Fwd: [rtems-bsp-builder] 2022-07-16 06:31:12: Profile(s): everything
Sun Jul 17 14:30:50 UTC 2022
Various failures which appear to be consistent across Ubuntu and FreeBSD
12/13.
+ Some tests must now be too big
+ Microblaze linking issue.
+ Odd risc-v link issue
Hint Alex.. I need the Microblaze patch to push. :)
--joel
---------- Forwarded message ---------
Date: Sat, Jul 16, 2022, 8:24 PM
Subject: [rtems-bsp-builder] 2022-07-16 06:31:12: Profile(s): everything
To: <build at rtems.org>
RTEMS Tools Project - RTEMS Kernel BSP Builder, 6.0.not_released
Host: #55-Ubuntu SMP Wed Jan 12 17:36:34 UTC 2022
command: /home/tester/rtems-cron-6/tools/6/bin/rtems-bsp-builder\
         --rtems=/home/tester/rtems-cron-6/rtems --build-path=/home/tester\
         /rtems-cron-6/build --prefix=/home/tester/rtems-\
         cron-6/tools/6/bsps --log=/home/tester/rtems-cron-6/bsp-\
         builder.log --warnings-report=warnings.log --mail --use-gitconfig\
         --profiles=everything
Total Time            : 4:30:43.646599 for 1260 completed job(s)
Average BSP Build Time: 0:00:12.891783
Builds
 debug
 no-posix
 posix
 posix-debug
 posix-profiling
 profiling
 smp
 smp-debug
Failures Report
   1 debug arm/lm4f120 build:
      configure: /home/tester/rtems-cron-6/rtems/waf configure\
      --prefix=/home/tester/rtems-cron-6/tools/6/bsps --top=/home/tester\
      /rtems-cron-6/rtems --rtems-config=config-arm-lm4f120-debug.ini
     error: home/tester/rtems-cron-6/tools/6/arm-
            rtems6/bin/ld:linkcmds.base:348 cannot move location counter
            backwards (from 0000000020008170 to 0000000020008000)
     error: ld/collect2:0 error: linkcmds.base:348 cannot move location
            counter backwards (from 0000000020008170 to 0000000020008000)
   2 posix arm/lm4f120 build:
      /rtems-cron-6/rtems --rtems-config=config-arm-lm4f120-posix.ini
            backwards (from 0000000020008820 to 0000000020008000)
            counter backwards (from 0000000020008820 to 0000000020008000)
   3 posix-debug arm/lm4f120 build:
      /rtems-cron-6/rtems --rtems-config=config-arm-lm4f120-posix-\
      debug.ini
            backwards (from 00000000200089f8 to 0000000020008000)
            counter backwards (from 00000000200089f8 to 0000000020008000)
   4 posix-profiling arm/lm4f120 build:
      profiling.ini
            backwards (from 0000000020008860 to 0000000020008000)
            counter backwards (from 0000000020008860 to 0000000020008000)
   5 posix arm/lpc1768_mbed build:
      /rtems-cron-6/rtems --rtems-config=config-arm-lpc1768_mbed-posix.ini
            backwards (from 00000000100086a0 to 0000000010008000)
            counter backwards (from 00000000100086a0 to 0000000010008000)
   6 posix-debug arm/lpc1768_mbed build:
      /rtems-cron-6/rtems --rtems-config=config-arm-lpc1768_mbed-posix-\
      debug.ini
            backwards (from 0000000010008878 to 0000000010008000)
            counter backwards (from 0000000010008878 to 0000000010008000)
   7 posix-profiling arm/lpc1768_mbed build:
      profiling.ini
            backwards (from 00000000100086c0 to 0000000010008000)
            counter backwards (from 00000000100086c0 to 0000000010008000)
   8 debug arm/lpc1768_mbed_ahb_ram_eth build:
      /rtems-cron-6/rtems --rtems-config=config-arm-\
      lpc1768_mbed_ahb_ram_eth-debug.ini
            backwards (from 0000000020081850 to 0000000020080000)
            counter backwards (from 0000000020081850 to 0000000020080000)
   9 no-posix arm/lpc1768_mbed_ahb_ram_eth build:
      lpc1768_mbed_ahb_ram_eth-no-posix.ini
            backwards (from 00000000200816b8 to 0000000020080000)
            counter backwards (from 00000000200816b8 to 0000000020080000)
  10 posix arm/lpc1768_mbed_ahb_ram_eth build:
      lpc1768_mbed_ahb_ram_eth-posix.ini
            backwards (from 0000000020081f40 to 0000000020080000)
            counter backwards (from 0000000020081f40 to 0000000020080000)
  11 posix-debug arm/lpc1768_mbed_ahb_ram_eth build:
      lpc1768_mbed_ahb_ram_eth-posix-debug.ini
            backwards (from 00000000200820d8 to 0000000020080000)
            counter backwards (from 00000000200820d8 to 0000000020080000)
