[PATCH] score: Restore previous behavior for system state
Kinsey Moore
kinsey.moore at oarcorp.com
Fri Jul 15 20:06:18 UTC 2022
Disregard this patch, I see Sebastian has already committed a different fix to the test itself.
Kinsey
-----Original Message-----
Sent: Friday, July 15, 2022 14:54
To: devel at rtems.org
Cc: Kinsey Moore <kinsey.moore at oarcorp.com>
Subject: [PATCH] score: Restore previous behavior for system state
Set system state before creating the idle threads. This fixes the
spextensions01 test since it expects this behavior.
cpukit/score/src/threadcreateidle.c | 3 ++-
1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/cpukit/score/src/threadcreateidle.c b/cpukit/score/src/threadcreateidle.c
index b5e0cfdc9b..dcd8ba0478 100644
--- a/cpukit/score/src/threadcreateidle.c
+++ b/cpukit/score/src/threadcreateidle.c
@@ -112,6 +112,8 @@ static void _Thread_Create_idle_for_CPU( Per_CPU_Control *cpu )
void _Thread_Create_idle( void )
+ _System_state_Set( SYSTEM_STATE_BEFORE_MULTITASKING );
#if defined(RTEMS_SMP)
uint32_t cpu_max;
uint32_t cpu_index;
@@ -132,5 +134,4 @@ void _Thread_Create_idle( void )
_CPU_Use_thread_local_storage(
&_Per_CPU_Get_executing( _Per_CPU_Get() )->Registers
- _System_state_Set( SYSTEM_STATE_BEFORE_MULTITASKING );
2.30.2
