[PATCH v2 2/2] c-user: Document new rtems_task_delete() behaviour
Sebastian Huber
Wed Jul 27 09:30:11 UTC 2022
Update #4679.
c-user/task/directives.rst | 25 ++++++++++++++++++++-----
1 file changed, 20 insertions(+), 5 deletions(-)
diff --git a/c-user/task/directives.rst b/c-user/task/directives.rst
index 64b591d..b78aaa9 100644
--- a/c-user/task/directives.rst
+++ b/c-user/task/directives.rst
@@ -805,14 +805,26 @@ specified by ``id``.
:c:macro:`RTEMS_CALLED_FROM_ISR`
The directive was called from within interrupt context.
+:c:macro:`RTEMS_INCORRECT_STATE`
+ The task termination procedure was started, however, waiting for the
+ terminating task would have resulted in a deadlock.
:c:macro:`RTEMS_ILLEGAL_ON_REMOTE_OBJECT`
The task resided on a remote node.
.. rubric:: NOTES:
-RTEMS stops the execution of the task and reclaims the stack memory, any
-allocated delay or timeout timers, the TCB, and, if the task is
-:c:macro:`RTEMS_FLOATING_POINT`, its floating point context area. RTEMS
+The task deletion is done in several steps. Firstly, the task is marked as
+terminating. While the task life of the terminating task is protected, it
+executes normally until it disables the task life protection or it deletes
+itself. A terminating task will eventually stop its normal execution and start
+its termination procedure. The procedure executes in the context of the
+terminating task. The task termination procedure involves the destruction of
+POSIX key values and running the task termination user extensions. Once
+complete the execution of the task is stopped and task-specific resources are
+reclaimed by the system, such as the stack memory, any allocated delay or
+timeout timers, the :term:`TCB`, and, if the task is
+:c:macro:`RTEMS_FLOATING_POINT`, its floating point context area. RTEMS
explicitly does not reclaim the following resources: region segments, partition
buffers, semaphores, timers, or rate monotonic periods.
@@ -824,10 +836,13 @@ resources before deletion. A task can be directed to release its resources and
delete itself by restarting it with a special argument or by sending it a
message, an event, or a signal.
-Deletion of the current task (:c:macro:`RTEMS_SELF`) will force RTEMS to select
+Deletion of the calling task (:c:macro:`RTEMS_SELF`) will force RTEMS to select
another task to execute.
-The :term:`TCB` for the deleted task is reclaimed by RTEMS.
+When a task deletes another task, the calling task waits until the task
+termination procedure of the task being deleted has completed. The terminating
+task inherits the :term:`eligible priorities <eligible priority>` of the
+calling task.
When a global task is deleted, the task identifier must be transmitted to every
node in the system for deletion from the local copy of the global object table.
2.35.3