  12 posix-profiling arm/lpc1768_mbed_ahb_ram_eth build:
      lpc1768_mbed_ahb_ram_eth-posix-profiling.ini
  13 profiling arm/lpc1768_mbed_ahb_ram_eth build:
      lpc1768_mbed_ahb_ram_eth-profiling.ini
  14 posix arm/lpc2362 build:
      /rtems-cron-6/rtems --rtems-config=config-arm-lpc2362-posix.ini
            backwards (from 0000000040008580 to 0000000040008000)
            counter backwards (from 0000000040008580 to 0000000040008000)
  15 posix-debug arm/lpc2362 build:
      /rtems-cron-6/rtems --rtems-config=config-arm-lpc2362-posix-\
      debug.ini
            backwards (from 0000000040008758 to 0000000040008000)
            counter backwards (from 0000000040008758 to 0000000040008000)
  16 posix-profiling arm/lpc2362 build:
      profiling.ini
            backwards (from 00000000400085c0 to 0000000040008000)
            counter backwards (from 00000000400085c0 to 0000000040008000)
  17 posix arm/lpc23xx_tli800 build:
      lpc23xx_tli800-posix.ini
  18 posix-debug arm/lpc23xx_tli800 build:
      /rtems-cron-6/rtems --rtems-config=config-arm-lpc23xx_tli800-posix-\
      debug.ini
  19 posix-profiling arm/lpc23xx_tli800 build:
      profiling.ini
  20 debug microblaze/kcu105 build:
      /rtems-cron-6/rtems --rtems-config=config-microblaze-\
      kcu105-debug.ini
     error: ld/collect2:0 error: linkcmds:36: syntax error
     error: home/tester/rtems-cron-6/tools/6/microblaze-
            rtems6/bin/ld:linkcmds:36: syntax error
  21 no-posix microblaze/kcu105 build:
      /rtems-cron-6/rtems --rtems-config=config-microblaze-kcu105-no-\
      posix.ini
  22 posix microblaze/kcu105 build:
      kcu105-posix.ini
  23 posix-debug microblaze/kcu105 build:
      /rtems-cron-6/rtems --rtems-config=config-microblaze-kcu105-posix-\
      debug.ini
  24 posix-profiling microblaze/kcu105 build:
      profiling.ini
  25 profiling microblaze/kcu105 build:
      kcu105-profiling.ini
  26 debug microblaze/kcu105_qemu build:
      /rtems-cron-6/rtems --rtems-config=config-microblaze-kcu105_qemu-\
      debug.ini
  27 no-posix microblaze/kcu105_qemu build:
      /rtems-cron-6/rtems --rtems-config=config-microblaze-kcu105_qemu-no-\
      posix.ini
  28 posix microblaze/kcu105_qemu build:
      posix.ini
  29 posix-debug microblaze/kcu105_qemu build:
      posix-debug.ini
  30 posix-profiling microblaze/kcu105_qemu build:
      posix-profiling.ini
  31 profiling microblaze/kcu105_qemu build:
      profiling.ini
Warnings Report
 | By Architecture (total : 11512)                                     |
 | common : 23 warning(s)                                              |
 |   Shared :  606 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :    0 | CPU Kit :  994 |                |                 |
 | aarch64 : 0 warning(s)                                              |
 | arm : 29 warning(s)                                                 |
 |   Shared :  162 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :    0 | CPU Kit :  222 |                |                 |
 | bfin : 32 warning(s)                                                |
 |   Shared :  126 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :  234 | CPU Kit :   90 |                |                 |
 | i386 : 32 warning(s)                                                |
 |   Shared :    0 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :    0 | CPU Kit :  276 |                |                 |
 | lm32 : 14 warning(s)                                                |
 |   Shared :  156 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :    0 | CPU Kit :   72 |                |                 |
 | m68k : 33 warning(s)                                                |
 |   Shared :  876 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :    0 | CPU Kit : 1050 |                |                 |
 | microblaze : 0 warning(s)                                           |
 | mips : 8 warning(s)                                                 |
 |   LibCPU :    0 | CPU Kit :   54 |                |                 |
 | moxie : 2 warning(s)                                                |
