[PATCH v5 1/4] bsps/stm32f4 Include STM32F4 HAL
oss at c-mauderer.de oss at c-mauderer.de
Sat Jul 30 14:32:47 UTC 2022
Hello Duc,
general note for the patch: Please write in the commit message where you
got the sources from. That can be a link to a github repo including a
commit ID or a link to the zip file from ST (including a date, version
or similar information). If you moved some stuff around compared to the
original structure: Please describe about what you did. For example in
the imxrt I just added the cp commands that I used:
https://git.rtems.org/rtems/commit/bsps/arm/imxrt?id=48f6a6c302a3e1a3f8915e2503d0fe618d1af285
Not the best solution but at least someone else can find out roughly
what I did.
Am 24.07.22 um 14:01 schrieb Duc Doan:
> This patch is too large so I cannot send via email. Please find it here:
> https://github.com/dtbpkmte/GSoC-2022-RTEMS/commit/6f1fbc7dd7a5e0877d8bff11e1b21558928dbc16
>   .gitignore                                    |     1 +
You added a "patches" directory to the gitignore. That looks like a
change that is specific to your method of working. These kind of changes
should normall not be pushed.
If you want to ignore stuff specific to your work environment, I
recommend to use a global .gitignore file. Git has a "core.excludesfile"
config for that.
>   bsps/arm/include/cmsis_compiler.h             |   266 +
>   bsps/arm/include/cmsis_gcc.h                  |  3460 +--
>   bsps/arm/include/cmsis_version.h              |    39 +
>   bsps/arm/include/core_cm4.h                   |   524 +-
>   bsps/arm/include/core_cm7.h                   |  5186 ++--
>   bsps/arm/include/mpu_armv7.h                  |   270 +
Are the cmsis files from the same source or directly from ARM?
The cmsis_gcc.h has a lot of changes compared to the earlier version
that has been present in RTEMS. A lot of the changes seem to be
whitespace changes. Can these be avoided somehow (for example by using
dos2unix before overwriting the file)?
In the discord chat there was one suggestion from Ho Kaido to move the
files one level down and make them BSP specific. I'm not sure whether
I'm for or against that idea. Advantage is that it makes BSPs
independant from each other. Disadvantage is that it duplicates code.
I think I would try to avoid moving them down due to the code
duplication but it raises the question: Which BSPs use the files too and
did you try whether they still compile after the upgrade?
>   .../stm32f4/hal/Legacy/stm32f4xx_hal_can.c    |  1679 ++
>   .../stm32f4/hal/Legacy/stm32f4xx_hal_eth.c    |  2307 ++
>   bsps/arm/stm32f4/hal/stm32f4xx_hal.c          |   615 +
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_adc.c      |  2110 ++
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_adc_ex.c   |  1112 +
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_can.c      |  2462 ++
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_cec.c      |   996 +
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_cortex.c   |   502 +
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_crc.c      |   328 +
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_cryp.c     |  7132 ++++++
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_cryp_ex.c  |   680 +
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_dac.c      |  1341 +
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_dac_ex.c   |   495 +
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_dcmi.c     |  1161 +
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_dcmi_ex.c  |   182 +
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_dfsdm.c    |  4423 ++++
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_dma.c      |  1305 +
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_dma2d.c    |  2126 ++
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_dma_ex.c   |   313 +
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_dsi.c      |  2760 +++
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_eth.c      |  3220 +++
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_exti.c     |   547 +
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_flash.c    |   775 +
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_flash_ex.c |  1347 +
>   .../stm32f4/hal/stm32f4xx_hal_flash_ramfunc.c |   172 +
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_fmpi2c.c   |  6864 ++++++
>   .../arm/stm32f4/hal/stm32f4xx_hal_fmpi2c_ex.c |   258 +
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_fmpsmbus.c |  2749 +++
>   .../stm32f4/hal/stm32f4xx_hal_fmpsmbus_ex.c   |   145 +
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_gpio.c     |   533 +
