[PATCH v3 2/2] aarch64/versal: Support DDRMC0 region 0 and 1
chrisj at rtems.org
chrisj at rtems.org
Wed Jul 27 03:13:22 UTC 2022
- Support DDRMC0 region 0 up to 2G in size
- Support DDRMC0 region 1 with DDR memory greater than 2G
up to the DDRMC0 max amount
- Extend the heap with region 1's memory
Closes #4684
bsps/aarch64/xilinx-versal/include/bsp.h | 9 ++++
.../aarch64/xilinx-versal/start/bspstartmmu.c | 49 +++++++++++++++++++
bsps/include/bsp/fatal.h | 1 +
.../aarch64/xilinx-versal/linkcmds_lp64.yml | 48 ++++++++++++++++--
4 files changed, 102 insertions(+), 5 deletions(-)
diff --git a/bsps/aarch64/xilinx-versal/include/bsp.h b/bsps/aarch64/xilinx-versal/include/bsp.h
index 2017e10ade..0bd93f28bc 100644
--- a/bsps/aarch64/xilinx-versal/include/bsp.h
+++ b/bsps/aarch64/xilinx-versal/include/bsp.h
@@ -47,6 +47,7 @@
#ifndef ASM
#include <bsp/default-initial-extension.h>
+#include <bsp/linker-symbols.h>
#include <bsp/start.h>
@@ -61,6 +62,14 @@ extern "C" {
#define BSP_RESET_SMC
+ * DDRMC mapping
+LINKER_SYMBOL(bsp_r0_ram_base)
+LINKER_SYMBOL(bsp_r0_ram_end)
+LINKER_SYMBOL(bsp_r1_ram_base)
+LINKER_SYMBOL(bsp_r1_ram_end)
* @brief Versal specific set up of the MMU.
diff --git a/bsps/aarch64/xilinx-versal/start/bspstartmmu.c b/bsps/aarch64/xilinx-versal/start/bspstartmmu.c
index 5949111d0d..b2da3bc60d 100644
--- a/bsps/aarch64/xilinx-versal/start/bspstartmmu.c
+++ b/bsps/aarch64/xilinx-versal/start/bspstartmmu.c
@@ -38,6 +38,9 @@
#include <bsp/aarch64-mmu.h>
#include <libcpu/mmu-vmsav8-64.h>
+#include <rtems/malloc.h>
+#include <rtems/sysinit.h>
BSP_START_DATA_SECTION static const aarch64_mmu_config_entry
versal_mmu_config_table[] = {
AARCH64_MMU_DEFAULT_SECTIONS,
@@ -57,6 +60,29 @@ versal_mmu_config_table[] = {
.begin = 0xff000000U,
.end = 0xffc00000U,
.flags = AARCH64_MMU_DEVICE
+ }, { /* DDRMC0_region1_mem, if not used size is 0 and ignored */
+ .begin = (uintptr_t) bsp_r1_ram_base,
+ .end = (uintptr_t) bsp_r1_ram_end,
+ .flags = AARCH64_MMU_DATA_RW_CACHED
+ * Create an MMU table to get the R1 base and end. This avoids
+ * relocation errors as the R1 addresses are in the upper A64 address
+ * space.
+ * The versal_mmu_config_table table cannot be used because the regions
+ * in that table have no identifiers to indicate which region is the
+ * the DDRMC0_region1_mem region.
+static const struct mem_region {
+ uintptr_t begin;
+ uintptr_t end;
+} bsp_r1_region[] = {
+ { /* DDRMC0_region1_mem, if not used size is 0 and ignored */
@@ -78,3 +104,26 @@ versal_setup_mmu_and_cache( void )
aarch64_mmu_enable();
+void bsp_r1_heap_extend(void);
+ const struct mem_region* r1 = &bsp_r1_region[0];
+ if (r1->begin != r1->end) {
+ rtems_status_code sc =
+ rtems_heap_extend((void*) r1->begin, r1->end - r1->begin);
+ if (sc != RTEMS_SUCCESSFUL) {
+ bsp_fatal(BSP_FATAL_HEAP_EXTEND_ERROR);
+ * Initialise after the IDLE thread exists so the protected heap
+ * extend call has a valid context.
+RTEMS_SYSINIT_ITEM(
+ bsp_r1_heap_extend,
+ RTEMS_SYSINIT_IDLE_THREADS,
+ RTEMS_SYSINIT_ORDER_LAST
diff --git a/bsps/include/bsp/fatal.h b/bsps/include/bsp/fatal.h
index e37e47d7ed..f350fe9f48 100644
--- a/bsps/include/bsp/fatal.h
+++ b/bsps/include/bsp/fatal.h
@@ -73,6 +73,7 @@ typedef enum {
BSP_FATAL_CONSOLE_INSTALL_1,
BSP_FATAL_CONSOLE_REGISTER_DEV_2,
BSP_FATAL_MMU_ADDRESS_INVALID,
+ BSP_FATAL_HEAP_EXTEND_ERROR,
/* ARM fatal codes */
BSP_ARM_A9MPCORE_FATAL_CLOCK_IRQ_INSTALL = BSP_FATAL_CODE_BLOCK(1),
diff --git a/spec/build/bsps/aarch64/xilinx-versal/linkcmds_lp64.yml b/spec/build/bsps/aarch64/xilinx-versal/linkcmds_lp64.yml
index 76c0220f0e..ca353d2662 100644
--- a/spec/build/bsps/aarch64/xilinx-versal/linkcmds_lp64.yml
+++ b/spec/build/bsps/aarch64/xilinx-versal/linkcmds_lp64.yml
@@ -4,7 +4,8 @@ content: |
/* SPDX-License-Identifier: BSD-2-Clause */
- * Copyright (C) 2021 Gedare Bloom <gedare at rtems.org>
+ * Copyright (C) 2021 Gedare Bloom <gedare at rtems.org>
+ * Copyright (C) 2022 Chris Johns <chrisj at rtems.org>
* modification, are permitted provided that the following conditions
@@ -28,10 +29,41 @@ content: |
* POSSIBILITY OF SUCH DAMAGE.