 |   Shared :   20 |     BSP :    0 | Network :    0 |    Tests :    0 |
 | nios2 : 0 warning(s)                                                |
 | or1k : 1 warning(s)                                                 |
 |   Shared :    6 |     BSP :    0 | Network :    0 |    Tests :    0 |
 | powerpc : 28 warning(s)                                             |
 |   Shared :  116 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :   12 | CPU Kit :  380 |                |                 |
 | riscv : 0 warning(s)                                                |
 | sh : 162 warning(s)                                                 |
 |   Shared :   56 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :    0 | CPU Kit :   84 |                |                 |
 | sparc : 4 warning(s)                                                |
 |   LibCPU :    0 | CPU Kit :    6 |                |                 |
 | sparc64 : 2 warning(s)                                              |
 |   Shared :   28 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :    0 | CPU Kit :    0 |                |                 |
 | v850 : 1 warning(s)                                                 |
 |   Shared :   48 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :    0 | CPU Kit :   36 |                |                 |
 | x86_64 : 1 warning(s)                                               |
 | By BSP (total : 11512)                                              |
 | common : 280 warning(s)                                             |
 |   Shared : 1358 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :   96 | CPU Kit : 2126 |                |                 |
 | aarch64/xilinx_zynqmp_ilp32_qemu : 0 warning(s)                     |
 | aarch64/xilinx_zynqmp_ilp32_zu3eg : 0 warning(s)                    |
 | aarch64/xilinx_zynqmp_lp64_qemu : 0 warning(s)                      |
 | aarch64/xilinx_zynqmp_lp64_zu3eg : 0 warning(s)                     |
 | arm/altcycv_devkit : 7 warning(s)                                   |
 |   LibCPU :    0 | CPU Kit :    2 |                |                 |
 | arm/atsamv : 2 warning(s)                                           |
 | arm/beagleboardorig : 0 warning(s)                                  |
 | arm/beagleboardxm : 0 warning(s)                                    |
 | arm/beagleboneblack : 0 warning(s)                                  |
 | arm/beaglebonewhite : 0 warning(s)                                  |
 | arm/csb336 : 0 warning(s)                                           |
 | arm/csb337 : 0 warning(s)                                           |
 | arm/csb637 : 0 warning(s)                                           |
 | arm/gumstix : 0 warning(s)                                          |
 | arm/imx7 : 2 warning(s)                                             |
 |   LibCPU :    0 | CPU Kit :   34 |                |                 |
 | arm/imxrt1052 : 0 warning(s)                                        |
 | arm/kit637_v6 : 0 warning(s)                                        |
 | arm/lm3s3749 : 0 warning(s)                                         |
 | arm/lm3s6965 : 0 warning(s)                                         |
 | arm/lm3s6965_qemu : 0 warning(s)                                    |
 | arm/lm4f120 : 0 warning(s)                                          |
 | arm/lpc1768_mbed : 0 warning(s)                                     |
 | arm/lpc1768_mbed_ahb_ram : 0 warning(s)                             |
 | arm/lpc1768_mbed_ahb_ram_eth : 0 warning(s)                         |
 | arm/lpc17xx_ea_ram : 0 warning(s)                                   |
 | arm/lpc17xx_ea_rom_int : 0 warning(s)                               |
 | arm/lpc17xx_plx800_ram : 0 warning(s)                               |
 | arm/lpc17xx_plx800_rom_int : 0 warning(s)                           |
 | arm/lpc2362 : 0 warning(s)                                          |
 | arm/lpc23xx_tli800 : 0 warning(s)                                   |
 | arm/lpc24xx_ea : 0 warning(s)                                       |
 | arm/lpc24xx_ncs_ram : 0 warning(s)                                  |
