Fwd: [rtems-bsp-builder] 2022-07-23 23:03:59: Profile(s): everything
Joel Sherrill
joel at rtems.org
Sun Jul 24 14:53:53 UTC 2022
Looks like some tests are two big for some lpc BSPs.
I haven't looked into all the bfin failures. Those are new.
The Microblaze ones are the linker script issue a patch was posted for. I
need to push that.
---------- Forwarded message ---------
Date: Sun, Jul 24, 2022, 5:24 AM
Subject: [rtems-bsp-builder] 2022-07-23 23:03:59: Profile(s): everything
To: <build at rtems.org>
RTEMS Tools Project - RTEMS Kernel BSP Builder, 6.0.not_released
Host: FreeBSD 12.2-RELEASE r366954 GENERIC
command: /home/tester/rtems-cron-6/tools/6/bin/rtems-bsp-builder\
--rtems=/home/tester/rtems-cron-6/rtems --build-\
path=/home/tester/rtems-cron-6/build --prefix=/home/tester/rtems-\
cron-6/tools/6/bsps --log=/home/tester/rtems-cron-6/bsp-\
builder.log --warnings-report=warnings.log --mail --use-gitconfig\
--profiles=everything
Total Time : 6:20:39.191204 for 1260 completed job(s)
Average BSP Build Time: 0:00:18.126342
Builds
debug
no-posix
posix
posix-debug
posix-profiling
profiling
smp
smp-debug
Failures Report
1 debug arm/lpc1768_mbed_ahb_ram_eth build:
configure: /home/tester/rtems-cron-6/rtems/waf configure\
--prefix=/home/tester/rtems-cron-6/tools/6/bsps\
--top=/home/tester/rtems-cron-6/rtems --rtems-config=config-arm-\
lpc1768_mbed_ahb_ram_eth-debug.ini
error: usr/home/tester/rtems-cron-6/tools/6/arm-
rtems6/bin/ld:linkcmds.base:348 cannot move location counter
backwards (from 0000000020080b98 to 0000000020080000)
error: ld/collect2:0 error: linkcmds.base:348 cannot move location
counter backwards (from 0000000020080b98 to 0000000020080000)
2 no-posix arm/lpc1768_mbed_ahb_ram_eth build:
lpc1768_mbed_ahb_ram_eth-no-posix.ini
backwards (from 0000000020080a00 to 0000000020080000)
counter backwards (from 0000000020080a00 to 0000000020080000)
3 posix arm/lpc1768_mbed_ahb_ram_eth build:
lpc1768_mbed_ahb_ram_eth-posix.ini
backwards (from 0000000020081288 to 0000000020080000)
counter backwards (from 0000000020081288 to 0000000020080000)
4 posix-debug arm/lpc1768_mbed_ahb_ram_eth build:
lpc1768_mbed_ahb_ram_eth-posix-debug.ini
backwards (from 0000000020081420 to 0000000020080000)
counter backwards (from 0000000020081420 to 0000000020080000)
5 posix-profiling arm/lpc1768_mbed_ahb_ram_eth build:
lpc1768_mbed_ahb_ram_eth-posix-profiling.ini
6 profiling arm/lpc1768_mbed_ahb_ram_eth build:
lpc1768_mbed_ahb_ram_eth-profiling.ini
7 debug bfin/TLL6527M configure:
--top=/home/tester/rtems-cron-6/rtems --rtems-config=config-bfin-\
TLL6527M-debug.ini
8 no-posix bfin/TLL6527M configure:
TLL6527M-no-posix.ini
9 posix bfin/TLL6527M configure:
TLL6527M-posix.ini
10 posix-debug bfin/TLL6527M configure:
TLL6527M-posix-debug.ini
