<offlist> GSoC 2022:
Prashanth S fishesprashanth at gmail.com
Fri Jul 15 14:54:16 UTC 2022
Hi Christian,
I created a patch (attached in the mail) for review, which has CAN support.
Shall I send the patch for review to @rtems-devel at rtems.org
<devel at rtems.org>?
Regards
Prashanth S
On Mon, 11 Jul 2022 at 10:03, Prashanth S <fishesprashanth at gmail.com> wrote:
> Hi Christian,
> This is to update the status.
> Yesterday, pushed a fix for a bug in tx path and added minimal rx path.
> Regards
> Prashanth S
> On Thu, 7 Jul, 2022, 10:58 am Prashanth S, <fishesprashanth at gmail.com>
> wrote:
>> Hi Gedare,
>> This is to ask for the License on the TI files.
>> As we already confirmed on the license for TI files as BSD, this is to
>> double check.
>> I found two different licenses, I have added both of them.
>> *dcan.c and all header files (except dcan_frame.h)*
>>  *  \file   dcan.c
>>  *  \brief  DCAN APIs.
>>  *   This file contains the device abstraction layer APIs for
>>  *   Dual Controller Area Network(DCAN).
>> * Copyright (C) 2010 Texas Instruments Incorporated - http://www.ti.com/
>> *  Redistribution and use in source and binary forms, with or without
>> *  modification, are permitted provided that the following conditions
>> *  are met:
>> *    Redistributions of source code must retain the above copyright
>> *    notice, this list of conditions and the following disclaimer.
>> *    Redistributions in binary form must reproduce the above copyright
>> *    notice, this list of conditions and the following disclaimer in the
>> *    documentation and/or other materials provided with the
>> *    distribution.
>> *    Neither the name of Texas Instruments Incorporated nor the names of
>> *    its contributors may be used to endorse or promote products derived
>> *    from this software without specific prior written permission.
>> *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
>> *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
>> *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
>> *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
>> *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
>> *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
>> *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
>> *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
>> *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
>> *  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
>> *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
>> *dcan_frame.c and dcan_frame.h*
>> * \file   dcan_frame.c
>>  * \brief  This file consists of wrapper functions which internally call
>>  *         DCAN APIs.
>>  * Copyright (C) 2005 Marc Kleine-Budde, Pengutronix
>>  * Copyright (C) 2006 Andrey Volkov, Varma Electronics
>>  * Copyright (C) 2008-2009 Wolfgang Grandegger <wg at grandegger.com>
>>  * This program is free software; you can redistribute it and/or modify
>>  * it under the terms of the version 2 of the GNU General Public License
>>  * as published by the Free Software Foundation
>>  * This program is distributed in the hope that it will be useful,
>>  * but WITHOUT ANY WARRANTY; without even the implied warranty of
>>  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
>>  * GNU General Public License for more details.
>>  * You should have received a copy of the GNU General Public License
>>  * along with this program; if not, write to the Free Software
>>  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
>>  USA
>> Regards
>> Prashanth S
>> On Wed, 1 Jun 2022 at 07:15, Gedare Bloom <gedare at rtems.org> wrote:
>>> On Sun, May 29, 2022 at 6:09 AM Prashanth S <fishesprashanth at gmail.com>
>>> wrote:
>>> > Hi Christian,
>>> > Please make sure to take notes for blog posts or the weekly
>>> > status meeting.
>>> > Ok.
>>> > The License mentined in drivers/dcan.c
>>> http://www.ti.com/
>>> > *  are met:
>>> the
>>> > *    distribution.
>>> of
>>> derived
>>> FOR
>>> INCIDENTAL,
>>> USE,
>>> ANY
>>> USE
>>> That license looks ok. It is a 3-BSD (2-BSD with advertising
>>> restriction).
>>> Is there an AM335x API for CAN in addition to the drivers? I have used
>>> TI's Tivaware before which has it's own CAN API, for example. That
>>> could be another possibility to consider for an initial simple target,
>>> if the code already exists for it.
>>> I think the choice of CAN API is a bit complicated. The grlib/grcan is
>>> actually a good choice for RTEMS.
>>> > Regards
>>> > Prashanth S
>>> > On Sun, 29 May 2022 at 13:33, Christian Mauderer <oss at c-mauderer.de>
>>> wrote:
>>> >> Hello Prashanth,
>>> >> sounds good. Please make sure to take notes for blog posts or the
>>> weekly
>>> >> status meeting.
