[PATCH] c-user: Document new rtems_task_delete() behaviour
Chris Johns
chrisj at rtems.org
Wed Jul 27 03:37:59 UTC 2022
On 26/7/2022 8:07 pm, Sebastian Huber wrote:
> Update #4679.
> c-user/task/directives.rst | 29 +++++++++++++++++++++++------
> 1 file changed, 23 insertions(+), 6 deletions(-)
> diff --git a/c-user/task/directives.rst b/c-user/task/directives.rst
> index 64b591d..9f9ea45 100644
> --- a/c-user/task/directives.rst
> +++ b/c-user/task/directives.rst
> @@ -805,16 +805,28 @@ specified by ``id``.
> :c:macro:`RTEMS_CALLED_FROM_ISR`
> The directive was called from within interrupt context.
> +:c:macro:`RTEMS_INCORRECT_STATE`
> + The task termination procedure was started, however, waiting for the
> + terminating task would have resulted in a deadlock.
The process is synchronous if the task is not deleting itself?
> :c:macro:`RTEMS_ILLEGAL_ON_REMOTE_OBJECT`
> The task resided on a remote node.
> .. rubric:: NOTES:
> -RTEMS stops the execution of the task and reclaims the stack memory, any
> -allocated delay or timeout timers, the TCB, and, if the task is
> -:c:macro:`RTEMS_FLOATING_POINT`, its floating point context area. RTEMS
> -explicitly does not reclaim the following resources: region segments, partition
> -buffers, semaphores, timers, or rate monotonic periods.
> +The task deletion is done in several steps. Firstly, the task is marked as
> +terminating. While the task life of the terminating task is protected, it
> +executes normally until it disables the task life protection or it deletes
> +itself.
I do not understand this last sentence. How does a task executing normally
disable it's task life protection?
What is task life protection?
> A terminating task will eventually stop its normal execution and start
> +its termination procedure.
Is the context when the task is not deleting itself?
> The procedure executes in the context of the
> +terminating task.
I assume from above this is synchronous? When is the deleting task dispatched to
run?
> It involves the destruction of POSIX key values and running
> the task termination user extensions.
It? What about:
"The task termination procedure involves the destruction of POSIX
key values and running the task termination user extensions."
> Once the task termination procedure is
"Once complete the execution of the task is stopped and ..."
> +done, the execution of the task is stopped and task-specific resources are
> +reclaimed by the system, such as the stack memory, any allocated delay or
> +timeout timers, the TCB, and, if the task is :c:macro:`RTEMS_FLOATING_POINT`,
> +its floating point context area. RTEMS explicitly does not reclaim the
> +following resources: region segments, partition buffers, semaphores, timers, or
> +rate monotonic periods.
> A task is responsible for releasing its resources back to RTEMS before
> deletion. To insure proper deallocation of resources, a task should not be
> @@ -824,11 +836,16 @@ resources before deletion. A task can be directed to release its resources and
> delete itself by restarting it with a special argument or by sending it a
> message, an event, or a signal.
> -Deletion of the current task (:c:macro:`RTEMS_SELF`) will force RTEMS to select
> +Deletion of the calling task (:c:macro:`RTEMS_SELF`) will force RTEMS to select
> another task to execute.
What about SMP? If the calling task is deleting a task running on another core?
The language is hard here. I am not sure what works.
> The :term:`TCB` for the deleted task is reclaimed by RTEMS.
> +When a task other than the calling task is deleted, the calling task waits
"When a task is deleting another task the task calling delete waits ..."?
> +until the task termination procedure of the other task is done. The
"until the task termination procedure of the task being delete has completed."?
> +terminating task inherits the :term:`eligible priorities <eligible priority>`
> +of the calling task.
Inherits when terminating?
So it is synchronous. Maybe this could be mentioned before now.