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_hash.c     |  3514 +++
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_hash_ex.c  |  1040 +
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_hcd.c      |  1728 ++
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_i2c.c      |  7524 ++++++
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_i2c_ex.c   |   182 +
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_i2s.c      |  2094 ++
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_i2s_ex.c   |  1135 +
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_irda.c     |  2687 ++
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_iwdg.c     |   262 +
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_lptim.c    |  2484 ++
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_ltdc.c     |  2215 ++
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_ltdc_ex.c  |   151 +
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_mmc.c      |  3201 +++
>   .../stm32f4/hal/stm32f4xx_hal_msp_template.c  |   100 +
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_nand.c     |  2405 ++
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_nor.c      |  1543 ++
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_pccard.c   |   946 +
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_pcd.c      |  2387 ++
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_pcd_ex.c   |   341 +
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_pwr.c      |   571 +
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_pwr_ex.c   |   600 +
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_qspi.c     |  2915 +++
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_rcc.c      |  1122 +
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_rcc_ex.c   |  3784 +++
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_rng.c      |   867 +
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_rtc.c      |  1896 ++
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_rtc_ex.c   |  1878 ++
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_sai.c      |  2554 ++
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_sai_ex.c   |   310 +
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_sd.c       |  3277 +++
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_sdram.c    |  1308 +
>   .../arm/stm32f4/hal/stm32f4xx_hal_smartcard.c |  2364 ++
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_smbus.c    |  2784 +++
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_spdifrx.c  |  1627 ++
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_spi.c      |  3915 +++
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_sram.c     |  1110 +
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_tim.c      |  7621 ++++++
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_tim_ex.c   |  2428 ++
>   ...tm32f4xx_hal_timebase_rtc_alarm_template.c |   318 +
>   ...m32f4xx_hal_timebase_rtc_wakeup_template.c |   293 +
>   .../hal/stm32f4xx_hal_timebase_tim_template.c |   177 +
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_uart.c     |  3751 +++
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_usart.c    |  2838 +++
>   bsps/arm/stm32f4/hal/stm32f4xx_hal_wwdg.c     |   420 +
>   bsps/arm/stm32f4/hal/stm32f4xx_ll_adc.c       |   922 +
>   bsps/arm/stm32f4/hal/stm32f4xx_ll_crc.c       |   103 +
>   bsps/arm/stm32f4/hal/stm32f4xx_ll_dac.c       |   280 +
>   bsps/arm/stm32f4/hal/stm32f4xx_ll_dma.c       |   423 +
>   bsps/arm/stm32f4/hal/stm32f4xx_ll_dma2d.c     |   594 +
>   bsps/arm/stm32f4/hal/stm32f4xx_ll_exti.c      |   212 +
>   bsps/arm/stm32f4/hal/stm32f4xx_ll_fmc.c       |  1498 ++
>   bsps/arm/stm32f4/hal/stm32f4xx_ll_fmpi2c.c    |   217 +
>   bsps/arm/stm32f4/hal/stm32f4xx_ll_fsmc.c      |  1062 +
>   bsps/arm/stm32f4/hal/stm32f4xx_ll_gpio.c      |   303 +
>   bsps/arm/stm32f4/hal/stm32f4xx_ll_i2c.c       |   251 +
>   bsps/arm/stm32f4/hal/stm32f4xx_ll_lptim.c     |   301 +
>   bsps/arm/stm32f4/hal/stm32f4xx_ll_pwr.c       |    81 +
>   bsps/arm/stm32f4/hal/stm32f4xx_ll_rcc.c       |  1660 ++
>   bsps/arm/stm32f4/hal/stm32f4xx_ll_rng.c       |   111 +
>   bsps/arm/stm32f4/hal/stm32f4xx_ll_rtc.c       |   838 +
>   bsps/arm/stm32f4/hal/stm32f4xx_ll_sdmmc.c     |  1578 ++
>   bsps/arm/stm32f4/hal/stm32f4xx_ll_spi.c       |   624 +
>   bsps/arm/stm32f4/hal/stm32f4xx_ll_tim.c       |  1189 +
>   bsps/arm/stm32f4/hal/stm32f4xx_ll_usart.c     |   500 +
>   bsps/arm/stm32f4/hal/stm32f4xx_ll_usb.c       |  2224 ++
>   bsps/arm/stm32f4/hal/stm32f4xx_ll_utils.c     |   749 +
>   bsps/arm/stm32f4/hal/system_stm32f4xx.c       |   747 +