 | arm/lpc24xx_ncs_rom_ext : 0 warning(s)                              |
 | arm/lpc24xx_ncs_rom_int : 0 warning(s)                              |
 | arm/lpc24xx_plx800_ram : 0 warning(s)                               |
 | arm/lpc24xx_plx800_rom_int : 0 warning(s)                           |
 | arm/lpc32xx_mzx : 0 warning(s)                                      |
 | arm/lpc32xx_mzx_stage_1 : 0 warning(s)                              |
 | arm/lpc32xx_mzx_stage_2 : 0 warning(s)                              |
 | arm/lpc32xx_phycore : 0 warning(s)                                  |
 | arm/lpc40xx_ea_ram : 0 warning(s)                                   |
 | arm/lpc40xx_ea_rom_int : 0 warning(s)                               |
 | arm/nucleo-h743zi : 0 warning(s)                                    |
 | arm/raspberrypi : 0 warning(s)                                      |
 | arm/raspberrypi2 : 0 warning(s)                                     |
 | arm/realview_pbx_a9_qemu : 0 warning(s)                             |
 | arm/smdk2410 : 0 warning(s)                                         |
 | arm/stm32f105rc : 0 warning(s)                                      |
 | arm/stm32f4 : 2 warning(s)                                          |
 | arm/stm32h7 : 0 warning(s)                                          |
 | arm/tms570ls3137_hdk : 0 warning(s)                                 |
 | arm/tms570ls3137_hdk_intram : 0 warning(s)                          |
 | arm/tms570ls3137_hdk_sdram : 0 warning(s)                           |
 | arm/tms570ls3137_hdk_with_loader : 0 warning(s)                     |
 | arm/xilinx_zynq_a9_qemu : 0 warning(s)                              |
 | arm/xilinx_zynq_zc702 : 0 warning(s)                                |
 | arm/xilinx_zynq_zc706 : 0 warning(s)                                |
 | arm/xilinx_zynq_zedboard : 0 warning(s)                             |
 | arm/xilinx_zynqmp_ultra96 : 1 warning(s)                            |
 | bfin/TLL6527M : 11 warning(s)                                       |
 |   Shared :   38 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :  138 | CPU Kit :   30 |                |                 |
 | bfin/bf537Stamp : 0 warning(s)                                      |
 | bfin/eZKit533 : 0 warning(s)                                        |
 | i386/pc386 : 0 warning(s)                                           |
 | i386/pc486 : 0 warning(s)                                           |
 | i386/pc586 : 0 warning(s)                                           |
 | i386/pc586-sse : 0 warning(s)                                       |
 | i386/pc686 : 0 warning(s)                                           |
 | i386/pcp4 : 0 warning(s)                                            |
 | lm32/lm32_evr : 0 warning(s)                                        |
 | lm32/lm32_evr_gdbsim : 0 warning(s)                                 |
 | lm32/milkymist : 12 warning(s)                                      |
 |   Shared :   96 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :    0 | CPU Kit :   24 |                |                 |
 | m68k/COBRA5475 : 0 warning(s)                                       |
 | m68k/av5282 : 0 warning(s)                                          |
 | m68k/csb360 : 0 warning(s)                                          |
 | m68k/gen68340 : 0 warning(s)                                        |
 | m68k/gen68360 : 2 warning(s)                                        |
 |   Shared :   14 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :    0 | CPU Kit :   48 |                |                 |
 | m68k/gen68360_040 : 0 warning(s)                                    |
 | m68k/m5484FireEngine : 3 warning(s)                                 |
 |   Shared :   66 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :    0 | CPU Kit :   60 |                |                 |
 | m68k/mcf5206elite : 1 warning(s)                                    |
 |   Shared :   74 |     BSP :    0 | Network :    0 |    Tests :    0 |
 | m68k/mcf52235 : 3 warning(s)                                        |
