[PATCH 2/2] aarch64/versal: Support DDRMC0 region 0 and 1
chrisj at rtems.org chrisj at rtems.org
Fri Jul 22 06:35:06 UTC 2022
- Support DDRMC0 region 0 up to 2G in size
- Support DDRMC0 region 1 with DDR memory greater than 2G
  up to the DDRMC0 max amount
- Extend the heap with region 1's memory
Closes #4684
 bsps/aarch64/xilinx-versal/include/bsp.h      |  9 ++++
 bsps/aarch64/xilinx-versal/start/bspstart.c   |  2 +
 .../aarch64/xilinx-versal/start/bspstartmmu.c | 36 ++++++++++++++
 .../aarch64/xilinx-versal/linkcmds_lp64.yml   | 48 +++++++++++++++++--
 4 files changed, 90 insertions(+), 5 deletions(-)
diff --git a/bsps/aarch64/xilinx-versal/include/bsp.h b/bsps/aarch64/xilinx-versal/include/bsp.h
index 2017e10ade..0bd93f28bc 100644
--- a/bsps/aarch64/xilinx-versal/include/bsp.h
+++ b/bsps/aarch64/xilinx-versal/include/bsp.h
@@ -47,6 +47,7 @@
 #ifndef ASM
 #include <bsp/default-initial-extension.h>
+#include <bsp/linker-symbols.h>
 #include <bsp/start.h>
@@ -61,6 +62,14 @@ extern "C" {
 #define BSP_RESET_SMC
+ * DDRMC mapping
+LINKER_SYMBOL(bsp_r0_ram_base)
+LINKER_SYMBOL(bsp_r0_ram_end)
+LINKER_SYMBOL(bsp_r1_ram_base)
+LINKER_SYMBOL(bsp_r1_ram_end)
  * @brief Versal specific set up of the MMU.
diff --git a/bsps/aarch64/xilinx-versal/start/bspstart.c b/bsps/aarch64/xilinx-versal/start/bspstart.c
index 2f0048ddf3..86b3024dd2 100644
--- a/bsps/aarch64/xilinx-versal/start/bspstart.c
+++ b/bsps/aarch64/xilinx-versal/start/bspstart.c
@@ -38,6 +38,8 @@
 #include <bsp/irq-generic.h>
+#include <bsp/aarch64-mmu.h>
 void bsp_start( void )
   bsp_interrupt_initialize();
diff --git a/bsps/aarch64/xilinx-versal/start/bspstartmmu.c b/bsps/aarch64/xilinx-versal/start/bspstartmmu.c
index 5949111d0d..c2fcd62c9f 100644
--- a/bsps/aarch64/xilinx-versal/start/bspstartmmu.c
+++ b/bsps/aarch64/xilinx-versal/start/bspstartmmu.c
@@ -38,6 +38,9 @@
 #include <libcpu/mmu-vmsav8-64.h>
+#include <rtems/malloc.h>
+#include <rtems/sysinit.h>
 BSP_START_DATA_SECTION static const aarch64_mmu_config_entry
 versal_mmu_config_table[] = {
   AARCH64_MMU_DEFAULT_SECTIONS,
@@ -57,6 +60,24 @@ versal_mmu_config_table[] = {
     .begin = 0xff000000U,
     .end = 0xffc00000U,
     .flags = AARCH64_MMU_DEVICE
+  }, { /* DDRMC0_region1_mem, if not used size is 0 and ignored */
+    .begin = (uintptr_t) bsp_r1_ram_base,
+    .end = (uintptr_t) bsp_r1_ram_end,
+    .flags = AARCH64_MMU_DATA_RW_CACHED
+ * Create an MMU table to get the R1 base and end. This avoids
+ * relocation errors as the R1 addresses are in the upper A64 address
+ * space.
+static const aarch64_mmu_config_entry
+bsp_r1_region[] = {
+  { /* DDRMC0_region1_mem, if not used size is 0 and ignored */
+    .flags = 0
@@ -78,3 +99,18 @@ versal_setup_mmu_and_cache( void )
   aarch64_mmu_enable();
+void bsp_r1_heap_extend(void);
+  const aarch64_mmu_config_entry* r1 = &bsp_r1_region[0];
+  if (false && r1->begin != r1->end) {
+    rtems_heap_extend((void*) r1->begin, r1->end - r1->begin);
+RTEMS_SYSINIT_ITEM(
+  bsp_r1_heap_extend,
+  RTEMS_SYSINIT_MALLOC,
+  RTEMS_SYSINIT_ORDER_LAST
diff --git a/spec/build/bsps/aarch64/xilinx-versal/linkcmds_lp64.yml b/spec/build/bsps/aarch64/xilinx-versal/linkcmds_lp64.yml
index 76c0220f0e..ca353d2662 100644
--- a/spec/build/bsps/aarch64/xilinx-versal/linkcmds_lp64.yml
+++ b/spec/build/bsps/aarch64/xilinx-versal/linkcmds_lp64.yml
@@ -4,7 +4,8 @@ content: |
   /* SPDX-License-Identifier: BSD-2-Clause */
-   * Copyright (C) 2021 Gedare Bloom <gedare at rtems.org>
+   * Copyright (C) 2021 Gedare Bloom <gedare at rtems.org>
+   * Copyright (C) 2022 Chris Johns <chrisj at rtems.org>
    * modification, are permitted provided that the following conditions
@@ -28,10 +29,41 @@ content: |
    * POSSIBILITY OF SUCH DAMAGE.
