[tools v2] tester: Normalize JSON and YAML reports
Sebastian Huber
Tue Jul 26 12:10:53 UTC 2022
Report the same data in JSON and YAML reports. Do not report redundant
information.
Update 4671.
v2:
* Add 'report-version' attribute with a value of 1.
* Add 'tester-version' attribute.
* Use a list for both 'command-line' attributes.
tester/rt/test.py | 193 ++++++++++------------------------------------
1 file changed, 42 insertions(+), 151 deletions(-)
diff --git a/tester/rt/test.py b/tester/rt/test.py
index 113936c..a13b40a 100644
--- a/tester/rt/test.py
+++ b/tester/rt/test.py
@@ -218,76 +218,48 @@ def killall(tests):
test.kill()
+def results_to_data(args, reports, start_time, end_time):
+ data = {}
+ data['report-version'] = 1
+ data['tester-version'] = version.string()
+ data['command-line'] = args
+ data['host'] = host.label(mode='all')
+ data['python'] = sys.version.replace('\n', '')
+ data['start-time'] = start_time.isoformat()
+ data['end-time'] = start_time.isoformat()
+ reports_data = []
+ for name, run in reports.results.items():
+ run_data = {}
+ result = run['result']
+ run_data['result'] = result
+ output = []
+ for line in run['output']:
+ if line.startswith('] '):
+ output.append(line[2:])
+ elif line.startswith('=> exe:'):
+ run_data['command-line'] = line[9:].split()
+ run_data['output'] = output
+ run_data['executable'] = name
+ run_data['executable-sha512'] = get_hash512(name)
+ run_data['start-time'] = run['start'].isoformat()
+ run_data['end-time'] = run['end'].isoformat()
+ run_data['bsp'] = run['bsp']
+ run_data['arch'] = run['bsp_arch']
+ reports_data.append(run_data)
+ data['reports'] = reports_data
+ return data
def generate_json_report(args, reports, start_time, end_time,
- total, json_file):
+ _total, json_file):
import json
- import sys
- json_log = {}
- json_log['Command Line'] = " ".join(args)
- json_log['Python'] = sys.version.replace('\n', '')
- json_log['test_groups'] = []
- json_log['Host'] = host.label(mode='all')
- json_log['summary'] = {}
- json_log['summary']['passed_count'] = reports.passed
- json_log['summary']['failed_count'] = reports.failed
- json_log['summary']['user-input_count'] = reports.user_input
- json_log['summary']['expected-fail_count'] = reports.expected_fail
- json_log['summary']['indeterminate_count'] = reports.indeterminate
- json_log['summary']['benchmark_count'] = reports.benchmark
- json_log['summary']['timeout_count'] = reports.timeouts
- json_log['summary']['test-too-long_count'] = reports.test_too_long
- json_log['summary']['invalid_count'] = reports.invalids
- json_log['summary']['wrong-version_count'] = reports.wrong_version
- json_log['summary']['wrong-build_count'] = reports.wrong_build
- json_log['summary']['wrong-tools_count'] = reports.wrong_tools
- json_log['summary']['invalid-header_count'] = reports.wrong_header
- json_log['summary']['total_count'] = reports.total
- time_delta = end_time - start_time
- json_log['summary']['average_test_time'] = str(time_delta / total)
- json_log['summary']['testing_time'] = str(time_delta)
- result_types = [
- 'failed', 'user-input', 'expected-fail', 'indeterminate',
- 'benchmark', 'timeout', 'test-too-long', 'invalid', 'wrong-version',
- 'wrong-build', 'wrong-tools', 'wrong-header'
- json_results = {}
- for result_type in result_types:
- json_log['summary'][result_type] = []
- # collate results for JSON log
- for name in reports.results:
- result_type = reports.results[name]['result']
- # map fatal-error on to failed since the report adds both to the failed count
- if result_type == "fatal-error":
- result_type = "failed"
- test_parts = name.split("/")
- test_category = test_parts[-2]
- test_name = test_parts[-1]
- if result_type != 'passed':
- json_log['summary'][result_type].append(test_name)
- if test_category not in json_results:
- json_results[test_category] = []
- json_result = {}
- # remove the file extension
- json_result["name"] = test_name.split('.')[0]
- json_result["result"] = result_type
- if result_type == "failed" or result_type == "timeout":
- json_result["output"] = reports.results[name]["output"]
- json_results[test_category].append(json_result)