 | m68k/mcf5225x : 3 warning(s)                                        |
 | m68k/mcf5235 : 1 warning(s)                                         |
 | m68k/mcf5329 : 3 warning(s)                                         |
 | m68k/mrm332 : 0 warning(s)                                          |
 | m68k/mvme147 : 0 warning(s)                                         |
 | m68k/mvme147s : 0 warning(s)                                        |
 | m68k/mvme162 : 0 warning(s)                                         |
 | m68k/mvme162lx : 0 warning(s)                                       |
 | m68k/mvme167 : 0 warning(s)                                         |
 | m68k/pgh360 : 0 warning(s)                                          |
 | m68k/uC5282 : 6 warning(s)                                          |
 | microblaze/kcu105 : 0 warning(s)                                    |
 | microblaze/kcu105_qemu : 0 warning(s)                               |
 | mips/hurricane : 1 warning(s)                                       |
 | mips/malta : 6 warning(s)                                           |
 | mips/rbtx4938 : 1 warning(s)                                        |
 | moxie/moxiesim : 2 warning(s)                                       |
 | nios2/nios2_iss : 0 warning(s)                                      |
 | or1k/generic_or1k : 1 warning(s)                                    |
 | powerpc/beatnik : 2 warning(s)                                      |
 |   LibCPU :   12 | CPU Kit :    6 |                |                 |
 | powerpc/br_uid : 0 warning(s)                                       |
 | powerpc/gwlcfm : 0 warning(s)                                       |
 | powerpc/hsc_cm01 : 0 warning(s)                                     |
 | powerpc/icecube : 0 warning(s)                                      |
 | powerpc/mcp750 : 0 warning(s)                                       |
 | powerpc/mpc5566evb : 0 warning(s)                                   |
 | powerpc/mpc5643l_evb : 0 warning(s)                                 |
 | powerpc/mpc5668g : 0 warning(s)                                     |
 | powerpc/mpc5674fevb : 0 warning(s)                                  |
 | powerpc/mpc8260ads : 0 warning(s)                                   |
 | powerpc/mpc8309som : 0 warning(s)                                   |
 | powerpc/mpc8313erdb : 0 warning(s)                                  |
 | powerpc/mpc8349eamds : 0 warning(s)                                 |
 | powerpc/mtx603e : 0 warning(s)                                      |
 | powerpc/mvme2100 : 0 warning(s)                                     |
 | powerpc/mvme2307 : 0 warning(s)                                     |
 | powerpc/mvme3100 : 1 warning(s)                                     |
 |   Shared :    8 |     BSP :    0 | Network :    0 |    Tests :    0 |
 | powerpc/mvme5500 : 2 warning(s)                                     |
 | powerpc/pghplus : 0 warning(s)                                      |
 | powerpc/phycore_mpc5554 : 0 warning(s)                              |
 | powerpc/pm520_cr825 : 0 warning(s)                                  |
 | powerpc/pm520_ze30 : 0 warning(s)                                   |
 | powerpc/psim : 1 warning(s)                                         |
 | powerpc/qemuppc : 1 warning(s)                                      |
 | powerpc/qemuprep : 0 warning(s)                                     |
 | powerpc/qemuprep-altivec : 0 warning(s)                             |
 | powerpc/qoriq_core_0 : 0 warning(s)                                 |
 | powerpc/qoriq_core_1 : 0 warning(s)                                 |
 | powerpc/qoriq_e500 : 0 warning(s)                                   |
 | powerpc/qoriq_e6500_32 : 0 warning(s)                               |
 | powerpc/qoriq_e6500_64 : 6 warning(s)                               |
 |   Shared :   24 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :    0 | CPU Kit :  114 |                |                 |
 | powerpc/ss555 : 2 warning(s)                                        |
 | powerpc/t32mppc : 2 warning(s)                                      |
