[PATCH 2/2] aarch64/versal: Support DDRMC0 region 0 and 1
Kinsey Moore kinsey.moore at oarcorp.com
Tue Jul 26 13:47:33 UTC 2022
On 7/22/2022 01:35, chrisj at rtems.org wrote:
> From: Chris Johns <chrisj at rtems.org>
> - Support DDRMC0 region 0 up to 2G in size
> - Support DDRMC0 region 1 with DDR memory greater than 2G
>    up to the DDRMC0 max amount
> - Extend the heap with region 1's memory
> Closes #4684
>   bsps/aarch64/xilinx-versal/include/bsp.h      |  9 ++++
>   bsps/aarch64/xilinx-versal/start/bspstart.c   |  2 +
>   .../aarch64/xilinx-versal/start/bspstartmmu.c | 36 ++++++++++++++
>   .../aarch64/xilinx-versal/linkcmds_lp64.yml   | 48 +++++++++++++++++--
>   4 files changed, 90 insertions(+), 5 deletions(-)
> diff --git a/bsps/aarch64/xilinx-versal/include/bsp.h b/bsps/aarch64/xilinx-versal/include/bsp.h
> index 2017e10ade..0bd93f28bc 100644
> --- a/bsps/aarch64/xilinx-versal/include/bsp.h
> +++ b/bsps/aarch64/xilinx-versal/include/bsp.h
> @@ -47,6 +47,7 @@
>   #ifndef ASM
>   #include <bsp/default-initial-extension.h>
> +#include <bsp/linker-symbols.h>
>   #include <bsp/start.h>
>   #include <rtems.h>
> @@ -61,6 +62,14 @@ extern "C" {
>   #define BSP_RESET_SMC
> + * DDRMC mapping
> +LINKER_SYMBOL(bsp_r0_ram_base)
> +LINKER_SYMBOL(bsp_r0_ram_end)
> +LINKER_SYMBOL(bsp_r1_ram_base)
> +LINKER_SYMBOL(bsp_r1_ram_end)
>    * @brief Versal specific set up of the MMU.
> diff --git a/bsps/aarch64/xilinx-versal/start/bspstart.c b/bsps/aarch64/xilinx-versal/start/bspstart.c
> index 2f0048ddf3..86b3024dd2 100644
> --- a/bsps/aarch64/xilinx-versal/start/bspstart.c
> +++ b/bsps/aarch64/xilinx-versal/start/bspstart.c
> @@ -38,6 +38,8 @@
>   #include <bsp/irq-generic.h>
> +#include <bsp/aarch64-mmu.h>
Unnecessary include? Nothing referencing MMU functionality was added to
this file.
>   void bsp_start( void )
>     bsp_interrupt_initialize();
> diff --git a/bsps/aarch64/xilinx-versal/start/bspstartmmu.c b/bsps/aarch64/xilinx-versal/start/bspstartmmu.c
> index 5949111d0d..c2fcd62c9f 100644
> --- a/bsps/aarch64/xilinx-versal/start/bspstartmmu.c
> +++ b/bsps/aarch64/xilinx-versal/start/bspstartmmu.c
> @@ -38,6 +38,9 @@
>   #include <libcpu/mmu-vmsav8-64.h>
> +#include <rtems/malloc.h>
> +#include <rtems/sysinit.h>
>   BSP_START_DATA_SECTION static const aarch64_mmu_config_entry
>   versal_mmu_config_table[] = {
>     AARCH64_MMU_DEFAULT_SECTIONS,
> @@ -57,6 +60,24 @@ versal_mmu_config_table[] = {
>       .begin = 0xff000000U,
>       .end = 0xffc00000U,
>       .flags = AARCH64_MMU_DEVICE
> +  }, { /* DDRMC0_region1_mem, if not used size is 0 and ignored */
> +    .begin = (uintptr_t) bsp_r1_ram_base,
> +    .end = (uintptr_t) bsp_r1_ram_end,
> +    .flags = AARCH64_MMU_DATA_RW_CACHED
> + * Create an MMU table to get the R1 base and end. This avoids
> + * relocation errors as the R1 addresses are in the upper A64 address
> + * space.
> +static const aarch64_mmu_config_entry
> +bsp_r1_region[] = {
> +  { /* DDRMC0_region1_mem, if not used size is 0 and ignored */
> +    .flags = 0
Is there a reason this data is being repeated over using the data
already in the table above? Even if repeating the data makes it easier,
use of this data structure is a little confusing since it's not being
fed into the MMU routines and setting flags here is unnecessary.
> @@ -78,3 +99,18 @@ versal_setup_mmu_and_cache( void )
>     aarch64_mmu_enable();
> +void bsp_r1_heap_extend(void);
> +  const aarch64_mmu_config_entry* r1 = &bsp_r1_region[0];
> +  if (false && r1->begin != r1->end) {
> +    rtems_heap_extend((void*) r1->begin, r1->end - r1->begin);
> +RTEMS_SYSINIT_ITEM(
> +  bsp_r1_heap_extend,
> +  RTEMS_SYSINIT_MALLOC,
> +  RTEMS_SYSINIT_ORDER_LAST
> diff --git a/spec/build/bsps/aarch64/xilinx-versal/linkcmds_lp64.yml b/spec/build/bsps/aarch64/xilinx-versal/linkcmds_lp64.yml
> index 76c0220f0e..ca353d2662 100644
> --- a/spec/build/bsps/aarch64/xilinx-versal/linkcmds_lp64.yml
> +++ b/spec/build/bsps/aarch64/xilinx-versal/linkcmds_lp64.yml
> @@ -4,7 +4,8 @@ content: |
>     /* SPDX-License-Identifier: BSD-2-Clause */
> -   * Copyright (C) 2021 Gedare Bloom <gedare at rtems.org>
> +   * Copyright (C) 2021 Gedare Bloom <gedare at rtems.org>
> +   * Copyright (C) 2022 Chris Johns <chrisj at rtems.org>
>      * Redistribution and use in source and binary forms, with or without
>      * modification, are permitted provided that the following conditions
> @@ -28,10 +29,41 @@ content: |
>      * POSSIBILITY OF SUCH DAMAGE.