11 posix-profiling bfin/TLL6527M configure:
TLL6527M-posix-profiling.ini
12 profiling bfin/TLL6527M configure:
TLL6527M-profiling.ini
13 debug bfin/bf537Stamp configure:
bf537Stamp-debug.ini
14 no-posix bfin/bf537Stamp configure:
bf537Stamp-no-posix.ini
15 posix bfin/bf537Stamp configure:
bf537Stamp-posix.ini
16 posix-debug bfin/bf537Stamp configure:
bf537Stamp-posix-debug.ini
17 posix-profiling bfin/bf537Stamp configure:
bf537Stamp-posix-profiling.ini
18 profiling bfin/bf537Stamp configure:
bf537Stamp-profiling.ini
19 debug bfin/eZKit533 configure:
eZKit533-debug.ini
20 no-posix bfin/eZKit533 configure:
eZKit533-no-posix.ini
21 posix bfin/eZKit533 configure:
eZKit533-posix.ini
22 posix-debug bfin/eZKit533 configure:
eZKit533-posix-debug.ini
23 posix-profiling bfin/eZKit533 configure:
eZKit533-posix-profiling.ini
24 profiling bfin/eZKit533 configure:
eZKit533-profiling.ini
25 debug microblaze/kcu105 build:
--top=/home/tester/rtems-cron-6/rtems --rtems-config=config-\
microblaze-kcu105-debug.ini
error: usr/home/tester/rtems-cron-6/tools/6/microblaze-
rtems6/bin/ld:linkcmds:36: syntax error
error: ld/collect2:0 error: linkcmds:36: syntax error
26 no-posix microblaze/kcu105 build:
microblaze-kcu105-no-posix.ini
27 posix microblaze/kcu105 build:
microblaze-kcu105-posix.ini
28 posix-debug microblaze/kcu105 build:
microblaze-kcu105-posix-debug.ini
29 posix-profiling microblaze/kcu105 build:
microblaze-kcu105-posix-profiling.ini
30 profiling microblaze/kcu105 build:
microblaze-kcu105-profiling.ini
31 debug microblaze/kcu105_qemu build:
microblaze-kcu105_qemu-debug.ini
32 no-posix microblaze/kcu105_qemu build:
microblaze-kcu105_qemu-no-posix.ini
33 posix microblaze/kcu105_qemu build:
microblaze-kcu105_qemu-posix.ini
34 posix-debug microblaze/kcu105_qemu build:
microblaze-kcu105_qemu-posix-debug.ini
35 posix-profiling microblaze/kcu105_qemu build:
microblaze-kcu105_qemu-posix-profiling.ini
36 profiling microblaze/kcu105_qemu build:
microblaze-kcu105_qemu-profiling.ini
Warnings Report
| By Architecture (total : 10426) |
| common : 18 warning(s) |
| Shared : 780 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 0 | CPU Kit : 914 | | |
| aarch64 : 0 warning(s) |
| arm : 29 warning(s) |
| Shared : 162 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 0 | CPU Kit : 222 | | |
| i386 : 32 warning(s) |
| Shared : 0 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 0 | CPU Kit : 276 | | |
| lm32 : 19 warning(s) |
| Shared : 156 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 0 | CPU Kit : 72 | | |
| m68k : 33 warning(s) |
| Shared : 876 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 0 | CPU Kit : 1050 | | |
| microblaze : 0 warning(s) |
| mips : 8 warning(s) |
| LibCPU : 0 | CPU Kit : 54 | | |
| moxie : 2 warning(s) |
