[PATCH 3/3] score: Extend memory dirty/zero actions
Sebastian Huber
Thu Jul 14 13:13:02 UTC 2022
Dirty or zero also the part of the .noinit section used by RTEMS.
cpukit/include/rtems/score/memory.h | 14 +++++++-
cpukit/score/src/memorydirtyfreeareas.c | 9 ++++-
cpukit/score/src/memorynoinit.c | 45 +++++++++++++++++++++++++
cpukit/score/src/memoryzerofreeareas.c | 9 ++++-
spec/build/cpukit/librtemscpu.yml | 1 +
5 files changed, 75 insertions(+), 3 deletions(-)
create mode 100644 cpukit/score/src/memorynoinit.c
diff --git a/cpukit/include/rtems/score/memory.h b/cpukit/include/rtems/score/memory.h
index 5761402711..fa17ea164c 100644
--- a/cpukit/include/rtems/score/memory.h
+++ b/cpukit/include/rtems/score/memory.h
@@ -10,7 +10,7 @@
* SPDX-License-Identifier: BSD-2-Clause
- * Copyright (C) 2019 embedded brains GmbH
+ * Copyright (C) 2019, 2022 embedded brains GmbH
* modification, are permitted provided that the following conditions
@@ -352,6 +352,18 @@ void _Memory_Zero_free_areas( void );
void _Memory_Dirty_free_areas( void );
+ * @brief This symbol marks the begin of the non-initialized section used by
+ * RTEMS.
+extern char _Memory_Noinit_begin[];
+ * @brief This symbol marks the end of the non-initialized section used by
+ * RTEMS.
+extern char _Memory_Noinit_end[];
#ifdef __cplusplus
diff --git a/cpukit/score/src/memorydirtyfreeareas.c b/cpukit/score/src/memorydirtyfreeareas.c
index fc6c2630bf..8a817c2208 100644
--- a/cpukit/score/src/memorydirtyfreeareas.c
+++ b/cpukit/score/src/memorydirtyfreeareas.c
@@ -10,7 +10,7 @@
- * Copyright (C) 2020 embedded brains GmbH
+ * Copyright (C) 2020, 2022 embedded brains GmbH
@@ -40,7 +40,14 @@
#include <rtems/score/memory.h>
+#include <string.h>
_Memory_Fill( _Memory_Get(), 0xcf );
+ memset(
+ _Memory_Noinit_begin,
+ 0xcf,
+ (uintptr_t) _Memory_Noinit_end - (uintptr_t) _Memory_Noinit_begin
diff --git a/cpukit/score/src/memorynoinit.c b/cpukit/score/src/memorynoinit.c
new file mode 100644
index 0000000000..19772356cd
--- /dev/null
+++ b/cpukit/score/src/memorynoinit.c
@@ -0,0 +1,45 @@
+ * @file
+ * @ingroup RTEMSScoreMemory
+ * @brief This source file contains the definition of ::_Memory_Noinit_begin
+ * and ::_Memory_Noinit_end.
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2022 embedded brains GmbH
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/score/memory.h>
+RTEMS_SECTION( ".noinit.rtems.begin" ) char _Memory_Noinit_begin[ 0 ];
+RTEMS_SECTION( ".noinit.rtems.end" ) char _Memory_Noinit_end[ 0 ];
diff --git a/cpukit/score/src/memoryzerofreeareas.c b/cpukit/score/src/memoryzerofreeareas.c
index 4ea0812426..b1cef47ef9 100644
--- a/cpukit/score/src/memoryzerofreeareas.c
+++ b/cpukit/score/src/memoryzerofreeareas.c
@@ -10,7 +10,7 @@
@@ -40,7 +40,14 @@
_Memory_Fill( _Memory_Get(), 0 );
+ memset(
+ 0,
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index 31a68cf85a..012a5db141 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -1435,6 +1435,7 @@ source:
- cpukit/score/src/memoryallocate.c
- cpukit/score/src/memorydirtyfreeareas.c
- cpukit/score/src/memoryfill.c
+- cpukit/score/src/memorynoinit.c
- cpukit/score/src/memoryzerobeforeuse.c
- cpukit/score/src/memoryzerofreeareas.c
- cpukit/score/src/mutex.c
2.35.3
