/start/bspgetworkarea-fromstack.c   |  53 +++++
 bsps/riscv/shared/start/start.S               |  25 +++
 bsps/shared/grlib/uart/apbuart_termios.c      |   1 +
 spec/build/bsps/riscv/noel/abi.yml            |  48 ++++
 spec/build/bsps/riscv/noel/bspnoel32im.yml    |  19 ++
 spec/build/bsps/riscv/noel/bspnoel32imafd.yml |  19 ++
 spec/build/bsps/riscv/noel/bspnoel64imac.yml  |  19 ++
 spec/build/bsps/riscv/noel/bspnoel64imafd.yml |  19 ++
 .../build/bsps/riscv/noel/bspnoel64imafdc.yml |  19 ++
 spec/build/bsps/riscv/noel/grp.yml            |  59 +++++
 spec/build/bsps/riscv/noel/obj.yml            |  38 ++++
 spec/build/bsps/riscv/noel/objsmp.yml         |  15 ++
 spec/build/bsps/riscv/noel/optconirq.yml      |  16 ++
 spec/build/bsps/riscv/noel/optextirqmax.yml   |  16 ++
 spec/build/bsps/riscv/optrambegin.yml         |   3 +
 spec/build/cpukit/optarchbits.yml             |   2 +
 spec/build/cpukit/optsmp.yml                  |   4 +
 28 files changed, 892 insertions(+)
 create mode 100644 bsps/riscv/include/bsp/start.h
 create mode 100644 bsps/riscv/noel/config/noel32im.cfg
 create mode 100644 bsps/riscv/noel/config/noel32imafd.cfg
 create mode 100644 bsps/riscv/noel/config/noel64imac.cfg
 create mode 100644 bsps/riscv/noel/config/noel64imafd.cfg
 create mode 100644 bsps/riscv/noel/config/noel64imafdc.cfg
 create mode 100644 bsps/riscv/noel/console/console-config.c
 create mode 100644 bsps/riscv/noel/include/bsp.h
 create mode 100644 bsps/riscv/noel/include/bsp/irq.h
 create mode 100644 bsps/riscv/noel/include/tm27.h
 create mode 100644 bsps/riscv/noel/start/bsp_fatal_halt.c
 create mode 100644 bsps/riscv/shared/start/bspgetworkarea-fromstack.c
 create mode 100644 spec/build/bsps/riscv/noel/abi.yml
 create mode 100644 spec/build/bsps/riscv/noel/bspnoel32im.yml
 create mode 100644 spec/build/bsps/riscv/noel/bspnoel32imafd.yml
 create mode 100644 spec/build/bsps/riscv/noel/bspnoel64imac.yml
 create mode 100644 spec/build/bsps/riscv/noel/bspnoel64imafd.yml
 create mode 100644 spec/build/bsps/riscv/noel/bspnoel64imafdc.yml
 create mode 100644 spec/build/bsps/riscv/noel/grp.yml
 create mode 100644 spec/build/bsps/riscv/noel/obj.yml
 create mode 100644 spec/build/bsps/riscv/noel/objsmp.yml
 create mode 100644 spec/build/bsps/riscv/noel/optconirq.yml
 create mode 100644 spec/build/bsps/riscv/noel/optextirqmax.yml
2.34.1
