[PATCH 1/2] basp/aarch64: Make the unexpected sections origin address 64bit
Kinsey Moore kinsey.moore at oarcorp.com
Fri Jul 22 13:14:09 UTC 2022
Has this patch been tested with ILP32? I suspect that this line might
need to get yanked out to a shared lp64 linkcmds.base and a shared ilp32
linkcmds.base or this line pulled up into the bsp-specific linkcmds
variants.
Kinsey
On 7/22/2022 01:35, chrisj at rtems.org wrote:
> From: Chris Johns <chrisj at rtems.org>
> Update #4684
>   bsps/aarch64/shared/start/linkcmds.base | 2 +-
>   1 file changed, 1 insertion(+), 1 deletion(-)
> diff --git a/bsps/aarch64/shared/start/linkcmds.base b/bsps/aarch64/shared/start/linkcmds.base
> index bcdf4715d7..f4639bd990 100644
> --- a/bsps/aarch64/shared/start/linkcmds.base
> +++ b/bsps/aarch64/shared/start/linkcmds.base
> @@ -56,7 +56,7 @@ bsp_stack_hyp_size = DEFINED (bsp_stack_hyp_size) ? bsp_stack_hyp_size : 0;
>   bsp_stack_hyp_size = ALIGN (bsp_stack_hyp_size, bsp_stack_align);
>   MEMORY {
> -	UNEXPECTED_SECTIONS : ORIGIN = 0xffffffff, LENGTH = 0
> +	UNEXPECTED_SECTIONS : ORIGIN = 0xffffffffffffffff, LENGTH = 0
>   SECTIONS {