 |   LibCPU :    0 | CPU Kit :   42 |                |                 |
 | powerpc/tqm8xx_stk8xx : 0 warning(s)                                |
 | powerpc/virtex : 0 warning(s)                                       |
 | powerpc/virtex4 : 0 warning(s)                                      |
 | powerpc/virtex5 : 0 warning(s)                                      |
 | riscv/griscv : 0 warning(s)                                         |
 | riscv/grv32imac : 0 warning(s)                                      |
 | riscv/grv32imafdc : 0 warning(s)                                    |
 | riscv/rv32iac : 0 warning(s)                                        |
 | riscv/rv32imac : 0 warning(s)                                       |
 | riscv/rv32imafc : 0 warning(s)                                      |
 | riscv/rv32imafd : 0 warning(s)                                      |
 | riscv/rv32imafdc : 0 warning(s)                                     |
 | riscv/rv64imac : 0 warning(s)                                       |
 | riscv/rv64imac_medany : 0 warning(s)                                |
 | riscv/rv64imafd : 0 warning(s)                                      |
 | riscv/rv64imafd_medany : 0 warning(s)                               |
 | riscv/rv64imafdc : 0 warning(s)                                     |
 | riscv/rv64imafdc_medany : 0 warning(s)                              |
 | sh/gensh1 : 1 warning(s)                                            |
 |   LibCPU :    0 | CPU Kit :   12 |                |                 |
 | sh/gensh2 : 1 warning(s)                                            |
 | sh/gensh4 : 1 warning(s)                                            |
 | sh/simsh1 : 0 warning(s)                                            |
 | sh/simsh2 : 0 warning(s)                                            |
 | sh/simsh2e : 0 warning(s)                                           |
 | sh/simsh4 : 0 warning(s)                                            |
 | sparc/at697f : 0 warning(s)                                         |
 | sparc/gr712rc : 0 warning(s)                                        |
 | sparc/gr740 : 0 warning(s)                                          |
 | sparc/leon2 : 0 warning(s)                                          |
 | sparc/leon3 : 0 warning(s)                                          |
 | sparc/ut699 : 0 warning(s)                                          |
 | sparc/ut700 : 0 warning(s)                                          |
 | sparc64/niagara : 0 warning(s)                                      |
 | sparc64/usiii : 1 warning(s)                                        |
 | v850/v850e1sim : 0 warning(s)                                       |
 | v850/v850e2sim : 0 warning(s)                                       |
 | v850/v850e2v3sim : 0 warning(s)                                     |
 | v850/v850esim : 0 warning(s)                                        |
 | v850/v850essim : 0 warning(s)                                       |
 | v850/v850sim : 0 warning(s)                                         |
 | x86_64/amd64 : 1 warning(s)                                         |
 | By Build (total : 11512)                                            |
 | common : 370 warning(s)                                             |
 |   Shared : 1294 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :  205 | CPU Kit : 2446 |                |                 |
 | debug : 2 warning(s)                                                |
 |   Shared :  202 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :   41 | CPU Kit :  407 |                |                 |
 | no-posix : 0 warning(s)                                             |
 | posix-debug : 0 warning(s)                                          |
 | posix-profiling : 0 warning(s)                                      |
 | smp : 0 warning(s)                                                  |
 | smp-debug : 0 warning(s)                                            |
build mailing list
build at rtems.org
http://lists.rtems.org/mailman/listinfo/build
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220717/1a6ddeca/attachment-0001.htm>
