[PATCH] Arm/raspberrypi.h: Added relevant headers for the bcm2711
Alan Cudmore
alan.cudmore at gmail.com
Fri Jul 22 02:59:09 UTC 2022
Joel, I don't think we need to commit the file now.
Some suggestions:
- Let's not put RPI2 or RPI3 defines or ifdefs in the file if it's only
going to be for the Aarch64 RPI4 BSP
- If it will be only used for the RPI4, it might be confusing to have the
BCM2836 defines rather than using BCM2711
- If we really can share most of the defines between the RPI2 and RPI4
bsps, is there any way we can have a common include in the bsps/shared
directory? Something like bcm_soc.h that has common defines for all
raspberry Pi models? That would require changes to the Raspberry Pi 1 and 2
BSPs but it would avoid duplication of code.
I also wonder if we can end up taking advantage of shared drivers such as
the pl011 serial driver.
Another source of info that may be helpful is the RT-Thread RTOS. They have
RPI 2, 3, and 4 BSPs. The RPI4 has 32 and 64 bit versions. In addition the
RTOS is Apache 2.0 licensed, so that may be easier to re-use (Please
correct me if I'm wrong on the license usage!)
https://github.com/RT-Thread/rt-thread/tree/master/bsp/raspberry-pi/raspi4-64
Thanks,
Alan
On Thu, Jul 21, 2022 at 2:01 PM Joel Sherrill <joel at rtems.org> wrote:
> On Thu, Jul 21, 2022 at 12:32 PM Noor Aman <nooraman5718 at gmail.com> wrote:
>> I dont think this would be visible to any other application until or
>> unless user explicitly include this header 'raspberrypi.h' in their
>> application. And as of now, this header is only placed in
>> bsps/arm/raspberrypi/includes.
> Sorry. My mistake. I was thinking it was in bsp.h. :(
>> For my project I'm thinking of using this header with my project with
>> bcm2711 addresses included. For my project, this header will go under
>> bsps/aarch64/raspberrypi/includes. So I don't think this will create any
>> problem for other BSPs.
> This will be ok. A file has to explicitly include it.
> If you think it is ready to commit, I'm happy to do it if Alan or someone
> else also acks.
> --joel
>> On Thu, Jul 21, 2022, 10:16 PM Joel Sherrill <joel at rtems.org> wrote:
>>> This looks generally ok but is all this visible to any application that
>>> includes bsp.h?
>>> It might all need to be moved into a separate header to avoid
>>> contaminating everyone's namespace.
>>> On Thu, Jul 21, 2022, 10:56 AM Noor Aman <nooraman5718 at gmail.com> wrote:
>>>> A brief gist of what i found compatible with the older code
>>>> ---COMPATIBLE HEADER---
>>>> - BCM2835 timer
>>>> - GPIO
>>>> - AUX
>>>> - GPU timer
>>>> ---DIDNT CHECK---
>>>> - SPI
>>>> - I2C
>>>> ---MINOR CHNAGE---
>>>> - IRQ
>>>> - FIQ
>>>> ---NOT SURE ABOUT---
>>>> - Watchdog
>>>> - Power management
>>>> - Mailbox register
>>>> I didnt get any info about power management or watchdog or mailboxes.
>>>> (It isnt in the BCM2835 Documention too I think??)
>>>> And to answer your question Alan about if the Aarch64 would require a
>>>> DTB or not which you asked me quite earlier. I can say now, you dont,
>>>> because every address is defined here already so no need for the DTB.