+   * The RAM supports 32G of DDR4 or LPDDR memory using DDRMC0.
+   * The DDR Conroller (DDRC) has two regions R0 and R1. R0 is
+   * in the A32 address space and R1 is in the A64 address space.
+  DDRMC0_REGION_0_BASE = 0x00000000000;
+  DDRMC0_REGION_0_LENGTH = 0x00080000000;
+  DDRMC0_REGION_1_BASE = 0x00800000000;
+  DDRMC0_REGION_1_LENGTH = 0x01000000000;
+  BSP_RAM_BASE = ${BSP_XILINX_VERSAL_RAM_BASE};
+  BSP_R0_RAM_BASE = DDRMC0_REGION_0_BASE;
+  BSP_R0_RAM_LENGTH =
+     ${BSP_XILINX_VERSAL_RAM_LENGTH} >= DDRMC0_REGION_0_LENGTH ?
+         DDRMC0_REGION_0_LENGTH - BSP_RAM_BASE : ${BSP_XILINX_VERSAL_RAM_LENGTH};
+  BSP_R0_RAM_END = BSP_RAM_BASE + BSP_R0_RAM_LENGTH;
+  BSP_R1_RAM_BASE = DDRMC0_REGION_1_BASE;
+  BSP_R1_RAM_LENGTH =
+         ${BSP_XILINX_VERSAL_RAM_LENGTH} - DDRMC0_REGION_0_LENGTH : 0;
+  AARCH64_MMU_TT_PAGES_SIZE = 0x1000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES};
   MEMORY {
-    RAM       : ORIGIN = ${BSP_XILINX_VERSAL_RAM_BASE} + ${BSP_XILINX_VERSAL_LOAD_OFFSET}, LENGTH = ${BSP_XILINX_VERSAL_RAM_LENGTH} - ${BSP_XILINX_VERSAL_LOAD_OFFSET} - ${BSP_XILINX_VERSAL_NOCACHE_LENGTH} - (0x1000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES})
-    NOCACHE   : ORIGIN = ${BSP_XILINX_VERSAL_RAM_BASE} + ${BSP_XILINX_VERSAL_RAM_LENGTH} - (0x1000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES}) - ${BSP_XILINX_VERSAL_NOCACHE_LENGTH}, LENGTH = ${BSP_XILINX_VERSAL_NOCACHE_LENGTH}
-    RAM_MMU   : ORIGIN = ${BSP_XILINX_VERSAL_RAM_BASE} + ${BSP_XILINX_VERSAL_RAM_LENGTH} - (0x1000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES}), LENGTH = 0x1000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES}
+    RAM       : ORIGIN = BSP_RAM_BASE + ${BSP_XILINX_VERSAL_LOAD_OFFSET},
+                LENGTH = BSP_R0_RAM_LENGTH - ${BSP_XILINX_VERSAL_LOAD_OFFSET} - ${BSP_XILINX_VERSAL_NOCACHE_LENGTH} - AARCH64_MMU_TT_PAGES_SIZE
+    RAM1      : ORIGIN = BSP_R1_RAM_BASE,
+                LENGTH = BSP_R1_RAM_LENGTH
+    NOCACHE   : ORIGIN = BSP_RAM_BASE + BSP_R0_RAM_LENGTH - AARCH64_MMU_TT_PAGES_SIZE - ${BSP_XILINX_VERSAL_NOCACHE_LENGTH},
+                LENGTH = ${BSP_XILINX_VERSAL_NOCACHE_LENGTH}
+    RAM_MMU   : ORIGIN = BSP_R0_RAM_END - AARCH64_MMU_TT_PAGES_SIZE,
+                LENGTH = AARCH64_MMU_TT_PAGES_SIZE
   REGION_ALIAS ("REGION_START",          RAM);
@@ -58,6 +90,11 @@ content: |
   bsp_vector_table_in_start_section = 1;
+  bsp_r0_ram_base = DDRMC0_REGION_0_BASE;
+  bsp_r0_ram_end = ORIGIN (RAM) + LENGTH (RAM);
+  bsp_r1_ram_base = ORIGIN (RAM1);
+  bsp_r1_ram_end = ORIGIN (RAM1) + LENGTH (RAM1);
   bsp_translation_table_base = ORIGIN (RAM_MMU);
   bsp_translation_table_end = ORIGIN (RAM_MMU) + LENGTH (RAM_MMU);
@@ -66,7 +103,8 @@ content: |
   INCLUDE linkcmds.base
 copyrights:
-- Copyright (C) 2021 Gedare Bloom <gedare at rtems.org>
+- Copyright (C) 2021 Gedare Bloom <gedare at rtems.org>
+- Copyright (C) 2022 Chris Johns <chrisj at rtems.org>
 enabled-by: true
 install-path: ${BSP_LIBDIR}
 links: []
2.19.1