>>> >> You mention "Am335x starterware". Which license does that have? If it
>>> is
>>> >> compatible to the BSD license, it might would be possible to just port
>>> >> the driver.
>>> >> Best regards
>>> >> Christian
>>> >> Am 28.05.22 um 16:15 schrieb Prashanth S:
>>> >> > Hi All,
>>> >> > This is a status update on today's work.
>>> >> > Gone through the HW initialization requirements for CAN loopback to
>>> work
>>> >> > in interrupt mode from Am335x starterware.
>>> >> > With this and the Am335x reference manual, I would try to
>>> understand the
>>> >> > HW initialization sequence and then start implementing the driver
>>> in RTEMS.
>>> >> > Regards
>>> >> > Prashanth S
>>> >> > On Fri, 27 May 2022 at 00:00, Christian Mauderer <oss at c-mauderer.de
>>> >> > <mailto:oss at c-mauderer.de>> wrote:
>>> >> >     Am 26.05.22 um 19:16 schrieb Prashanth S:
>>> >> >      > Hi Christian,
>>> >> >      > You have a medium sized project. That means it's no full
>>> time. Do
>>> >> >      > you plan to work full time on the start or the end or part
>>> time
>>> >> >     during
>>> >> >      > the whole GSoC time?
>>> >> >      > I plan to work part time on the weekdays and full time on the
>>> >> >     weekends.
>>> >> >      > The plan of project is more or less your proposal, isn't it?
>>> >> >      > Yes the plan is the same as the proposal.
>>> >> >      > Beneath that: I think you need a decision soon which CAN
>>> stack
>>> >> >     you want
>>> >> >      > to use. It will define some of the interfaces for the CAN
>>> driver.
>>> >> >     Pavel
>>> >> >      > suggested a few on the mailing list. I'm not sure whether
>>> there
>>> >> >     was some
>>> >> >      > final one selected?
>>> >> >      > The final one is not selected yet. Meanwhile, I thought of
>>> >> >     implementing
>>> >> >      > the CAN driver
>>> >> >      > and get the tx and rx working, and get the driver into the
>>> framework.
>>> >> >     You can start working on some parts but note that different
>>> driver
>>> >> >     stacks can have quite different APIs. Therefore most of the
>>> time it's
>>> >> >     simpler if you know the stack that should be used.
>>> >> >      > @pisa at cmp.felk.cvut.cz <mailto:pisa at cmp.felk.cvut.cz>
>>> >> >     <mailto:pisa at cmp.felk.cvut.cz <mailto:pisa at cmp.felk.cvut.cz>> ,
>>> >> >     @Christian
>>> >> >      > Mauderer <mailto:oss at c-mauderer.de <mailto:oss at c-mauderer.de>>
>>> >> >     @Gedare Bloom
>>> >> >      > <mailto:gedare at rtems.org <mailto:gedare at rtems.org>> .
>>> >> >      > May I ask for suggestions on the CAN framework for RTEMS.
>>> >> >      > Shall I take the suggested stacks as reference and develop
>>> APIs
>>> >> >     and data
>>> >> >      > structures.
>>> >> >      > Or select a particular stack and port the required features?
>>> >> >     I think Pavel knows CAN stacks and frameworks a lot better than
>>> me.
>>> >> >     So I
>>> >> >     hope that he can suggest a good approach here.
>>> >> >     I think the discussion on the list about the stacks stopped
>>> about a
>>> >> >     month ago without a result, did it? The last mail seems to be
>>> from
>>> >> >     Pavel
>>> >> >     from 16.04.. He suggested some directions. Maybe you can create
>>> a plan
>>> >> >     based on that and post it to the list for further discussions.
>>> >> >     It would be good to do that soon so that the discussion can
>>> take place
>>> >> >     while you are still doing other things like setting up your
>>> hardware
>>> >> >     and
>>> >> >     the Linux test setup.
>>> >> >      > Is a JTAG setup for BBB needed or prints would be sufficient
>>> for
>>> >> >     debugging?
>>> >> >     Having a good debug solution is always useful in my experience.