+ * The RAM supports 32G of DDR4 or LPDDR memory using DDRMC0.
+ * The DDR Conroller (DDRC) has two regions R0 and R1. R0 is
+ * in the A32 address space and R1 is in the A64 address space.
+ DDRMC0_REGION_0_BASE = 0x00000000000;
+ DDRMC0_REGION_0_LENGTH = 0x00080000000;
+ DDRMC0_REGION_1_BASE = 0x00800000000;
+ DDRMC0_REGION_1_LENGTH = 0x01000000000;
+ BSP_RAM_BASE = ${BSP_XILINX_VERSAL_RAM_BASE};
+ BSP_R0_RAM_BASE = DDRMC0_REGION_0_BASE;
+ BSP_R0_RAM_LENGTH =
+ ${BSP_XILINX_VERSAL_RAM_LENGTH} >= DDRMC0_REGION_0_LENGTH ?
+ DDRMC0_REGION_0_LENGTH - BSP_RAM_BASE : ${BSP_XILINX_VERSAL_RAM_LENGTH};
+ BSP_R0_RAM_END = BSP_RAM_BASE + BSP_R0_RAM_LENGTH;
+ BSP_R1_RAM_BASE = DDRMC0_REGION_1_BASE;
+ BSP_R1_RAM_LENGTH =
+ ${BSP_XILINX_VERSAL_RAM_LENGTH} - DDRMC0_REGION_0_LENGTH : 0;
+ AARCH64_MMU_TT_PAGES_SIZE = 0x1000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES};
MEMORY {
- RAM : ORIGIN = ${BSP_XILINX_VERSAL_RAM_BASE} + ${BSP_XILINX_VERSAL_LOAD_OFFSET}, LENGTH = ${BSP_XILINX_VERSAL_RAM_LENGTH} - ${BSP_XILINX_VERSAL_LOAD_OFFSET} - ${BSP_XILINX_VERSAL_NOCACHE_LENGTH} - (0x1000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES})
- NOCACHE : ORIGIN = ${BSP_XILINX_VERSAL_RAM_BASE} + ${BSP_XILINX_VERSAL_RAM_LENGTH} - (0x1000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES}) - ${BSP_XILINX_VERSAL_NOCACHE_LENGTH}, LENGTH = ${BSP_XILINX_VERSAL_NOCACHE_LENGTH}
- RAM_MMU : ORIGIN = ${BSP_XILINX_VERSAL_RAM_BASE} + ${BSP_XILINX_VERSAL_RAM_LENGTH} - (0x1000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES}), LENGTH = 0x1000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES}
+ RAM : ORIGIN = BSP_RAM_BASE + ${BSP_XILINX_VERSAL_LOAD_OFFSET},
+ LENGTH = BSP_R0_RAM_LENGTH - ${BSP_XILINX_VERSAL_LOAD_OFFSET} - ${BSP_XILINX_VERSAL_NOCACHE_LENGTH} - AARCH64_MMU_TT_PAGES_SIZE
+ RAM1 : ORIGIN = BSP_R1_RAM_BASE,
+ LENGTH = BSP_R1_RAM_LENGTH
+ NOCACHE : ORIGIN = BSP_RAM_BASE + BSP_R0_RAM_LENGTH - AARCH64_MMU_TT_PAGES_SIZE - ${BSP_XILINX_VERSAL_NOCACHE_LENGTH},
+ LENGTH = ${BSP_XILINX_VERSAL_NOCACHE_LENGTH}
+ RAM_MMU : ORIGIN = BSP_R0_RAM_END - AARCH64_MMU_TT_PAGES_SIZE,
+ LENGTH = AARCH64_MMU_TT_PAGES_SIZE
REGION_ALIAS ("REGION_START", RAM);
@@ -58,6 +90,11 @@ content: |
bsp_vector_table_in_start_section = 1;
+ bsp_r0_ram_base = DDRMC0_REGION_0_BASE;
+ bsp_r0_ram_end = ORIGIN (RAM) + LENGTH (RAM);
+ bsp_r1_ram_base = ORIGIN (RAM1);
+ bsp_r1_ram_end = ORIGIN (RAM1) + LENGTH (RAM1);
bsp_translation_table_base = ORIGIN (RAM_MMU);
bsp_translation_table_end = ORIGIN (RAM_MMU) + LENGTH (RAM_MMU);
@@ -66,7 +103,8 @@ content: |
INCLUDE linkcmds.base
copyrights:
-- Copyright (C) 2021 Gedare Bloom <gedare at rtems.org>
+- Copyright (C) 2021 Gedare Bloom <gedare at rtems.org>
+- Copyright (C) 2022 Chris Johns <chrisj at rtems.org>
enabled-by: true
install-path: ${BSP_LIBDIR}
links: []
2.19.1
