[libbsd 00/22] Remove FreeBSD file descriptors and avoid VFS
Sebastian Huber
Mon Jul 25 06:12:01 UTC 2022
On 11/07/2022 15:04, Sebastian Huber wrote:
> On 24/06/2022 08:33, Sebastian Huber wrote:
>> This patch set removes the FreeBSD file descriptors. The VFS is no
>> longer used
>> if only the USB, SD/MMC, network, PCI, and NVMe support is used by the
>> application. This change significantly reduce the memory usage of
>> LibBSD for
>> these applications. Using the media01 test case for the arm/lpc32xx
>> BSP as a
>> benchmark, the heap usage dropped from 14.3MiB to 10.2MiB. The "_BSD
>> bufdaemon", "_BSD vnlru", "_BSD syncer", and "_BSD bufspacedaemon-"
>> tasks are
>> no longer present in media01. The code size is reduced by about
>> 8KiB. The
>> data size is reduced by about 30KiB. The throughput with a simple FTP
>> test
>> increased by about 1%.
>> The "Remove FreeBSD file descriptors" change removes more lines than
>> there are
>> added.
>> This change makes it easier to port the NFS support to the master
>> branch since
>> now the changes are more localized.
> I have a target with only 8MiB of RAM (for code and data). So, this
> patch set is not just a micro optimization.
This pending patch set is currently a blocker for me. I would like to
work on the NTP daemon integration and an update of the libbsd master
branch to a more recent FreeBSD version. This patch set just restores
what worked well for several years.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
