[PATCH] libdl: Refactor shared code in Arm and AArch64
Ryan Long ryan.long at oarcorp.com
Thu Jul 28 15:04:09 UTC 2022
rtl-mdreloc-arm.c was used as the basis for rtl-mdreloc-aarch64.c. This lead
to some code being shared by the two files. The code was consolidated into
rtl-unwind-arm.c.
Closes #4686
 cpukit/libdl/rtl-mdreloc-aarch64.c | 79 +-----------------------------
 cpukit/libdl/rtl-mdreloc-arm.c     | 79 +-----------------------------
 cpukit/libdl/rtl-unwind-arm.c      | 69 ++++++++++++++++++++++++++
 cpukit/libdl/rtl-unwind-arm.h      | 46 +++++++++++++++++
 spec/build/cpukit/objdlaarch64.yml |  1 +
 spec/build/cpukit/objdlarm.yml     |  1 +
 6 files changed, 119 insertions(+), 156 deletions(-)
 create mode 100644 cpukit/libdl/rtl-unwind-arm.c
 create mode 100644 cpukit/libdl/rtl-unwind-arm.h
diff --git a/cpukit/libdl/rtl-mdreloc-aarch64.c b/cpukit/libdl/rtl-mdreloc-aarch64.c
index 3b1bbff2d2..738c9eba70 100644
--- a/cpukit/libdl/rtl-mdreloc-aarch64.c
+++ b/cpukit/libdl/rtl-mdreloc-aarch64.c
@@ -73,16 +73,12 @@ __RCSID("$NetBSD: mdreloc.c,v 1.14 2020/06/16 21:01:30 joerg Exp $");
 #include <inttypes.h>
 #include <sys/stat.h>
 #include <sys/endian.h>
-#include <unwind.h>
 #include <rtems/rtl/rtl.h>
 #include "rtl-elf.h"
 #include "rtl-error.h"
 #include <rtems/rtl/rtl-trace.h>
-#include "rtl-unwind.h"
-typedef unsigned _Unwind_Word __attribute__((__mode__(__word__)));
-typedef _Unwind_Word _uw;
+#include "rtl-unwind-arm.h"
 struct tls_data {
   size_t    td_tlsindex;
@@ -523,76 +519,3 @@ rtems_rtl_elf_relocate_rel (rtems_rtl_obj*            obj,
   return rtems_rtl_elf_rel_failure;
-bool
-rtems_rtl_elf_unwind_parse (const rtems_rtl_obj* obj,
-                            const char*          name,
-                            uint32_t             flags)
-   * We location the EH sections in section flags.
-  return false;
-bool
-rtems_rtl_elf_unwind_register (rtems_rtl_obj* obj)
-  return true;
-bool
-rtems_rtl_elf_unwind_deregister (rtems_rtl_obj* obj)
-  return true;
-/* An exception index table entry.  */
-typedef struct __EIT_entry
-  _uw fnoffset;
-  _uw content;
-} __EIT_entry;
-/* The exception index table location in the base module */
-extern __EIT_entry __exidx_start;
-extern __EIT_entry __exidx_end;
- * A weak reference is in libgcc, provide a real version and provide a way to
- * manage loaded modules.
- * Passed in the return address and a reference to the number of records
- * found. We set the start of the exidx data and the number of records.
-_Unwind_Ptr __gnu_Unwind_Find_exidx (_Unwind_Ptr return_address,
-                                     int*        nrec) __attribute__ ((__noinline__,
-        __used__,
-        __noclone__));
-                                     int*        nrec)
-  rtems_rtl_data*   rtl;
-  rtems_chain_node* node;
-  __EIT_entry*      exidx_start = &__exidx_start;
-  __EIT_entry*      exidx_end = &__exidx_end;
-  rtl = rtems_rtl_lock ();
-  node = rtems_chain_first (&rtl->objects);
-  while (!rtems_chain_is_tail (&rtl->objects, node)) {
-    rtems_rtl_obj* obj = (rtems_rtl_obj*) node;
-    if (rtems_rtl_obj_text_inside (obj, (void*) return_address)) {
-      exidx_start = (__EIT_entry*) obj->eh_base;
-      exidx_end = (__EIT_entry*) (obj->eh_base + obj->eh_size);
-      break;
-    node = rtems_chain_next (node);
-  rtems_rtl_unlock ();
-  *nrec = exidx_end - exidx_start;
-  return (_Unwind_Ptr) exidx_start;
diff --git a/cpukit/libdl/rtl-mdreloc-arm.c b/cpukit/libdl/rtl-mdreloc-arm.c
index 4950dcdab1..fbfd42dc58 100644
--- a/cpukit/libdl/rtl-mdreloc-arm.c
+++ b/cpukit/libdl/rtl-mdreloc-arm.c
@@ -12,14 +12,12 @@
 #include <sys/types.h>
-#include <unwind-arm-common.h>
  * Set to 1 to allow untested relocations. If you tested one and it
@@ -597,78 +595,3 @@ rtems_rtl_elf_relocate_rel (rtems_rtl_obj*            obj,
                                   symvalue,
                                   false);
-bool
-                            const char*          name,
-                            uint32_t             flags)
-  return false;
-bool
-  return true;
-bool
-  obj->loader = NULL;
-  return true;
-  _uw fnoffset;
-  _uw content;
-} __EIT_entry;
-        __used__,
-        __noclone__));
-                                     int*        nrec)
-      break;
diff --git a/cpukit/libdl/rtl-unwind-arm.c b/cpukit/libdl/rtl-unwind-arm.c
new file mode 100644
index 0000000000..a496fb3793
--- /dev/null
+++ b/cpukit/libdl/rtl-unwind-arm.c
@@ -0,0 +1,69 @@
+bool
+rtems_rtl_elf_unwind_parse (const rtems_rtl_obj* obj,
+                            const char*          name,
+                            uint32_t             flags)
+   * We location the EH sections in section flags.