>>>> diff --git a/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
>>>> b/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
>>>> index eeb48c42f1..a4ed2a01d1 100644
>>>> --- a/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
>>>> +++ b/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
>>>> @@ -52,15 +52,23 @@
>>>> -#if (BSP_IS_RPI2 == 1)
>>>> - #define RPI_PERIPHERAL_BASE 0x3F000000
>>>> +#if (RPI_BSP == RPI2)
>>>> + #define RPI_PERIPHERAL_BASE 0X3F000000
>>>> #define BASE_OFFSET 0X3F000000
>>>> +#elif (RPI_BSP == RPI4)
>>>> + #define RPI_PERIPHERAL_BASE 0xFE000000
>>>> + #define BASE_OFFSET 0xFE000000
>>>> + #define RPI_PERIPHERAL_SIZE 0x01800000
>>>> #else
>>>> #define RPI_PERIPHERAL_BASE 0x20000000
>>>> #define BASE_OFFSET 0X5E000000
>>>> #endif
>>>> -#define RPI_PERIPHERAL_SIZE 0x01000000
>>>> +#ifndef RPI_PERIPHERAL_SIZE
>>>> +#define RPI_PERIPHERAL_SIZE 0x01000000
>>>> * @name Bus to Physical address translation
>>>> @@ -543,6 +551,188 @@
>>>> #define BCM2836_IRQ_SOURCE_PMU 0x00000200
>>>> #define BCM2836_IRQ_SOURCE_LOCAL_TIMER 0x00000800
>>>> + * @name Raspberry Pi 4 ARM_LOCAL registers
>>>> +#define BCM2711_LOCAL_REGS_BASE 0x4C0000000
>>>> +#define BCM2711_LOCAL_ARM_CONTROL (BCM2711_LOCAL_REGS_BASE + 0x00)
>>>> +#define BCM2711_LOCAL_CORE_IRQ_CONTROL (BCM2711_LOCAL_REGS_BASE + 0x0c)
>>>> +#define BCM2711_LOCAL_PMU_CONTROL_SET (BCM2711_LOCAL_REGS_BASE + 0x10)
>>>> +#define BCM2711_LOCAL_PMU_CONTROL_CLR (BCM2711_LOCAL_REGS_BASE + 0x14)
>>>> +#define BCM2711_LOCAL_PERI_IRQ_ROUTE0 (BCM2711_LOCAL_REGS_BASE + 0x24)
>>>> +#define BCM2711_LOCAL_AXI_QUIET_TIME (BCM2711_LOCAL_REGS_BASE + 0x30)
>>>> +#define BCM2711_LOCAL_LOCAL_TIMER_CONTROL (BCM2711_LOCAL_REGS_BASE +
>>>> 0x34)
>>>> +#define BCM2711_LOCAL_LOCAL_TIMER_IRQ (BCM2711_LOCAL_REGS_BASE +
>>>> 0x38)
>>>> +#define BCM2711_LOCAL_TIMER_CNTRL0 (BCM2711_LOCAL_REGS_BASE +
>>>> 0x40)
>>>> +#define BCM2711_LOCAL_TIMER_CNTRL1 (BCM2711_LOCAL_REGS_BASE + 0x44)
>>>> +#define BCM2711_LOCAL_TIMER_CNTRL2 (BCM2711_LOCAL_REGS_BASE + 0x48)
>>>> +#define BCM2711_LOCAL_TIMER_CNTRL3 (BCM2711_LOCAL_REGS_BASE + 0x4c)
>>>> +#define BCM2711_LOCAL_MAILBOX_CNTRL0 (BCM2711_LOCAL_REGS_BASE + 0x50)
>>>> +#define BCM2711_LOCAL_MAILBOX_CNTRL1 (BCM2711_LOCAL_REGS_BASE + 0x54)
>>>> +#define BCM2711_LOCAL_MAILBOX_CNTRL2 (BCM2711_LOCAL_REGS_BASE + 0x58)
>>>> +#define BCM2711_LOCAL_MAILBOX_CNTRL3 (BCM2711_LOCAL_REGS_BASE + 0x5c)
>>>> +#define BCM2711_LOCAL_IRQ_SOURCE0 (BCM2711_LOCAL_REGS_BASE + 0x60)
>>>> +#define BCM2711_LOCAL_IRQ_SOURCE1 (BCM2711_LOCAL_REGS_BASE + 0x64)
>>>> +#define BCM2711_LOCAL_IRQ_SOURCE2 (BCM2711_LOCAL_REGS_BASE + 0x68)
>>>> +#define BCM2711_LOCAL_IRQ_SOURCE3 (BCM2711_LOCAL_REGS_BASE + 0x6c)
>>>> +#define BCM2711_LOCAL_FIQ_SOURCE0 (BCM2711_LOCAL_REGS_BASE + 0x70)
>>>> +#define BCM2711_LOCAL_FIQ_SOURCE1 (BCM2711_LOCAL_REGS_BASE + 0x74)
>>>> +#define BCM2711_LOCAL_FIQ_SOURCE2 (BCM2711_LOCAL_REGS_BASE + 0x78)
>>>> +#define BCM2711_LOCAL_FIQ_SOURCE3 (BCM2711_LOCAL_REGS_BASE + 0x7c)