>   .../stm32f4/include/Legacy/stm32_hal_legacy.h |  4014 +++
>   .../include/Legacy/stm32f4xx_hal_can_legacy.h |   765 +
>   .../include/Legacy/stm32f4xx_hal_eth_legacy.h |  2209 ++
>   bsps/arm/stm32f4/include/bsp.h                |     4 +
>   bsps/arm/stm32f4/include/bsp/io.h             |     4 +
>   bsps/arm/stm32f4/include/stm32f401xc.h        |  8641 +++++++
>   bsps/arm/stm32f4/include/stm32f401xe.h        |  8641 +++++++
>   bsps/arm/stm32f4/include/stm32f405xx.h        | 14310 +++++++++++
>   bsps/arm/stm32f4/include/stm32f407xx.h        | 15607 ++++++++++++
>   bsps/arm/stm32f4/include/stm32f410cx.h        |  7357 ++++++
>   bsps/arm/stm32f4/include/stm32f410rx.h        |  7361 ++++++
>   bsps/arm/stm32f4/include/stm32f410tx.h        |  7306 ++++++
>   bsps/arm/stm32f4/include/stm32f411xe.h        |  8680 +++++++
>   bsps/arm/stm32f4/include/stm32f412cx.h        | 13507 ++++++++++
>   bsps/arm/stm32f4/include/stm32f412rx.h        | 14500 +++++++++++
>   bsps/arm/stm32f4/include/stm32f412vx.h        | 14512 +++++++++++
>   bsps/arm/stm32f4/include/stm32f412zx.h        | 14537 +++++++++++
>   bsps/arm/stm32f4/include/stm32f413xx.h        | 15462 ++++++++++++
>   bsps/arm/stm32f4/include/stm32f415xx.h        | 14595 +++++++++++
>   bsps/arm/stm32f4/include/stm32f417xx.h        | 15887 ++++++++++++
>   bsps/arm/stm32f4/include/stm32f423xx.h        | 15615 ++++++++++++
>   bsps/arm/stm32f4/include/stm32f427xx.h        | 16827 +++++++++++++
>   bsps/arm/stm32f4/include/stm32f429xx.h        | 17185 +++++++++++++
>   bsps/arm/stm32f4/include/stm32f437xx.h        | 17129 +++++++++++++
>   bsps/arm/stm32f4/include/stm32f439xx.h        | 17479 +++++++++++++
>   bsps/arm/stm32f4/include/stm32f446xx.h        | 15981 ++++++++++++
>   bsps/arm/stm32f4/include/stm32f469xx.h        | 20278 +++++++++++++++
>   bsps/arm/stm32f4/include/stm32f479xx.h        | 20575 ++++++++++++++++
>   bsps/arm/stm32f4/include/stm32f4xx.h          |   305 +
>   bsps/arm/stm32f4/include/stm32f4xx_hal.h      |   297 +
>   bsps/arm/stm32f4/include/stm32f4xx_hal_adc.h  |   898 +
>   .../stm32f4/include/stm32f4xx_hal_adc_ex.h    |   407 +
>   bsps/arm/stm32f4/include/stm32f4xx_hal_can.h  |   844 +
>   bsps/arm/stm32f4/include/stm32f4xx_hal_cec.h  |   792 +
>   bsps/arm/stm32f4/include/stm32f4xx_hal_conf.h |   506 +
>   .../stm32f4/include/stm32f4xx_hal_cortex.h    |   407 +
>   bsps/arm/stm32f4/include/stm32f4xx_hal_crc.h  |   181 +
>   bsps/arm/stm32f4/include/stm32f4xx_hal_cryp.h |   683 +
>   .../stm32f4/include/stm32f4xx_hal_cryp_ex.h   |   142 +
>   bsps/arm/stm32f4/include/stm32f4xx_hal_dac.h  |   480 +
>   .../stm32f4/include/stm32f4xx_hal_dac_ex.h    |   205 +
>   bsps/arm/stm32f4/include/stm32f4xx_hal_dcmi.h |   563 +
>   .../stm32f4/include/stm32f4xx_hal_dcmi_ex.h   |   208 +
>   bsps/arm/stm32f4/include/stm32f4xx_hal_def.h  |   210 +
>   .../arm/stm32f4/include/stm32f4xx_hal_dfsdm.h |  1141 +
>   bsps/arm/stm32f4/include/stm32f4xx_hal_dma.h  |   802 +
>   .../arm/stm32f4/include/stm32f4xx_hal_dma2d.h |   638 +
>   .../stm32f4/include/stm32f4xx_hal_dma_ex.h    |   102 +
>   bsps/arm/stm32f4/include/stm32f4xx_hal_dsi.h  |  1377 ++
>   bsps/arm/stm32f4/include/stm32f4xx_hal_eth.h  |  2144 ++
>   bsps/arm/stm32f4/include/stm32f4xx_hal_exti.h |   366 +
>   .../arm/stm32f4/include/stm32f4xx_hal_flash.h |   425 +
>   .../stm32f4/include/stm32f4xx_hal_flash_ex.h  |  1063 +
>   .../include/stm32f4xx_hal_flash_ramfunc.h     |    76 +
>   .../stm32f4/include/stm32f4xx_hal_fmpi2c.h    |   837 +
>   .../stm32f4/include/stm32f4xx_hal_fmpi2c_ex.h |   150 +
>   .../stm32f4/include/stm32f4xx_hal_fmpsmbus.h  |   790 +
>   .../include/stm32f4xx_hal_fmpsmbus_ex.h       |   136 +
>   bsps/arm/stm32f4/include/stm32f4xx_hal_gpio.h |   325 +
>   .../stm32f4/include/stm32f4xx_hal_gpio_ex.h   |  1590 ++
>   bsps/arm/stm32f4/include/stm32f4xx_hal_hash.h |   634 +
>   .../stm32f4/include/stm32f4xx_hal_hash_ex.h   |   175 +
>   bsps/arm/stm32f4/include/stm32f4xx_hal_hcd.h  |   316 +
>   bsps/arm/stm32f4/include/stm32f4xx_hal_i2c.h  |   741 +
>   .../stm32f4/include/stm32f4xx_hal_i2c_ex.h    |   115 +
>   bsps/arm/stm32f4/include/stm32f4xx_hal_i2s.h  |   618 +
>   .../stm32f4/include/stm32f4xx_hal_i2s_ex.h    |   183 +
>   bsps/arm/stm32f4/include/stm32f4xx_hal_irda.h |   682 +
>   bsps/arm/stm32f4/include/stm32f4xx_hal_iwdg.h |   220 +
>   .../arm/stm32f4/include/stm32f4xx_hal_lptim.h |   857 +
>   bsps/arm/stm32f4/include/stm32f4xx_hal_ltdc.h |   719 +
>   .../stm32f4/include/stm32f4xx_hal_ltdc_ex.h   |    83 +
>   bsps/arm/stm32f4/include/stm32f4xx_hal_mmc.h  |   747 +
>   bsps/arm/stm32f4/include/stm32f4xx_hal_nand.h |   388 +
