AW: AW: [PATCH] kern_tc.c: Update pps_event() for uniprocessor configurations
Sebastian Huber
Wed Jun 1 09:20:22 UTC 2022
On 01/06/2022 11:19, Gabriel.Moyano at dlr.de wrote:
>> On 01/06/2022 08:55,Gabriel.Moyano at dlr.de wrote:
>>>> On 30/05/2022 09:29, Gabriel Moyano wrote:
>>>>> Since pps->capgen is not used in uniprocessor configurations, there
>>>>> is no need to verified if it is equal to zero
>>>>> Update #2349
>>>>> cpukit/score/src/kern_tc.c | 4 ++++
>>>>> 1 file changed, 4 insertions(+)
>>>>> diff --git a/cpukit/score/src/kern_tc.c b/cpukit/score/src/kern_tc.c
>>>>> index 92739d8edd..897f81511e 100644
>>>>> --- a/cpukit/score/src/kern_tc.c
>>>>> +++ b/cpukit/score/src/kern_tc.c
>>>>> @@ -2165,7 +2165,11 @@ pps_event(struct pps_state *pps, int event)
>>>>> if ((event & pps->ppsparam.mode) == 0)
>>>>> return;
>>>>> /* If the timecounter was wound up underneath us, bail out. */
>>>>> +#if defined(RTEMS_SMP)
>>>>> if (pps->capgen == 0 || pps->capgen !=
>>>>> +#else
>>>>> + if (pps->capgen !=
>>>>> +#endif
>>>>> atomic_load_acq_int(&pps->capth->th_generation))
>>>>> return;
>>>> I think this fix is incomplete. What is with:
>>>> void
>>>> pps_capture(struct pps_state *pps)
>>>> struct timehands *th;
>>>> KASSERT(pps != NULL, ("NULL pps pointer in pps_capture"));
>>>> th = timehands;
>>>> pps->capgen = atomic_load_acq_int(&th->th_generation);
>>>> pps->capth = th;
>>>> #ifdef FFCLOCK
>>>> pps->capffth = fftimehands;
>>>> #endif
>>>> pps->capcount = th->th_counter->tc_get_timecount(th->th_counter);
>>>> atomic_thread_fence_acq();
>>>> if (pps->capgen != th->th_generation)
>>>> pps->capgen = 0;
>>>> I don't know why there is this "if" in the code. I will ask on a FreeBSD mailing list.
>>> I think it is for the case that th_generation has changed in between
>>> saving the th and th_counter. If this happens pps->capgen is set to 0
>>> and later pps_event() returns earlier. Since for uniprocessor
>>> th_generation equal to 0 is not used, I guess we can removed this if
>>> for those configurations
>> I asked on a FreeBSD mailing list:
>> https://lists.freebsd.org/archives/freebsd-hackers/2022-June/001165.html
> Thanks for asking.
> I'll prepare and send a new patch removing the "if" for uniprocessor configurations just in case.
Please wait with a new patch for a response from FreeBSD.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