>>>> + * @name Raspberry Pi 4 ARM_C FIQ and IRQ registers
>>>> +#define BCM2711_ARMC_REGS_BASE (RPI_PERIPHERAL_BASE + 0xB200)
>>>> +#define BCM2711_ARMC_IRQ0_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x00)
>>>> +#define BCM2711_ARMC_IRQ0_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x04)
>>>> +#define BCM2711_ARMC_IRQ0_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x08)
>>>> +#define BCM2711_ARMC_IRQ0_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0x10)
>>>> +#define BCM2711_ARMC_IRQ0_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0x14)
>>>> +#define BCM2711_ARMC_IRQ0_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0x18)
>>>> +#define BCM2711_ARMC_IRQ0_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0x20)
>>>> +#define BCM2711_ARMC_IRQ0_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0x24)
>>>> +#define BCM2711_ARMC_IRQ0_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0x28)
>>>> +#define BCM2711_ARMC_IRQ_STATUS0 (BCM2711_ARMC_REGS_BASE + 0x30)
>>>> +#define BCM2711_ARMC_IRQ_STATUS1 (BCM2711_ARMC_REGS_BASE + 0x34)
>>>> +#define BCM2711_ARMC_IRQ_STATUS2 (BCM2711_ARMC_REGS_BASE + 0x38)
>>>> +#define BCM2711_ARMC_IRQ1_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x40)
>>>> +#define BCM2711_ARMC_IRQ1_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x44)
>>>> +#define BCM2711_ARMC_IRQ1_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x48)
>>>> +#define BCM2711_ARMC_IRQ1_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0x50)
>>>> +#define BCM2711_ARMC_IRQ1_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0x54)
>>>> +#define BCM2711_ARMC_IRQ1_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0x58)
>>>> +#define BCM2711_ARMC_IRQ1_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0x60)
>>>> +#define BCM2711_ARMC_IRQ1_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0x64)
>>>> +#define BCM2711_ARMC_IRQ1_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0x68)
>>>> +#define BCM2711_ARMC_IRQ2_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x80)
>>>> +#define BCM2711_ARMC_IRQ2_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x84)
>>>> +#define BCM2711_ARMC_IRQ2_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x88)
>>>> +#define BCM2711_ARMC_IRQ2_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0x90)
>>>> +#define BCM2711_ARMC_IRQ2_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0x94)
>>>> +#define BCM2711_ARMC_IRQ2_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0x98)
>>>> +#define BCM2711_ARMC_IRQ2_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0xA0)
>>>> +#define BCM2711_ARMC_IRQ2_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0xA4)
>>>> +#define BCM2711_ARMC_IRQ2_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0xA8)
>>>> +#define BCM2711_ARMC_IRQ3_PENDING0 (BCM2711_ARMC_REGS_BASE + 0xC0)
>>>> +#define BCM2711_ARMC_IRQ3_PENDING1 (BCM2711_ARMC_REGS_BASE + 0xC4)