>   bsps/arm/stm32f4/include/stm32f4xx_hal_nor.h  |   330 +
>   .../stm32f4/include/stm32f4xx_hal_pccard.h    |   285 +
>   bsps/arm/stm32f4/include/stm32f4xx_hal_pcd.h  |   459 +
>   .../stm32f4/include/stm32f4xx_hal_pcd_ex.h    |    88 +
>   bsps/arm/stm32f4/include/stm32f4xx_hal_pwr.h  |   427 +
>   .../stm32f4/include/stm32f4xx_hal_pwr_ex.h    |   340 +
>   bsps/arm/stm32f4/include/stm32f4xx_hal_qspi.h |   750 +
>   bsps/arm/stm32f4/include/stm32f4xx_hal_rcc.h  |  1459 ++
>   .../stm32f4/include/stm32f4xx_hal_rcc_ex.h    |  7111 ++++++
>   bsps/arm/stm32f4/include/stm32f4xx_hal_rng.h  |   361 +
>   bsps/arm/stm32f4/include/stm32f4xx_hal_rtc.h  |   915 +
>   .../stm32f4/include/stm32f4xx_hal_rtc_ex.h    |  1079 +
>   bsps/arm/stm32f4/include/stm32f4xx_hal_sai.h  |   895 +
>   .../stm32f4/include/stm32f4xx_hal_sai_ex.h    |   114 +
>   bsps/arm/stm32f4/include/stm32f4xx_hal_sd.h   |   758 +
>   .../arm/stm32f4/include/stm32f4xx_hal_sdram.h |   238 +
>   .../stm32f4/include/stm32f4xx_hal_smartcard.h |   755 +
>   .../arm/stm32f4/include/stm32f4xx_hal_smbus.h |   731 +
>   .../stm32f4/include/stm32f4xx_hal_spdifrx.h   |   604 +
>   bsps/arm/stm32f4/include/stm32f4xx_hal_spi.h  |   729 +
>   bsps/arm/stm32f4/include/stm32f4xx_hal_sram.h |   236 +
>   bsps/arm/stm32f4/include/stm32f4xx_hal_tim.h  |  2146 ++
>   .../stm32f4/include/stm32f4xx_hal_tim_ex.h    |   354 +
>   bsps/arm/stm32f4/include/stm32f4xx_hal_uart.h |   884 +
>   .../arm/stm32f4/include/stm32f4xx_hal_usart.h |   648 +
>   bsps/arm/stm32f4/include/stm32f4xx_hal_wwdg.h |   298 +
>   bsps/arm/stm32f4/include/stm32f4xx_ll_adc.h   |  4779 ++++
>   bsps/arm/stm32f4/include/stm32f4xx_ll_bus.h   |  2105 ++
>   .../arm/stm32f4/include/stm32f4xx_ll_cortex.h |   637 +
>   bsps/arm/stm32f4/include/stm32f4xx_ll_crc.h   |   201 +
>   bsps/arm/stm32f4/include/stm32f4xx_ll_dac.h   |  1455 ++
>   bsps/arm/stm32f4/include/stm32f4xx_ll_dma.h   |  2868 +++
>   bsps/arm/stm32f4/include/stm32f4xx_ll_dma2d.h |  1901 ++
>   bsps/arm/stm32f4/include/stm32f4xx_ll_exti.h  |   954 +
>   bsps/arm/stm32f4/include/stm32f4xx_ll_fmc.h   |  1416 ++
>   .../arm/stm32f4/include/stm32f4xx_ll_fmpi2c.h |  2234 ++
>   bsps/arm/stm32f4/include/stm32f4xx_ll_fsmc.h  |  1086 +
>   bsps/arm/stm32f4/include/stm32f4xx_ll_gpio.h  |   981 +
>   bsps/arm/stm32f4/include/stm32f4xx_ll_i2c.h   |  1890 ++
>   bsps/arm/stm32f4/include/stm32f4xx_ll_iwdg.h  |   302 +
>   bsps/arm/stm32f4/include/stm32f4xx_ll_lptim.h |  1378 ++
>   bsps/arm/stm32f4/include/stm32f4xx_ll_pwr.h   |   985 +
>   bsps/arm/stm32f4/include/stm32f4xx_ll_rcc.h   |  7096 ++++++
>   bsps/arm/stm32f4/include/stm32f4xx_ll_rng.h   |   335 +
>   bsps/arm/stm32f4/include/stm32f4xx_ll_rtc.h   |  3663 +++
>   bsps/arm/stm32f4/include/stm32f4xx_ll_sdmmc.h |  1141 +
>   bsps/arm/stm32f4/include/stm32f4xx_ll_spi.h   |  2027 ++
>   .../arm/stm32f4/include/stm32f4xx_ll_system.h |  1711 ++
>   bsps/arm/stm32f4/include/stm32f4xx_ll_tim.h   |  4093 +++
>   bsps/arm/stm32f4/include/stm32f4xx_ll_usart.h |  2521 ++
>   bsps/arm/stm32f4/include/stm32f4xx_ll_usb.h   |   536 +
>   bsps/arm/stm32f4/include/stm32f4xx_ll_utils.h |   307 +
>   bsps/arm/stm32f4/include/stm32f4xx_ll_wwdg.h  |   316 +
>   bsps/arm/stm32f4/include/system_stm32f4xx.h   |   104 +
You most likely noted the long discussion on Discord between Andrei of
the North and me regarding how the hal could be made more
application-friendly. @Andrei: Do you think the headers should be moved
into a subdirectory to make them simpler to avoid in the application?
>   bsps/arm/stm32f4/start/bspstart.c             |   202 +-
>   bsps/arm/stm32f4/start/bspstart_old.c         |   297 +
>   spec/build/bsps/arm/grp.yml                   |     5 +-
>   spec/build/bsps/arm/stm32f4/grp.yml           |    12 +-
>   spec/build/bsps/arm/stm32f4/obj.yml           |   220 +
>   spec/build/bsps/arm/stm32f4/optenhal.yml      |    16 +
>   spec/build/bsps/arm/stm32f4/opthse.yml        |    17 +
>   spec/build/bsps/arm/stm32f4/optusehse.yml     |    16 +
>   spec/build/bsps/arm/stm32f4/optvariant.yml    |    24 +
>   spec/build/bsps/obj.yml                       |     1 +
Did the HAL files compile completely without change? If yes, it is OK if
you add them to the yml file right here. Otherwise I would suggest to
make two to three smaller steps:
- Add the unchanged files. Don't add them to the build yet so that the
commit would still compile without problems.
- Add necessary changes.
- Add the files to the build.
That makes it simpler to find out what you might had to change to make
the files compile and port the changes to a newer version.
