[PATCH v2 3/3] score: Extend memory dirty/zero actions
Fri Jul 15 06:38:48 UTC 2022
Dirty or zero also the part of the .noinit section used by RTEMS.
Close #4678.
 cpukit/include/rtems/score/memory.h     | 14 +++++++-
 cpukit/score/src/memorydirtyfreeareas.c |  9 ++++-
 cpukit/score/src/memorynoinit.c         | 45 +++++++++++++++++++++++
 cpukit/score/src/memoryzerofreeareas.c  |  9 ++++-
 spec/build/cpukit/librtemscpu.yml       |  1 +
 testsuites/sptests/sp54/init.c          | 48 +++++++++++++++++++++----
 6 files changed, 117 insertions(+), 9 deletions(-)
 create mode 100644 cpukit/score/src/memorynoinit.c
diff --git a/cpukit/include/rtems/score/memory.h b/cpukit/include/rtems/score/memory.h
index 5761402711..fa17ea164c 100644
--- a/cpukit/include/rtems/score/memory.h
+++ b/cpukit/include/rtems/score/memory.h
@@ -10,7 +10,7 @@
  * SPDX-License-Identifier: BSD-2-Clause
- * Copyright (C) 2019 embedded brains GmbH
+ * Copyright (C) 2019, 2022 embedded brains GmbH
  * modification, are permitted provided that the following conditions
@@ -352,6 +352,18 @@ void _Memory_Zero_free_areas( void );
 void _Memory_Dirty_free_areas( void );
+ * @brief This symbol marks the begin of the non-initialized section used by
+ *   RTEMS.
+extern char _Memory_Noinit_begin[];
+ * @brief This symbol marks the end of the non-initialized section used by
+ *   RTEMS.
+extern char _Memory_Noinit_end[];
 #ifdef __cplusplus
diff --git a/cpukit/score/src/memorydirtyfreeareas.c b/cpukit/score/src/memorydirtyfreeareas.c
index fc6c2630bf..8a817c2208 100644
--- a/cpukit/score/src/memorydirtyfreeareas.c
+++ b/cpukit/score/src/memorydirtyfreeareas.c
@@ -10,7 +10,7 @@
- * Copyright (C) 2020 embedded brains GmbH
+ * Copyright (C) 2020, 2022 embedded brains GmbH
@@ -40,7 +40,14 @@
 #include <rtems/score/memory.h>
+#include <string.h>
   _Memory_Fill( _Memory_Get(), 0xcf );
+  memset(
+    _Memory_Noinit_begin,
+    0xcf,
+    (uintptr_t) _Memory_Noinit_end - (uintptr_t) _Memory_Noinit_begin
diff --git a/cpukit/score/src/memorynoinit.c b/cpukit/score/src/memorynoinit.c
new file mode 100644
index 0000000000..19772356cd
--- /dev/null
+++ b/cpukit/score/src/memorynoinit.c
@@ -0,0 +1,45 @@
+ * @file
+ * @ingroup RTEMSScoreMemory
+ * @brief This source file contains the definition of ::_Memory_Noinit_begin
+ *   and ::_Memory_Noinit_end.
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2022 embedded brains GmbH
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/score/memory.h>
+RTEMS_SECTION( ".noinit.rtems.begin" ) char _Memory_Noinit_begin[ 0 ];
+RTEMS_SECTION( ".noinit.rtems.end" ) char _Memory_Noinit_end[ 0 ];
diff --git a/cpukit/score/src/memoryzerofreeareas.c b/cpukit/score/src/memoryzerofreeareas.c
index 4ea0812426..b1cef47ef9 100644
--- a/cpukit/score/src/memoryzerofreeareas.c
+++ b/cpukit/score/src/memoryzerofreeareas.c
@@ -10,7 +10,7 @@
@@ -40,7 +40,14 @@
   _Memory_Fill( _Memory_Get(), 0 );
+  memset(
+    0,
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index 31a68cf85a..012a5db141 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -1435,6 +1435,7 @@ source:
 - cpukit/score/src/memoryallocate.c
 - cpukit/score/src/memorydirtyfreeareas.c
 - cpukit/score/src/memoryfill.c
+- cpukit/score/src/memorynoinit.c
 - cpukit/score/src/memoryzerobeforeuse.c
 - cpukit/score/src/memoryzerofreeareas.c
 - cpukit/score/src/mutex.c
diff --git a/testsuites/sptests/sp54/init.c b/testsuites/sptests/sp54/init.c
index 712a4ae8db..9ec98e19e0 100644
--- a/testsuites/sptests/sp54/init.c
+++ b/testsuites/sptests/sp54/init.c
@@ -37,6 +37,10 @@
 #include "config.h"
 #endif
+#include <rtems/sysinit.h>
+#include <rtems/score/thread.h>
 #include <tmacros.h>
 const char rtems_test_name[] = "SP 54";
@@ -48,12 +52,6 @@ static void *Init( uintptr_t ignored )
   rtems_id                             id;
   const rtems_api_configuration_table *config;
-   *  It is possible that since this thread prints and there is no idle
-   *  task, that the system could fail miserably. :(
-  TEST_BEGIN();
   puts( "Init - use valid id of API class with no objects" );
   status = rtems_task_set_priority(
     rtems_build_id(0x2,0x1,0x01,0x0001) /* 0xa010001 */,
@@ -80,6 +78,44 @@ static void *Init( uintptr_t ignored )
   rtems_test_exit(0);
+static void check_dirty_memory( void )
+  unsigned char *p;
+  TEST_BEGIN();
+  p = _Memory_Allocate( _Memory_Get(), sizeof( *p ), RTEMS_ALIGNOF( *p ) );
+  rtems_test_assert( p != NULL );
+  rtems_test_assert( *p == 0xcf );
+  p = (unsigned char *) _Thread_Information.Objects.local_table;
+RTEMS_SYSINIT_ITEM(
+  check_dirty_memory,
+  RTEMS_SYSINIT_DIRTY_MEMORY,
+  RTEMS_SYSINIT_ORDER_LAST
+static void check_zero_workspace_automatically( void )
+  unsigned char *p;
+  rtems_test_assert( *p == 0 );
+  check_zero_workspace_automatically,
+  RTEMS_SYSINIT_ZERO_MEMORY,
 /* configuration information */
 #define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
2.35.3