>>> So if
>>> >> >     you have the possibility to set up a JTAG debugger, you should
>>> invest
>>> >> >     the time. Using prints could work in this project but it is
>>> >> >     definitively
>>> >> >     a inferior solution. Another possibility in this case could be
>>> >> >     libdebugger. But I have to say that I never used that myself
>>> because I
>>> >> >     always had a hardware debugger.
>>> >> >     Best regards
>>> >> >     Christian
>>> >> >      > Regards
>>> >> >      > Prashanth S
>>> >> >      > On Thu, 26 May 2022 at 21:33, Christian Mauderer
>>> >> >     <oss at c-mauderer.de <mailto:oss at c-mauderer.de>
>>> >> >      > <mailto:oss at c-mauderer.de <mailto:oss at c-mauderer.de>>>
>>> wrote:
>>> >> >      >     Hello Prashanth,
>>> >> >      >     Am 26.05.22 um 17:40 schrieb Prashanth S:
>>> >> >      >      > Hi Christian Mauderer,
>>> >> >      >      > Thank You.
>>> >> >      >      > Most of the time the RTEMS mailing list is quite
>>> informal and
>>> >> >      >     most of us
>>> >> >      >      > just use first names to address someone ("Christian"
>>> in my
>>> >> >     case). Is
>>> >> >      >      > that OK for you too? How do you prefer to be
>>> addressed?
>>> >> >      >      > Yes, no problem in calling me by first name
>>> (Prashanth).
>>> >> >      >      > Last years it always was a good idea to sort out time
>>> >> >     zones. You
>>> >> >      >      > mentioned that you are from India so you are most
>>> likely at
>>> >> >      >     UTC+5:30? Is
>>> >> >      >      > that correct? I'm in Germany and therefore my time is
>>> UTC+2
>>> >> >      >     during the
>>> >> >      >      > summer. That means that I sometimes forget at my
>>> evening
>>> >> >     that's
>>> >> >      >     already
>>> >> >      >      > late in the night for you. Please don't hesitate to
>>> just
>>> >> >     tell me
>>> >> >      >     that we
>>> >> >      >      > should continue a discussion on the next day if it
>>> starts
>>> >> >     to get too
>>> >> >      >      > late for you ;-)
>>> >> >      >      > Yes, my time zone is UTC +5:30.
>>> >> >      >      > Do you already have everything set up or do you
>>> >> >      >      > need some help with that? Maybe you can tell me
>>> roughly
>>> >> >     what hardware
>>> >> >      >      > you use? I would like to try to reproduce the setup
>>> here
>>> >> >     so that
>>> >> >      >     I can
>>> >> >      >      > test your software or help with debugging where
>>> necessary.
>>> >> >      >      > I have a BBB and Sn65Hvd230 Can Bus Transceiver. I am
>>> >> >     planning to
>>> >> >      >     buy
>>> >> >      >      > one more
>>> >> >      >      > BBB for testing CAN driver.
>>> >> >      >      > @oss at c-mauderer.de <mailto:oss at c-mauderer.de>
>>> >> >     <mailto:oss at c-mauderer.de <mailto:oss at c-mauderer.de>>> ,
>>> @Pavel Pisa
>>> >> >      >      > <mailto:ppisa4lists at pikron.com
>>> >> >     <mailto:ppisa4lists at pikron.com> <mailto:ppisa4lists at pikron.com
>>> >> >     <mailto:ppisa4lists at pikron.com>>> ,
>>> >> >      >     @Gedare Bloom <mailto:gedare at rtems.org
>>> >> >     <mailto:gedare at rtems.org> <mailto:gedare at rtems.org
>>> >> >     <mailto:gedare at rtems.org>>> .
>>> >> >      >      > How do you prefer to be addressed?
>>> >> >      >     Like I said: First name is OK. So just Christian.
>>> >> >      >      > I would like to start the programming part early.
>>> >> >      >     OK. You have a medium sized project. That means it's no
>>> full
>>> >> >     time. Do
>>> part
>>> >> >     time during
>>> >> >      >      > May I ask, what are the things I need to do before
>>> starting?
>>> >> >      >      > (Like, plan of the project, module design, creating a
>>> github
>>> >> >      >     repo, blog
>>> >> >      >      > posts)
>>> it?