Best regards
Christian
>   242 files changed, 586809 insertions(+), 4072 deletions(-)
>   create mode 100644 bsps/arm/include/cmsis_compiler.h
>   create mode 100644 bsps/arm/include/cmsis_version.h
>   create mode 100644 bsps/arm/include/mpu_armv7.h
>   create mode 100644 bsps/arm/stm32f4/hal/Legacy/stm32f4xx_hal_can.c
>   create mode 100644 bsps/arm/stm32f4/hal/Legacy/stm32f4xx_hal_eth.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_adc.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_adc_ex.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_can.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_cec.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_cortex.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_crc.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_cryp.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_cryp_ex.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_dac.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_dac_ex.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_dcmi.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_dcmi_ex.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_dfsdm.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_dma.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_dma2d.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_dma_ex.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_dsi.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_eth.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_exti.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_flash.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_flash_ex.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_flash_ramfunc.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_fmpi2c.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_fmpi2c_ex.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_fmpsmbus.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_fmpsmbus_ex.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_gpio.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_hash.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_hash_ex.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_hcd.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_i2c.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_i2c_ex.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_i2s.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_i2s_ex.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_irda.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_iwdg.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_lptim.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_ltdc.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_ltdc_ex.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_mmc.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_msp_template.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_nand.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_nor.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_pccard.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_pcd.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_pcd_ex.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_pwr.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_pwr_ex.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_qspi.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_rcc.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_rcc_ex.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_rng.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_rtc.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_rtc_ex.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_sai.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_sai_ex.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_sd.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_sdram.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_smartcard.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_smbus.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_spdifrx.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_spi.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_sram.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_tim.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_tim_ex.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_timebase_rtc_alarm_template.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_timebase_rtc_wakeup_template.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_timebase_tim_template.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_uart.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_usart.