| Shared : 20 | BSP : 0 | Network : 0 | Tests : 0 |
| nios2 : 0 warning(s) |
| or1k : 1 warning(s) |
| Shared : 6 | BSP : 0 | Network : 0 | Tests : 0 |
| powerpc : 28 warning(s) |
| Shared : 116 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 12 | CPU Kit : 380 | | |
| riscv : 0 warning(s) |
| sh : 162 warning(s) |
| Shared : 56 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 0 | CPU Kit : 84 | | |
| sparc : 4 warning(s) |
| LibCPU : 0 | CPU Kit : 6 | | |
| sparc64 : 2 warning(s) |
| Shared : 28 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 0 | CPU Kit : 0 | | |
| v850 : 1 warning(s) |
| Shared : 48 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 0 | CPU Kit : 36 | | |
| x86_64 : 1 warning(s) |
| By BSP (total : 10426) |
| common : 259 warning(s) |
| Shared : 1244 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 0 | CPU Kit : 2090 | | |
| aarch64/xilinx_zynqmp_ilp32_qemu : 0 warning(s) |
| aarch64/xilinx_zynqmp_ilp32_zu3eg : 0 warning(s) |
| aarch64/xilinx_zynqmp_lp64_qemu : 0 warning(s) |
| aarch64/xilinx_zynqmp_lp64_zu3eg : 0 warning(s) |
| arm/altcycv_devkit : 7 warning(s) |
| LibCPU : 0 | CPU Kit : 2 | | |
| arm/atsamv : 2 warning(s) |
| arm/beagleboardorig : 0 warning(s) |
| arm/beagleboardxm : 0 warning(s) |
| arm/beagleboneblack : 0 warning(s) |
| arm/beaglebonewhite : 0 warning(s) |
| arm/csb336 : 0 warning(s) |
| arm/csb337 : 0 warning(s) |
| arm/csb637 : 0 warning(s) |
| arm/gumstix : 0 warning(s) |
| arm/imx7 : 2 warning(s) |
| LibCPU : 0 | CPU Kit : 34 | | |
| arm/imxrt1052 : 0 warning(s) |
| arm/kit637_v6 : 0 warning(s) |
| arm/lm3s3749 : 0 warning(s) |
| arm/lm3s6965 : 0 warning(s) |
| arm/lm3s6965_qemu : 0 warning(s) |
| arm/lm4f120 : 0 warning(s) |
| arm/lpc1768_mbed : 0 warning(s) |
| arm/lpc1768_mbed_ahb_ram : 0 warning(s) |
| arm/lpc1768_mbed_ahb_ram_eth : 0 warning(s) |
| arm/lpc17xx_ea_ram : 0 warning(s) |
| arm/lpc17xx_ea_rom_int : 0 warning(s) |
| arm/lpc17xx_plx800_ram : 0 warning(s) |
| arm/lpc17xx_plx800_rom_int : 0 warning(s) |
| arm/lpc2362 : 0 warning(s) |
| arm/lpc23xx_tli800 : 0 warning(s) |
| arm/lpc24xx_ea : 0 warning(s) |
| arm/lpc24xx_ncs_ram : 0 warning(s) |
| arm/lpc24xx_ncs_rom_ext : 0 warning(s) |
| arm/lpc24xx_ncs_rom_int : 0 warning(s) |
| arm/lpc24xx_plx800_ram : 0 warning(s) |
| arm/lpc24xx_plx800_rom_int : 0 warning(s) |
| arm/lpc32xx_mzx : 0 warning(s) |
| arm/lpc32xx_mzx_stage_1 : 0 warning(s) |
| arm/lpc32xx_mzx_stage_2 : 0 warning(s) |
| arm/lpc32xx_phycore : 0 warning(s) |
| arm/lpc40xx_ea_ram : 0 warning(s) |
| arm/lpc40xx_ea_rom_int : 0 warning(s) |
| arm/nucleo-h743zi : 0 warning(s) |
| arm/raspberrypi : 0 warning(s) |
| arm/raspberrypi2 : 0 warning(s) |
| arm/realview_pbx_a9_qemu : 0 warning(s) |
| arm/smdk2410 : 0 warning(s) |