>>> >> >      >     I would suggest to start with a blog early. It's nice if
>>> you
>>> >> >     create it
>>> >> >      >     more or less as a "diary" what you did. It maybe isn't a
>>> bad
>>> >> >     idea to
>>> >> >      >     plan for example about weekly posts as a preparation for
>>> the
>>> >> >      >     meetings on
>>> >> >      >     Discord. But you can also do posts every time you have a
>>> nice
>>> >> >      >     self-contained part of work or similar.
>>> >> >      >     I think you planned to test your hardware setup with
>>> Linux.
>>> >> >     So maybe a
>>> >> >      >     nice first post could be about your hardware setup and
>>> how it
>>> >> >     runs the
>>> >> >      >     Linux sample.
>>> >> >     stack you want
>>> >> >     driver. Pavel
>>> >> >     there was
>>> >> >      >     some
>>> >> >      >     final one selected?
>>> >> >      >     Setting up a GitHub Repo is also a good idea but you need
>>> >> >     something
>>> >> >      >     that
>>> >> >      >     you want to put there. Only cloning the RTEMS repo isn't
>>> >> >     really useful
>>> >> >      >     if you don't add patches.
>>> >> >      >     I tend to keep my working environment in a repository.
>>> If you
>>> >> >     want to
>>> >> >      >     use something like that, this might be a good starting
>>> point
>>> >> >     for a
>>> >> >      >     repository. Basically just some commands in scripts and
>>> makefiles
>>> >> >      >     together with demo applications and repositories pulled
>>> in as
>>> >> >      >     submodules. That makes it simple to reproduce a certain
>>> >> >     version. I
>>> >> >      >     would
>>> >> >      >     strongly suggest to create it yourself because then you
>>> know
>>> >> >     your way
>>> >> >      >     around it. But if you want, you can also take a look at
>>> what
>>> >> >     I use
>>> >> >      >     since
>>> >> >      >     some years for testing code from BBB-GSoC projects:
>>> >> >      > https://gitlab.com/c-mauderer/rtems-bbb
>>> >> >     <https://gitlab.com/c-mauderer/rtems-bbb>
>>> >> >     <https://gitlab.com/c-mauderer/rtems-bbb>>
>>> >> >      >     But like I said: Please think about starting something
>>> like
>>> >> >     that from
>>> >> >      >     scratch because you then know every line of it and where
>>> you
>>> >> >     have to
>>> >> >      >     change something.
>>> >> >      >     Best regards
>>> >> >      >     Christian
>>> >> >      >      > Regards
>>> >> >      >      > Prashanth S
>>> >> >      >      > On Thu, 26 May 2022 at 20:24, Christian Mauderer
>>> >> >     <mailto:oss at c-mauderer.de <mailto:oss at c-mauderer.de>>>> wrote:
>>> >> >      >      >     Hello Prashanth S,
>>> >> >      >      >     welcome to this years GSoC.
>>> >> >      >      >     I'm sure you have already seen that Pavel and I
>>> have been
>>> >> >      >     assigned as
>>> >> >      >      >     mentor to your project. Gedare is backup in case
>>> one
>>> >> >     or both
>>> >> >      >     of us are
>>> >> >      >      >     unavailable for some reason (which normally
>>> shouldn't
>>> >> >     be the
>>> >> >      >     case).
>>> >> >      >      >     Gedare already mentioned it in yesterdays
>>> meeting: We
>>> >> >     should
>>> >> >      >     try to
>>> >> >      >      >     communicate often. Don't hesitate to ask many
>>> questions if
>>> >> >      >     you get
>>> >> >      >      >     stuck. Don't worry whether a question might be to
>>> >> >     "easy". Asking
>>> >> >      >      >     them is
>>> >> >      >      >     the best way to learn the answer. Beneath that it
>>> >> >     helps me to
>>> >> >      >     keep
>>> >> >      >      >     up to
>>> >> >      >      >     date what are you doing and that makes it simpler
>>> to
>>> >> >     help you.
>>> >> >     informal and
>>> >> >      >     most
>>> >> >      >      >     of us
>>> ("Christian" in my
>>> >> >      >     case). Is
>>> addressed?