>>>> +#define BCM2711_ARMC_IRQ3_PENDING2 (BCM2711_ARMC_REGS_BASE + 0xC8)
>>>> +#define BCM2711_ARMC_IRQ3_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0xD0)
>>>> +#define BCM2711_ARMC_IRQ3_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0xD4)
>>>> +#define BCM2711_ARMC_IRQ3_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0xD8)
>>>> +#define BCM2711_ARMC_IRQ3_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0xE0)
>>>> +#define BCM2711_ARMC_IRQ3_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0xE4)
>>>> +#define BCM2711_ARMC_IRQ3_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0xE8)
>>>> +#define BCM2711_ARMC_FIQ0_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x100)
>>>> +#define BCM2711_ARMC_FIQ0_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x104)
>>>> +#define BCM2711_ARMC_FIQ0_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x108)
>>>> +#define BCM2711_ARMC_FIQ0_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0x110)
>>>> +#define BCM2711_ARMC_FIQ0_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0x114)
>>>> +#define BCM2711_ARMC_FIQ0_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0x118)
>>>> +#define BCM2711_ARMC_FIQ0_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0x120)
>>>> +#define BCM2711_ARMC_FIQ0_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0x124)
>>>> +#define BCM2711_ARMC_FIQ0_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0x128)
>>>> +#define BCM2711_ARMC_FIQ1_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x140)
>>>> +#define BCM2711_ARMC_FIQ1_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x144)
>>>> +#define BCM2711_ARMC_FIQ1_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x148)
>>>> +#define BCM2711_ARMC_FIQ1_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0x150)
>>>> +#define BCM2711_ARMC_FIQ1_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0x154)
>>>> +#define BCM2711_ARMC_FIQ1_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0x158)
>>>> +#define BCM2711_ARMC_FIQ1_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0x160)
>>>> +#define BCM2711_ARMC_FIQ1_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0x164)
>>>> +#define BCM2711_ARMC_FIQ1_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0x168)
>>>> +#define BCM2711_ARMC_FIQ2_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x180)
>>>> +#define BCM2711_ARMC_FIQ2_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x184)
>>>> +#define BCM2711_ARMC_FIQ2_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x188)
>>>> +#define BCM2711_ARMC_FIQ2_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0x190)
>>>> +#define BCM2711_ARMC_FIQ2_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0x194)
>>>> +#define BCM2711_ARMC_FIQ2_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0x198)
>>>> +#define BCM2711_ARMC_FIQ2_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0x1A0)
>>>> +#define BCM2711_ARMC_FIQ2_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0x1A4)