| arm/stm32f105rc : 0 warning(s) |
| arm/stm32f4 : 2 warning(s) |
| arm/stm32h7 : 0 warning(s) |
| arm/tms570ls3137_hdk : 0 warning(s) |
| arm/tms570ls3137_hdk_intram : 0 warning(s) |
| arm/tms570ls3137_hdk_sdram : 0 warning(s) |
| arm/tms570ls3137_hdk_with_loader : 0 warning(s) |
| arm/xilinx_zynq_a9_qemu : 0 warning(s) |
| arm/xilinx_zynq_zc702 : 0 warning(s) |
| arm/xilinx_zynq_zc706 : 0 warning(s) |
| arm/xilinx_zynq_zedboard : 0 warning(s) |
| arm/xilinx_zynqmp_ultra96 : 1 warning(s) |
| i386/pc386 : 0 warning(s) |
| i386/pc486 : 0 warning(s) |
| i386/pc586 : 0 warning(s) |
| i386/pc586-sse : 0 warning(s) |
| i386/pc686 : 0 warning(s) |
| i386/pcp4 : 0 warning(s) |
| lm32/lm32_evr : 0 warning(s) |
| lm32/lm32_evr_gdbsim : 0 warning(s) |
| lm32/milkymist : 12 warning(s) |
| Shared : 96 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 0 | CPU Kit : 24 | | |
| m68k/COBRA5475 : 0 warning(s) |
| m68k/av5282 : 0 warning(s) |
| m68k/csb360 : 0 warning(s) |
| m68k/gen68340 : 0 warning(s) |
| m68k/gen68360 : 2 warning(s) |
| Shared : 14 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 0 | CPU Kit : 48 | | |
| m68k/gen68360_040 : 0 warning(s) |
| m68k/m5484FireEngine : 3 warning(s) |
| Shared : 66 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 0 | CPU Kit : 60 | | |
| m68k/mcf5206elite : 1 warning(s) |
| Shared : 74 | BSP : 0 | Network : 0 | Tests : 0 |
| m68k/mcf52235 : 3 warning(s) |
| m68k/mcf5225x : 3 warning(s) |
| m68k/mcf5235 : 1 warning(s) |
| m68k/mcf5329 : 3 warning(s) |
| m68k/mrm332 : 0 warning(s) |
| m68k/mvme147 : 0 warning(s) |
| m68k/mvme147s : 0 warning(s) |
| m68k/mvme162 : 0 warning(s) |
| m68k/mvme162lx : 0 warning(s) |
| m68k/mvme167 : 0 warning(s) |
| m68k/pgh360 : 0 warning(s) |
| m68k/uC5282 : 6 warning(s) |
| microblaze/kcu105 : 0 warning(s) |
| microblaze/kcu105_qemu : 0 warning(s) |
| mips/hurricane : 1 warning(s) |
| mips/malta : 6 warning(s) |
| mips/rbtx4938 : 1 warning(s) |
| moxie/moxiesim : 2 warning(s) |
| nios2/nios2_iss : 0 warning(s) |
| or1k/generic_or1k : 1 warning(s) |
| powerpc/beatnik : 2 warning(s) |
| LibCPU : 12 | CPU Kit : 6 | | |
| powerpc/br_uid : 0 warning(s) |
| powerpc/gwlcfm : 0 warning(s) |
| powerpc/hsc_cm01 : 0 warning(s) |
| powerpc/icecube : 0 warning(s) |
| powerpc/mcp750 : 0 warning(s) |
| powerpc/mpc5566evb : 0 warning(s) |
| powerpc/mpc5643l_evb : 0 warning(s) |
| powerpc/mpc5668g : 0 warning(s) |
| powerpc/mpc5674fevb : 0 warning(s) |
| powerpc/mpc8260ads : 0 warning(s) |
| powerpc/mpc8309som : 0 warning(s) |
| powerpc/mpc8313erdb : 0 warning(s) |
| powerpc/mpc8349eamds : 0 warning(s) |
| powerpc/mtx603e : 0 warning(s) |
| powerpc/mvme2100 : 0 warning(s) |
| powerpc/mvme2307 : 0 warning(s) |
| powerpc/mvme3100 : 1 warning(s) |