>>> >> >      >      >     We should try to find some common communication
>>> >> >     methods. In
>>> >> >      >     the best
>>> >> >      >      >     case you use public channels like the mailing
>>> list or
>>> >> >     the public
>>> >> >      >      >     Discord
>>> >> >      >      >     chat. But I know that it's sometimes a bit
>>> difficult
>>> >> >     to use
>>> >> >      >     these if
>>> >> >      >      >     you
>>> >> >      >      >     are new to open source projects. I still know how
>>> >> >     nervous I
>>> >> >      >     have been
>>> >> >      >      >     when I wrote my first mails to the list. So if you
>>> >> >     have some
>>> >> >      >     topics
>>> >> >      >      >     that
>>> >> >      >      >     you prefere to discuss private, you can always
>>> reach us by
>>> >> >      >     mail or
>>> >> >      >      >     private chat.
>>> >> >      >      >     I think Pavel isn't on Discord (Pavel: please
>>> correct
>>> >> >     me if
>>> >> >      >     I'm wrong).
>>> >> >      >      >     Discord isn't really known for their privacy
>>> friendly
>>> >> >      >     attitude so I can
>>> >> >      >      >     completely understand that. So at the moment the
>>> best
>>> >> >     method
>>> >> >      >     to reach
>>> >> >      >      >     all of us is most likely mail.
>>> >> >      >      >     My private mail address that I use for open source
>>> >> >     work is the
>>> >> >     <mailto:oss at c-mauderer.de <mailto:oss at c-mauderer.de>>>>. I
>>> check
>>> >> >      >     these mails
>>> >> >      >      >     at least once a day (most of
>>> >> >      >      >     the time more often). If you have something that
>>> has to be
>>> >> >      >     answered
>>> >> >      >      >     really fast, you might want to add my company
>>> mail address
>>> >> >      >      >     <christian.mauderer at embedded-brains.de
>>> >> >     <mailto:christian.mauderer at embedded-brains.de>
>>> >> >     <mailto:christian.mauderer at embedded-brains.de>>
>>> >> >     <mailto:christian.mauderer at embedded-brains.de>>>> to CC. You
>>> will find
>>> >> >      >      >     these two
>>> >> >      >      >     addresses on the mailing list too.
>>> >> >      >      >     Note that I have a mail filter that sorts mails
>>> from
>>> >> >     the list
>>> >> >      >     into
>>> >> >      >      >     folders. If you want to make sure that I read a
>>> mail
>>> >> >     on the
>>> >> >      >     list: Add
>>> >> >      >      >     one of my addresses to CC so that my filter keeps
>>> it
>>> >> >     in the
>>> >> >      >     inbox.
>>> >> >      >      >     That's a good idea for most people on the list:
>>> If you
>>> >> >     want
>>> >> >      >     someone
>>> >> >      >      >     special to answer something: Add him or her to
>>> CC. But
>>> >> >     please
>>> >> >      >     make sure
>>> >> >      >      >     that you only add addresses to CC that are
>>> already used in
>>> >> >      >     public.
>>> time
>>> >> >     zones. You
>>> >> >     likely at
>>> >> >      >      >     UTC+5:30? Is
>>> time is
>>> >> >     UTC+2
>>> >> >      >     during the
>>> evening
>>> >> >      >     that's already
>>> to
>>> >> >     just tell me
>>> >> >      >      >     that we
>>> >> >     starts to
>>> >> >      >     get too
>>> >> >      >      >     late for you ;-)
>>> >> >      >      >     I'm not entirely sure which time zones Pavel and
>>> >> >     Gedare have
>>> >> >      >     but I'm
>>> >> >      >      >     sure you will find out soon enough when you can
>>> reach
>>> >> >     every
>>> >> >      >     one of them.
>>> >> >      >      >     I think that's enough general information for the
>>> moment.
>>> >> >      >     Let's start a
>>> >> >      >      >     (short) technical part:
>>> >> >      >      >     I have to be honest: I haven't followed every
>>> mail on
>>> >> >     the list
>>> >> >      >      >     regarding
>>> >> >      >      >     your project during the last weeks. So maybe let
>>> me
>>> >> >     ask a bit
>>> >> >      >     about
>>> >> >      >      >     your
>>> >> >      >      >     current hardware setup: Do you already have
>>> everything
>>> >> >     set up
>>> >> >      >     or do you
>>> >> >     roughly what
>>> >> >      >     hardware
>>> setup
>>> >> >     here so
>>> >> >      >     that I can
>>> necessary.
>>> >> >      >      >     Best regards
>>> >> >      >      >     Christian
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220715/cc03c8df/attachment-0001.htm>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220715/cc03c8df/attachment-0001.bin>
