[PATCH v3 1/2] bsp/riscv: Work area size based on stack pointer
Daniel Cederman
cederman at gaisler.com
Thu Jul 14 14:03:27 UTC 2022
Remember the initial stack pointer in start.S. It can later be used to
determine top of RAM.
bsps/riscv/include/bsp/start.h | 67 ++++++++++++++++
.../shared/start/bspgetworkarea-fromstack.c | 76 +++++++++++++++++++
bsps/riscv/shared/start/start.S | 25 ++++++
3 files changed, 168 insertions(+)
create mode 100644 bsps/riscv/include/bsp/start.h
create mode 100644 bsps/riscv/shared/start/bspgetworkarea-fromstack.c
diff --git a/bsps/riscv/include/bsp/start.h b/bsps/riscv/include/bsp/start.h
new file mode 100644
index 0000000000..267fc133c8
--- /dev/null
+++ b/bsps/riscv/include/bsp/start.h
@@ -0,0 +1,67 @@
+ * @file
+ * @ingroup RTEMSBSPsRISCVSharedStart
+ * @brief RISC-V start definitions.
+ * Copyright (c) 2021 Cobham Gaisler AB.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifndef LIBBSP_RISCV_SHARED_START_H
+#define LIBBSP_RISCV_SHARED_START_H
+ * @defgroup RTEMSBSPsRISCVSharedStart Start Support
+ * @brief Start support.
+#include <stdint.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * This variable is initialized by the first CPU entering the BSP start code.
+ * The value is the stack pointer at entry.
+extern uintptr_t riscv_start_stack_pointer;
+#ifdef __cplusplus
+#endif
+#endif /* LIBBSP_RISCV_SHARED_START_H */
diff --git a/bsps/riscv/shared/start/bspgetworkarea-fromstack.c b/bsps/riscv/shared/start/bspgetworkarea-fromstack.c
index 0000000000..d55a876346
--- /dev/null
+++ b/bsps/riscv/shared/start/bspgetworkarea-fromstack.c
@@ -0,0 +1,76 @@
+ * @file
+ * @brief BSP specific initialization support routines
+ * COPYRIGHT (c) 1989-2020.
+ * On-Line Applications Research Corporation (OAR).
+ * Cobham Gaisler AB.
+ * are met:
+#include <bsp.h>
+#include <bsp/start.h>
+#include <bsp/bootcard.h>
+#include <rtems/sysinit.h>
+ * These are provided by the linkcmds for ALL of the BSPs which use this file.
+extern char WorkAreaBase[];
+extern char RamEnd[];
+static Memory_Area _Memory_Areas[ 1 ];
+static void bsp_memory_initialize( void )
+ char *end;
+ /* top of RAM inidicated by initial stack pointer */
+ end = (char *) riscv_start_stack_pointer;
+ if (end == 0) {
+ /* fall back to linker symbol if not set */
+ end = RamEnd;
+ _Memory_Initialize( &_Memory_Areas[ 0 ], WorkAreaBase, end );
+RTEMS_SYSINIT_ITEM(
+ bsp_memory_initialize,
+ RTEMS_SYSINIT_MEMORY,
+ RTEMS_SYSINIT_ORDER_MIDDLE
+static const Memory_Information _Memory_Information =
+ MEMORY_INFORMATION_INITIALIZER( _Memory_Areas );
+const Memory_Information *_Memory_Get( void )
+ return &_Memory_Information;
diff --git a/bsps/riscv/shared/start/start.S b/bsps/riscv/shared/start/start.S
index 3702f8ac2f..21945a99f5 100644
--- a/bsps/riscv/shared/start/start.S
+++ b/bsps/riscv/shared/start/start.S
@@ -35,6 +35,16 @@
#include <bsp/linker-symbols.h>
#include <bspopts.h>
+#if __riscv_xlen == 32
+#define PTR_ALIGN 2
+#define PTR_SIZE 4
+#define PTR_VALUE .word
+#elif __riscv_xlen == 64
+#define PTR_ALIGN 3
+#define PTR_SIZE 8
+#define PTR_VALUE .dword
+#endif
PUBLIC(_start)
.section .bsp_start_text, "wax", @progbits
@@ -60,6 +70,9 @@ SYM(_start):
LADDR t0, _RISCV_Exception_handler
csrw mtvec, t0
+ /* Save stack pointer so it can mark end of work area later on */
+ mv t3, sp
/* Load stack pointer and branch to secondary processor start if necessary */
#ifdef RTEMS_SMP
LADDR sp, _ISR_Stack_area_begin
@@ -75,6 +88,9 @@ SYM(_start):
LADDR sp, _ISR_Stack_area_end
#endif
+ LADDR t0, riscv_start_stack_pointer
+ SREG t3, 0(t0)
#ifdef BSP_START_COPY_FDT_FROM_U_BOOT
mv a0, a1
call bsp_fdt_copy
@@ -146,3 +162,12 @@ SYM(_start):
#endif
#endif /* RTEMS_SMP */
+ .section .data, "aw"
+ .align PTR_ALIGN
+ .globl riscv_start_stack_pointer
+ .type riscv_start_stack_pointer, @object
+ .size riscv_start_stack_pointer, PTR_SIZE
+riscv_start_stack_pointer:
+ PTR_VALUE 0
2.34.1
