mps/jmr3904 Massive Number of Test Failures
Joel Sherrill
joel at rtems.org
Sat Jul 30 16:34:59 UTC 2022
Hi
A comment from Chris had me make a pass over the posted test results,
jmr3904 last had a good test run in January. Since then, there has not been
one in which more than 1 test pass and I suspect that's because the one
doesn't expect output.
https://lists.rtems.org/pipermail/build/2022-January/030809.html
I haven't looked into this by hand but if someone has ideas, I'm listening.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220730/c27cb874/attachment.htm>