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_hal_wwdg.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_adc.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_crc.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_dac.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_dma.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_dma2d.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_exti.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_fmc.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_fmpi2c.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_fsmc.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_gpio.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_i2c.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_lptim.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_pwr.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_rcc.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_rng.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_rtc.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_sdmmc.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_spi.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_tim.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_usart.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_usb.c
>   create mode 100644 bsps/arm/stm32f4/hal/stm32f4xx_ll_utils.c
>   create mode 100644 bsps/arm/stm32f4/hal/system_stm32f4xx.c
>   create mode 100644 bsps/arm/stm32f4/include/Legacy/stm32_hal_legacy.h
>   create mode 100644 bsps/arm/stm32f4/include/Legacy/stm32f4xx_hal_can_legacy.h
>   create mode 100644 bsps/arm/stm32f4/include/Legacy/stm32f4xx_hal_eth_legacy.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f401xc.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f401xe.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f405xx.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f407xx.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f410cx.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f410rx.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f410tx.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f411xe.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f412cx.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f412rx.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f412vx.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f412zx.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f413xx.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f415xx.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f417xx.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f423xx.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f427xx.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f429xx.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f437xx.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f439xx.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f446xx.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f469xx.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f479xx.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_adc.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_adc_ex.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_can.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_cec.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_conf.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_cortex.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_crc.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_cryp.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_cryp_ex.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_dac.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_dac_ex.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_dcmi.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_dcmi_ex.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_def.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_dfsdm.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_dma.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_dma2d.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_dma_ex.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_dsi.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_eth.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_exti.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_flash.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_flash_ex.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_flash_ramfunc.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_fmpi2c.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_fmpi2c_ex.