>>>> +#define BCM2711_ARMC_FIQ2_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0x1A8)
>>>> +#define BCM2711_ARMC_FIQ3_PENDING0 (BCM2711_ARMC_REGS_BASE + 0x1C0)
>>>> +#define BCM2711_ARMC_FIQ3_PENDING1 (BCM2711_ARMC_REGS_BASE + 0x1C4)
>>>> +#define BCM2711_ARMC_FIQ3_PENDING2 (BCM2711_ARMC_REGS_BASE + 0x1C8)
>>>> +#define BCM2711_ARMC_FIQ3_SET_EN_0 (BCM2711_ARMC_REGS_BASE + 0x1D0)
>>>> +#define BCM2711_ARMC_FIQ3_SET_EN_1 (BCM2711_ARMC_REGS_BASE + 0x1D4)
>>>> +#define BCM2711_ARMC_FIQ3_SET_EN_2 (BCM2711_ARMC_REGS_BASE + 0x1D8)
>>>> +#define BCM2711_ARMC_FIQ3_CLR_EN_0 (BCM2711_ARMC_REGS_BASE + 0x1E0)
>>>> +#define BCM2711_ARMC_FIQ3_CLR_EN_1 (BCM2711_ARMC_REGS_BASE + 0x1E4)
>>>> +#define BCM2711_ARMC_FIQ3_CLR_EN_2 (BCM2711_ARMC_REGS_BASE + 0x1E8)
>>>> +#define BCM2711_ARMC_SWIRQ_SET (BCM2711_ARMC_REGS_BASE + 0x1F0)
>>>> +#define BCM2711_ARMC_SWIRQ_CLEAR (BCM2711_ARMC_REGS_BASE + 0x1F4)
>>>> + * @name Raspberry Pi 4 Mailbox registers
>>>> +#define BCM2711_MAILBOX_00_WRITE_SET_BASE 0x4C000080
>>>> +#define BCM2711_MAILBOX_01_WRITE_SET_BASE 0x4C000084
>>>> +#define BCM2711_MAILBOX_02_WRITE_SET_BASE 0x4C000088
>>>> +#define BCM2711_MAILBOX_03_WRITE_SET_BASE 0x4C00008C
>>>> +#define BCM2711_MAILBOX_04_WRITE_SET_BASE 0x4C000090
>>>> +#define BCM2711_MAILBOX_05_WRITE_SET_BASE 0x4C000094
>>>> +#define BCM2711_MAILBOX_06_WRITE_SET_BASE 0x4C000098
>>>> +#define BCM2711_MAILBOX_07_WRITE_SET_BASE 0x4C00009C
>>>> +#define BCM2711_MAILBOX_08_WRITE_SET_BASE 0x4C0000A0
>>>> +#define BCM2711_MAILBOX_09_WRITE_SET_BASE 0x4C0000A4
>>>> +#define BCM2711_MAILBOX_10_WRITE_SET_BASE 0x4C0000A8
>>>> +#define BCM2711_MAILBOX_11_WRITE_SET_BASE 0x4C0000AC
>>>> +#define BCM2711_MAILBOX_12_WRITE_SET_BASE 0x4C0000B0
>>>> +#define BCM2711_MAILBOX_13_WRITE_SET_BASE 0x4C0000B4
>>>> +#define BCM2711_MAILBOX_14_WRITE_SET_BASE 0x4C0000B8
>>>> +#define BCM2711_MAILBOX_15_WRITE_SET_BASE 0x4C0000BC
>>>> +#define BCM2711_MAILBOX_00_READ_CLEAR_BASE 0x4C0000C0
>>>> +#define BCM2711_MAILBOX_01_READ_CLEAR_BASE 0x4C0000C4
>>>> +#define BCM2711_MAILBOX_02_READ_CLEAR_BASE 0x4C0000C8
>>>> +#define BCM2711_MAILBOX_03_READ_CLEAR_BASE 0x4C0000CC
>>>> +#define BCM2711_MAILBOX_04_READ_CLEAR_BASE 0x4C0000D0
>>>> +#define BCM2711_MAILBOX_05_READ_CLEAR_BASE 0x4C0000D4
>>>> +#define BCM2711_MAILBOX_06_READ_CLEAR_BASE 0x4C0000D8
>>>> +#define BCM2711_MAILBOX_07_READ_CLEAR_BASE 0x4C0000DC
>>>> +#define BCM2711_MAILBOX_08_READ_CLEAR_BASE 0x4C0000E0
>>>> +#define BCM2711_MAILBOX_09_READ_CLEAR_BASE 0x4C0000E4
>>>> +#define BCM2711_MAILBOX_10_READ_CLEAR_BASE 0x4C0000E8
>>>> +#define BCM2711_MAILBOX_11_READ_CLEAR_BASE 0x4C0000EC
>>>> +#define BCM2711_MAILBOX_12_READ_CLEAR_BASE 0x4C0000F0
>>>> +#define BCM2711_MAILBOX_13_READ_CLEAR_BASE 0x4C0000F4
>>>> +#define BCM2711_MAILBOX_14_READ_CLEAR_BASE 0x4C0000F8
>>>> +#define BCM2711_MAILBOX_15_READ_CLEAR_BASE 0x4C0000FC
>>>> #endif /* LIBBSP_ARM_RASPBERRYPI_RASPBERRYPI_H */
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220721/898a6665/attachment-0001.htm>