| Shared : 8 | BSP : 0 | Network : 0 | Tests : 0 |
| powerpc/mvme5500 : 2 warning(s) |
| powerpc/pghplus : 0 warning(s) |
| powerpc/phycore_mpc5554 : 0 warning(s) |
| powerpc/pm520_cr825 : 0 warning(s) |
| powerpc/pm520_ze30 : 0 warning(s) |
| powerpc/psim : 1 warning(s) |
| powerpc/qemuppc : 1 warning(s) |
| powerpc/qemuprep : 0 warning(s) |
| powerpc/qemuprep-altivec : 0 warning(s) |
| powerpc/qoriq_core_0 : 0 warning(s) |
| powerpc/qoriq_core_1 : 0 warning(s) |
| powerpc/qoriq_e500 : 0 warning(s) |
| powerpc/qoriq_e6500_32 : 0 warning(s) |
| powerpc/qoriq_e6500_64 : 6 warning(s) |
| Shared : 24 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 0 | CPU Kit : 114 | | |
| powerpc/ss555 : 2 warning(s) |
| powerpc/t32mppc : 2 warning(s) |
| LibCPU : 0 | CPU Kit : 42 | | |
| powerpc/tqm8xx_stk8xx : 0 warning(s) |
| powerpc/virtex : 0 warning(s) |
| powerpc/virtex4 : 0 warning(s) |
| powerpc/virtex5 : 0 warning(s) |
| riscv/griscv : 0 warning(s) |
| riscv/grv32imac : 0 warning(s) |
| riscv/grv32imafdc : 0 warning(s) |
| riscv/rv32iac : 0 warning(s) |
| riscv/rv32imac : 0 warning(s) |
| riscv/rv32imafc : 0 warning(s) |
| riscv/rv32imafd : 0 warning(s) |
| riscv/rv32imafdc : 0 warning(s) |
| riscv/rv64imac : 0 warning(s) |
| riscv/rv64imac_medany : 0 warning(s) |
| riscv/rv64imafd : 0 warning(s) |
| riscv/rv64imafd_medany : 0 warning(s) |
| riscv/rv64imafdc : 0 warning(s) |
| riscv/rv64imafdc_medany : 0 warning(s) |
| sh/gensh1 : 1 warning(s) |
| LibCPU : 0 | CPU Kit : 12 | | |
| sh/gensh2 : 1 warning(s) |
| sh/gensh4 : 1 warning(s) |
| sh/simsh1 : 0 warning(s) |
| sh/simsh2 : 0 warning(s) |
| sh/simsh2e : 0 warning(s) |
| sh/simsh4 : 0 warning(s) |
| sparc/at697f : 0 warning(s) |
| sparc/gr712rc : 0 warning(s) |
| sparc/gr740 : 0 warning(s) |
| sparc/leon2 : 0 warning(s) |
| sparc/leon3 : 0 warning(s) |
| sparc/ut699 : 0 warning(s) |
| sparc/ut700 : 0 warning(s) |
| sparc64/niagara : 0 warning(s) |
| sparc64/usiii : 1 warning(s) |
| v850/v850e1sim : 0 warning(s) |
| v850/v850e2sim : 0 warning(s) |
| v850/v850e2v3sim : 0 warning(s) |
| v850/v850esim : 0 warning(s) |
| v850/v850essim : 0 warning(s) |
| v850/v850sim : 0 warning(s) |
| x86_64/amd64 : 1 warning(s) |
| By Build (total : 10426) |
| common : 338 warning(s) |
| Shared : 1191 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 10 | CPU Kit : 866 | | |
| debug : 2 warning(s) |
| Shared : 185 | BSP : 0 | Network : 0 | Tests : 0 |
| LibCPU : 2 | CPU Kit : 392 | | |
| no-posix : 0 warning(s) |
| posix-debug : 0 warning(s) |
| posix-profiling : 0 warning(s) |
| smp : 0 warning(s) |
| smp-debug : 0 warning(s) |
build mailing list
build at rtems.org
http://lists.rtems.org/mailman/listinfo/build
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220724/c06e6307/attachment-0001.htm>
