[PATCH v1 4/5] libtests/dl*: Bump up the size of CONFIGURE_INIT_TASK_STACK_SIZE
Ryan Long ryan.long at oarcorp.com
Wed Jul 20 21:36:32 UTC 2022
Updates #4682
 testsuites/libtests/dl01/init.c     | 2 +-
 testsuites/libtests/dl02/init.c     | 2 +-
 testsuites/libtests/dl03/init.c     | 2 +-
 testsuites/libtests/dl04/init.c     | 2 +-
 testsuites/libtests/dl05/init.c     | 2 +-
 testsuites/libtests/dl06/initimpl.h | 2 +-
 testsuites/libtests/dl07/init.c     | 2 +-
 testsuites/libtests/dl08/init.c     | 2 +-
 testsuites/libtests/dl09/init.c     | 2 +-
 testsuites/libtests/dl10/init.c     | 2 +-
 10 files changed, 10 insertions(+), 10 deletions(-)
diff --git a/testsuites/libtests/dl01/init.c b/testsuites/libtests/dl01/init.c
index 59cf3147f0..06fa8004b8 100644
--- a/testsuites/libtests/dl01/init.c
+++ b/testsuites/libtests/dl01/init.c
@@ -94,7 +94,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
-#define CONFIGURE_INIT_TASK_STACK_SIZE (8U * 1024U)
+#define CONFIGURE_INIT_TASK_STACK_SIZE (CONFIGURE_MINIMUM_TASK_STACK_SIZE + (4U * 1024U))
 #define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
diff --git a/testsuites/libtests/dl02/init.c b/testsuites/libtests/dl02/init.c
index 19563e9093..495a58d287 100644
--- a/testsuites/libtests/dl02/init.c
+++ b/testsuites/libtests/dl02/init.c
 #define CONFIGURE_INIT_TASK_ATTRIBUTES   (RTEMS_DEFAULT_ATTRIBUTES | RTEMS_FLOATING_POINT)
diff --git a/testsuites/libtests/dl03/init.c b/testsuites/libtests/dl03/init.c
index 5080323c05..e953f1a4c6 100644
--- a/testsuites/libtests/dl03/init.c
+++ b/testsuites/libtests/dl03/init.c
@@ -80,7 +80,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/libtests/dl04/init.c b/testsuites/libtests/dl04/init.c
index a733d9da14..54a852800d 100644
--- a/testsuites/libtests/dl04/init.c
+++ b/testsuites/libtests/dl04/init.c
diff --git a/testsuites/libtests/dl05/init.c b/testsuites/libtests/dl05/init.c
index 93d69578f7..7e34af757d 100644
--- a/testsuites/libtests/dl05/init.c
+++ b/testsuites/libtests/dl05/init.c
@@ -96,7 +96,7 @@ static void Init(rtems_task_argument arg)
-#define CONFIGURE_INIT_TASK_STACK_SIZE (32U * 1024U)
+#define CONFIGURE_INIT_TASK_STACK_SIZE (36U * 1024U)
diff --git a/testsuites/libtests/dl06/initimpl.h b/testsuites/libtests/dl06/initimpl.h
index 66e503b156..0d3987983d 100644
--- a/testsuites/libtests/dl06/initimpl.h
+++ b/testsuites/libtests/dl06/initimpl.h
@@ -98,7 +98,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/libtests/dl07/init.c b/testsuites/libtests/dl07/init.c
index 42b3bed3fc..8db106ba29 100644
--- a/testsuites/libtests/dl07/init.c
+++ b/testsuites/libtests/dl07/init.c
@@ -100,7 +100,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/libtests/dl08/init.c b/testsuites/libtests/dl08/init.c
index 02f999e0c6..23ebe41d63 100644
--- a/testsuites/libtests/dl08/init.c
+++ b/testsuites/libtests/dl08/init.c
diff --git a/testsuites/libtests/dl09/init.c b/testsuites/libtests/dl09/init.c
index e8caf9b6e8..b375fe3f38 100644
--- a/testsuites/libtests/dl09/init.c
+++ b/testsuites/libtests/dl09/init.c
diff --git a/testsuites/libtests/dl10/init.c b/testsuites/libtests/dl10/init.c
index 2a23bd3d15..04f71eaaba 100644
--- a/testsuites/libtests/dl10/init.c
+++ b/testsuites/libtests/dl10/init.c
@@ -148,7 +148,7 @@ static void Init(rtems_task_argument arg)
2.30.2