> +   * The RAM supports 32G of DDR4 or LPDDR memory using DDRMC0.
> +   * The DDR Conroller (DDRC) has two regions R0 and R1. R0 is
> +   * in the A32 address space and R1 is in the A64 address space.
> +  DDRMC0_REGION_0_BASE = 0x00000000000;
> +  DDRMC0_REGION_0_LENGTH = 0x00080000000;
> +  DDRMC0_REGION_1_BASE = 0x00800000000;
> +  DDRMC0_REGION_1_LENGTH = 0x01000000000;
> +  BSP_RAM_BASE = ${BSP_XILINX_VERSAL_RAM_BASE};
> +  BSP_R0_RAM_BASE = DDRMC0_REGION_0_BASE;
> +  BSP_R0_RAM_LENGTH =
> +     ${BSP_XILINX_VERSAL_RAM_LENGTH} >= DDRMC0_REGION_0_LENGTH ?
> +         DDRMC0_REGION_0_LENGTH - BSP_RAM_BASE : ${BSP_XILINX_VERSAL_RAM_LENGTH};
> +  BSP_R0_RAM_END = BSP_RAM_BASE + BSP_R0_RAM_LENGTH;
> +  BSP_R1_RAM_BASE = DDRMC0_REGION_1_BASE;
> +  BSP_R1_RAM_LENGTH =
> +         ${BSP_XILINX_VERSAL_RAM_LENGTH} - DDRMC0_REGION_0_LENGTH : 0;
> +  AARCH64_MMU_TT_PAGES_SIZE = 0x1000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES};
>     MEMORY {
> -    RAM       : ORIGIN = ${BSP_XILINX_VERSAL_RAM_BASE} + ${BSP_XILINX_VERSAL_LOAD_OFFSET}, LENGTH = ${BSP_XILINX_VERSAL_RAM_LENGTH} - ${BSP_XILINX_VERSAL_LOAD_OFFSET} - ${BSP_XILINX_VERSAL_NOCACHE_LENGTH} - (0x1000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES})
> -    NOCACHE   : ORIGIN = ${BSP_XILINX_VERSAL_RAM_BASE} + ${BSP_XILINX_VERSAL_RAM_LENGTH} - (0x1000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES}) - ${BSP_XILINX_VERSAL_NOCACHE_LENGTH}, LENGTH = ${BSP_XILINX_VERSAL_NOCACHE_LENGTH}
> -    RAM_MMU   : ORIGIN = ${BSP_XILINX_VERSAL_RAM_BASE} + ${BSP_XILINX_VERSAL_RAM_LENGTH} - (0x1000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES}), LENGTH = 0x1000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES}
> +    RAM       : ORIGIN = BSP_RAM_BASE + ${BSP_XILINX_VERSAL_LOAD_OFFSET},
> +                LENGTH = BSP_R0_RAM_LENGTH - ${BSP_XILINX_VERSAL_LOAD_OFFSET} - ${BSP_XILINX_VERSAL_NOCACHE_LENGTH} - AARCH64_MMU_TT_PAGES_SIZE
> +    RAM1      : ORIGIN = BSP_R1_RAM_BASE,
> +                LENGTH = BSP_R1_RAM_LENGTH
> +    NOCACHE   : ORIGIN = BSP_RAM_BASE + BSP_R0_RAM_LENGTH - AARCH64_MMU_TT_PAGES_SIZE - ${BSP_XILINX_VERSAL_NOCACHE_LENGTH},
> +                LENGTH = ${BSP_XILINX_VERSAL_NOCACHE_LENGTH}
> +    RAM_MMU   : ORIGIN = BSP_R0_RAM_END - AARCH64_MMU_TT_PAGES_SIZE,
> +                LENGTH = AARCH64_MMU_TT_PAGES_SIZE
>     REGION_ALIAS ("REGION_START",          RAM);
> @@ -58,6 +90,11 @@ content: |
>     bsp_vector_table_in_start_section = 1;
> +  bsp_r0_ram_base = DDRMC0_REGION_0_BASE;
> +  bsp_r0_ram_end = ORIGIN (RAM) + LENGTH (RAM);
> +  bsp_r1_ram_base = ORIGIN (RAM1);
> +  bsp_r1_ram_end = ORIGIN (RAM1) + LENGTH (RAM1);
>     bsp_translation_table_base = ORIGIN (RAM_MMU);
>     bsp_translation_table_end = ORIGIN (RAM_MMU) + LENGTH (RAM_MMU);
> @@ -66,7 +103,8 @@ content: |
>     INCLUDE linkcmds.base
>   copyrights:
> -- Copyright (C) 2021 Gedare Bloom <gedare at rtems.org>
> +- Copyright (C) 2021 Gedare Bloom <gedare at rtems.org>
> +- Copyright (C) 2022 Chris Johns <chrisj at rtems.org>
>   enabled-by: true
>   install-path: ${BSP_LIBDIR}
>   links: []