+  return false;
+bool
+rtems_rtl_elf_unwind_register (rtems_rtl_obj* obj)
+  return true;
+bool
+rtems_rtl_elf_unwind_deregister (rtems_rtl_obj* obj)
+  return true;
+/* The exception index table location in the base module */
+extern __EIT_entry __exidx_start;
+extern __EIT_entry __exidx_end;
+ * A weak reference is in libgcc, provide a real version and provide a way to
+ * manage loaded modules.
+ * Passed in the return address and a reference to the number of records
+ * found. We set the start of the exidx data and the number of records.
+_Unwind_Ptr
+__gnu_Unwind_Find_exidx (_Unwind_Ptr return_address,
+                         int*        nrec) __attribute__ ((__noinline__,
+                                                           __used__,
+                                                           __noclone__));
+_Unwind_Ptr __gnu_Unwind_Find_exidx (_Unwind_Ptr return_address,
+                                     int*        nrec)
+  rtems_rtl_data*   rtl;
+  rtems_chain_node* node;
+  __EIT_entry*      exidx_start = &__exidx_start;
+  __EIT_entry*      exidx_end = &__exidx_end;
+  rtl = rtems_rtl_lock ();
+  node = rtems_chain_first (&rtl->objects);
+  while (!rtems_chain_is_tail (&rtl->objects, node)) {
+    rtems_rtl_obj* obj = (rtems_rtl_obj*) node;
+    if (rtems_rtl_obj_text_inside (obj, (void*) return_address)) {
+      exidx_start = (__EIT_entry*) obj->eh_base;
+      exidx_end = (__EIT_entry*) (obj->eh_base + obj->eh_size);
+      break;
+    node = rtems_chain_next (node);
+  rtems_rtl_unlock ();
+  *nrec = exidx_end - exidx_start;
+  return (_Unwind_Ptr) exidx_start;
diff --git a/cpukit/libdl/rtl-unwind-arm.h b/cpukit/libdl/rtl-unwind-arm.h
index 0000000000..08a2660560
--- /dev/null
+++ b/cpukit/libdl/rtl-unwind-arm.h
@@ -0,0 +1,46 @@
+#include <unwind.h>
+#include <rtems/rtl/rtl.h>
+#include "rtl-unwind.h"
+typedef unsigned _Unwind_Word __attribute__((__mode__(__word__)));
+typedef _Unwind_Word _uw;
+bool
+                            const char*          name,
+                            uint32_t             flags);
+bool
+rtems_rtl_elf_unwind_register (rtems_rtl_obj* obj);
+bool
+rtems_rtl_elf_unwind_deregister (rtems_rtl_obj* obj);
+/* An exception index table entry.  */
+typedef struct __EIT_entry
+  _uw fnoffset;
+  _uw content;
+} __EIT_entry;
+_Unwind_Ptr
+                                                           __used__,
+                                                           __noclone__));
+_Unwind_Ptr
+                         int*        nrec);
diff --git a/spec/build/cpukit/objdlaarch64.yml b/spec/build/cpukit/objdlaarch64.yml
index 2909a902f2..1715eefd3a 100644
--- a/spec/build/cpukit/objdlaarch64.yml
+++ b/spec/build/cpukit/objdlaarch64.yml
@@ -12,4 +12,5 @@ install: []
 links: []
 source:
 - cpukit/libdl/rtl-mdreloc-aarch64.c
+- cpukit/libdl/rtl-unwind-arm.c
 type: build
diff --git a/spec/build/cpukit/objdlarm.yml b/spec/build/cpukit/objdlarm.yml
index 6edb3653f2..f3e1d37668 100644
--- a/spec/build/cpukit/objdlarm.yml
+++ b/spec/build/cpukit/objdlarm.yml
 links: []
 source:
 - cpukit/libdl/rtl-mdreloc-arm.c
 type: build
2.30.2