- # convert results to a better format for report generation
- sorted_keys = sorted(json_results.keys())
- for i in range(len(sorted_keys)):
- results_log = {}
- results_log["index"] = i + 1
- results_log["name"] = sorted_keys[i]
- results_log["results"] = json_results[sorted_keys[i]]
- json_log["test_groups"].append(results_log)
- # write out JSON log
+ data = results_to_data(args, reports, start_time, end_time);
with open(json_file, 'w') as outfile:
- json.dump(json_log, outfile, sort_keys=True, indent=4)
+ json.dump(data, outfile, sort_keys=True, indent=4)
def generate_junit_report(args, reports, start_time, end_time,
@@ -343,97 +315,16 @@ def generate_junit_report(args, reports, start_time, end_time,
def generate_yaml_report(args, reports, start_time, end_time,
- total, yaml_file):
+ _total, yaml_file):
""" Generates a YAML file containing information about the test run,
including all test outputs """
import yaml
- def format_output(output_list):
- return "\n".join(output_list).replace("] ", '').replace('=> ', '')
- yaml_log = {}
- yaml_log['command-line'] = args
- yaml_log['host'] = host.label(mode='all')
- yaml_log['python'] = sys.version.replace('\n', '')
- yaml_log['summary'] = {}
- yaml_log['summary']['passed-count'] = reports.passed
- yaml_log['summary']['failed-count'] = reports.failed
- yaml_log['summary']['user-input-count'] = reports.user_input
- yaml_log['summary']['expected-fail-count'] = reports.expected_fail
- yaml_log['summary']['indeterminate-count'] = reports.indeterminate
- yaml_log['summary']['benchmark-count'] = reports.benchmark
- yaml_log['summary']['timeout-count'] = reports.timeouts
- yaml_log['summary']['test-too-long_count'] = reports.test_too_long
- yaml_log['summary']['invalid-count'] = reports.invalids
- yaml_log['summary']['wrong-version-count'] = reports.wrong_version
- yaml_log['summary']['wrong-build-count'] = reports.wrong_build
- yaml_log['summary']['wrong-tools-count'] = reports.wrong_tools
- yaml_log['summary']['wrong-header-count'] = reports.wrong_header
- yaml_log['summary']['total-count'] = reports.total
- yaml_log['summary']['average-test-time'] = str(time_delta / total)
- yaml_log['summary']['testing-time'] = str(time_delta)
- result_types = [
- yaml_log['summary'][result_type] = []
- result_element = {}
- yaml_log['outputs'] = []
- # process output of each test
- for exe_name in reports.results:
- test_parts = exe_name.split("/")
- result_element['executable-name'] = test_name
- result_element['executable-sha512'] = get_hash512(exe_name)
- result_element['execution-start'] = reports.results[exe_name]['start'].isoformat()
- result_element['execution-end'] = reports.results[exe_name]['end'].isoformat()
- date_diff = reports.results[exe_name]['end'] - reports.results[exe_name]['start']
- result_element['execution-duration'] = str(date_diff)
- result_element['execution-result'] = reports.results[exe_name]['result']
- result_element['bsp'] = reports.results[exe_name]['bsp']
- result_element['bsp-arch'] = reports.results[exe_name]['bsp_arch']
- result_output = reports.results[exe_name]['output']
- dbg_output = []
- test_output = []
- idxs_output = [] # store indices of given substrings
- for elem in result_output:
- if '=> ' in elem:
- idxs_output.append(result_output.index(elem))
- if '*** END' in elem:
- if len(idxs_output) == 3: # test executed and has result
- dbg_output = result_output[idxs_output[0]:idxs_output[1]]
- dbg_output.append("=== Executed Test ===")
- dbg_output = dbg_output + result_output[idxs_output[2]+1:len(result_output)]
- test_output = result_output[idxs_output[1]:idxs_output[2]+1]
- else:
- result_element['debugger-output'] = format_output(dbg_output)
- result_element['console-output'] = format_output(test_output)
- yaml_log['outputs'].append(result_element)
- result_type = reports.results[exe_name]['result']
- # map "fatal-error" on to "failed"
- yaml_log['summary'][result_type].append(test_name)
with open(yaml_file, 'w') as outfile:
- yaml.dump(yaml_log, outfile, default_flow_style=False, allow_unicode=True)
+ yaml.dump(data, outfile, default_flow_style=False, allow_unicode=True)
def get_hash512(exe):
2.35.3
