[RSB 1/3] 6/7: Update Newlib
Thu Jul 21 05:21:18 UTC 2022
On 20.07.22 22:52, Chris Johns wrote:
> On 20/7/2022 6:20 pm, Sebastian Huber wrote:
>> On 20/07/2022 10:11, Chris Johns wrote:
>>>>> Are these TLS allocations in newlib based on a single use of a newlib call that
>>>>> brings in the reent stuff? How does that work?
>>>> No, each TLS object is defined in the translation unit which uses the object.
>>>> The goal is to get only those objects linked in which are needed. Currently, the
>>>> Newlib thread delete hook pulls in some objects, however, this dependency will
>>>> go away once the TLS destructors are implemented.
>>> If I have task A and it opens a file and writes something to a file system will
>>> it pull in the TLS support for files?
>> Yes.
>>> Given the TLS support is static does this mean all threads in the A app allocate
>>> the newlib file TLS variables even if they never use newlib?
>> Yes.
>>> My understanding of the existing reent support is tasks that do not use newlib
>>> it never allocate a reent struct?
>> No, the struct _reent is allocated for all tasks if you don't use
>> CONFIGURE_DISABLE_NEWLIB_REENTRANCY (which is not recommended). How would you
>> know if a task doesn't use Newlib?
> I thought the get would do a check and then allocate on first use. It has been
> many years since I looked at the implementation.
> I think this change is a good one because it will reduce the needed memory to
> the amount used and it will have better performance.
> I think option you post is a good thing to add, maybe as
> --enable-newlib-reent-tls. What will be the default?
You mean a proper sb-set-builder option and not just a
--with-newlib-tls? I would make it the default for the targets with
known to work TLS support: aarch64, arm, nios2, powerpc, riscv, and
sparc. For m68k we have a GCC code generation issue currently.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
