[PATCH 2/3] score: Place object controls into .noinit sections
Sebastian Huber
Fri Jul 15 06:34:11 UTC 2022
On 15.07.22 07:41, Sebastian Huber wrote:
>>> Placing these elements into the .noinit section reduces
>>> the system initialization time by decreasing the .bss section size.
>> How much data do you see that is being moved out of .bss to .noinit?
> It depends on your application configuration. You have for example about
> 700 bytes per task. I noticed this in an application which hit the
> watchdog due to an update to RTEMS 6 because of the longer boot time to
> the initialization task.
I added a ticket for this:
https://devel.rtems.org/ticket/4678
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
