[PATCH] cdtest: Restrict exceptions during sysinit
Kinsey Moore kinsey.moore at oarcorp.com
Thu Jul 14 18:39:49 UTC 2022
I believe the logic in this patch is inverted for generating that #define.
Kinsey
-----Original Message-----
From: devel <devel-bounces at rtems.org> On Behalf Of Sebastian Huber
Sent: Wednesday, July 13, 2022 06:42
To: devel at rtems.org
Subject: [PATCH] cdtest: Restrict exceptions during sysinit
Exceptions during system initialization work only on targets which do not need
a registration of exception frames during the global construction.  In
particular, targets which use the DWARF2 unwinder cannot use exceptions during
system initialization.
 testsuites/samples/cdtest/main.cc | 14 ++++++++++++++
 1 file changed, 14 insertions(+)
diff --git a/testsuites/samples/cdtest/main.cc b/testsuites/samples/cdtest/main.cc
index 44cdaf84bb..d5530a657d 100644
--- a/testsuites/samples/cdtest/main.cc
+++ b/testsuites/samples/cdtest/main.cc
@@ -238,6 +238,17 @@ rtems_task main_task(
     exit(0);
+ * Exceptions during system initialization work only on targets which do not
+ * need a registration of exception frames during the global construction.  In
+ * particular, targets which use the DWARF2 unwinder cannot use exceptions
+ * during system initialization.
+#if defined(__arm__) || defined(__aarch64__)
+#define CAN_DO_EXCEPTIONS_DURING_SYSINIT
+#endif
+#ifdef CAN_DO_EXCEPTIONS_DURING_SYSINIT
 static void early_exception()
     try
@@ -250,11 +261,13 @@ static void early_exception()
       throw "early exception 2";
+#endif
 static void test_exceptions_during_system_init()
     TEST_BEGIN();
     try
       early_exception();
@@ -263,6 +276,7 @@ static void test_exceptions_during_system_init()
       rtems_test_assert(strcmp(e, "early exception 2") == 0);
+#endif
 RTEMS_SYSINIT_ITEM(
2.35.3
devel mailing list
devel at rtems.org
http://lists.rtems.org/mailman/listinfo/devel