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_fmpsmbus.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_fmpsmbus_ex.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_gpio.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_gpio_ex.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_hash.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_hash_ex.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_hcd.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_i2c.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_i2c_ex.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_i2s.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_i2s_ex.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_irda.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_iwdg.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_lptim.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_ltdc.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_ltdc_ex.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_mmc.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_nand.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_nor.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_pccard.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_pcd.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_pcd_ex.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_pwr.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_pwr_ex.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_qspi.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_rcc.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_rcc_ex.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_rng.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_rtc.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_rtc_ex.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_sai.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_sai_ex.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_sd.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_sdram.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_smartcard.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_smbus.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_spdifrx.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_spi.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_sram.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_tim.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_tim_ex.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_uart.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_usart.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_hal_wwdg.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_adc.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_bus.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_cortex.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_crc.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_dac.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_dma.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_dma2d.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_exti.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_fmc.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_fmpi2c.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_fsmc.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_gpio.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_i2c.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_iwdg.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_lptim.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_pwr.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_rcc.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_rng.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_rtc.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_sdmmc.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_spi.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_system.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_tim.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_usart.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_usb.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_utils.h
>   create mode 100644 bsps/arm/stm32f4/include/stm32f4xx_ll_wwdg.h
>   create mode 100644 bsps/arm/stm32f4/include/system_stm32f4xx.h
>   create mode 100644 bsps/arm/stm32f4/start/bspstart_old.c
>   create mode 100644 spec/build/bsps/arm/stm32f4/optenhal.yml
>   create mode 100644 spec/build/bsps/arm/stm32f4/opthse.yml
>   create mode 100644 spec/build/bsps/arm/stm32f4/optusehse.yml
>   create mode 100644 spec/build/bsps/arm/stm32f4/optvariant.yml
> devel mailing list
> devel at rtems.org
