[PATCH 1/4] bsps/stm32h7: add board C files for stm32h747i-disco BSP
Karel Gardas karel at functional.vision
Wed Jun 1 12:23:43 UTC 2022
Besides C files for the BSP variant the patch also provides license
clarification on system_stm32h7xx.c file which is provided
in boards/stm/stm32h747i-disco directory.
The files comes from STM32CubeH7 project and references "root directory"
in its license comment and it's not clear where this points out.
Let's add clarification comment about it and also based on it
and resulting license let's add SPDX license identifier.
Sponsored-By:	Precidata
 .../stm/stm32h747i-disco/stm32h7-config-clk.c |  45 ++
 .../stm/stm32h747i-disco/stm32h7-config-osc.c |  50 ++
 .../stm/stm32h747i-disco/stm32h7-config-per.c |  39 ++
 .../stm/stm32h747i-disco/system_stm32h7xx.c   | 602 ++++++++++++++++++
 4 files changed, 736 insertions(+)
 create mode 100644 bsps/arm/stm32h7/boards/stm/stm32h747i-disco/stm32h7-config-clk.c
 create mode 100644 bsps/arm/stm32h7/boards/stm/stm32h747i-disco/stm32h7-config-osc.c
 create mode 100644 bsps/arm/stm32h7/boards/stm/stm32h747i-disco/stm32h7-config-per.c
 create mode 100644 bsps/arm/stm32h7/boards/stm/stm32h747i-disco/system_stm32h7xx.c
diff --git a/bsps/arm/stm32h7/boards/stm/stm32h747i-disco/stm32h7-config-clk.c b/bsps/arm/stm32h7/boards/stm/stm32h747i-disco/stm32h7-config-clk.c
new file mode 100644
index 0000000000..c4ea947c3c
--- /dev/null
+++ b/bsps/arm/stm32h7/boards/stm/stm32h747i-disco/stm32h7-config-clk.c
@@ -0,0 +1,45 @@
+ * Copyright (C) 2022 Karel Gardas <karel at functional.vision>
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <stm32h7/hal.h>
+const RCC_ClkInitTypeDef stm32h7_config_clocks = {
+  .ClockType = RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_SYSCLK
+    | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2
+    | RCC_CLOCKTYPE_D3PCLK1 | RCC_CLOCKTYPE_D1PCLK1,
+  .SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK,
+  .SYSCLKDivider = RCC_SYSCLK_DIV1,
+  .AHBCLKDivider = RCC_HCLK_DIV2,
+  .APB3CLKDivider = RCC_APB3_DIV2,
+  .APB1CLKDivider = RCC_APB1_DIV2,
+  .APB2CLKDivider = RCC_APB2_DIV2,
+  .APB4CLKDivider = RCC_APB4_DIV2
diff --git a/bsps/arm/stm32h7/boards/stm/stm32h747i-disco/stm32h7-config-osc.c b/bsps/arm/stm32h7/boards/stm/stm32h747i-disco/stm32h7-config-osc.c
index 0000000000..4f294c455d
--- /dev/null
+++ b/bsps/arm/stm32h7/boards/stm/stm32h747i-disco/stm32h7-config-osc.c
@@ -0,0 +1,50 @@
+ * are met:
+#endif
+const RCC_OscInitTypeDef stm32h7_config_oscillator = {
+  .OscillatorType = RCC_OSCILLATORTYPE_HSE,
+  .HSEState = RCC_HSE_ON,
+  .LSEState = RCC_LSE_OFF,
+  .HSIState = RCC_HSI_OFF,
+  .CSIState = RCC_CSI_OFF,
+  .PLL.PLLState = RCC_PLL_ON,
+  .PLL.PLLSource = RCC_PLLSOURCE_HSE,
+  .PLL.PLLM = 5,
+  .PLL.PLLN = 160,
+  .PLL.PLLFRACN = 0,
+  .PLL.PLLP = 2,
+  .PLL.PLLR = 2,
+  .PLL.PLLQ = 4,
+  .PLL.PLLVCOSEL = RCC_PLL1VCOWIDE,
+  .PLL.PLLRGE = RCC_PLL1VCIRANGE_2
diff --git a/bsps/arm/stm32h7/boards/stm/stm32h747i-disco/stm32h7-config-per.c b/bsps/arm/stm32h7/boards/stm/stm32h747i-disco/stm32h7-config-per.c
index 0000000000..3a691a2c8b
--- /dev/null
+++ b/bsps/arm/stm32h7/boards/stm/stm32h747i-disco/stm32h7-config-per.c
@@ -0,0 +1,39 @@
+ * are met:
+#endif
+const RCC_PeriphCLKInitTypeDef stm32h7_config_peripheral_clocks = {
+  /* for stm32h747i-disco BSP we provide only minimalistic peripheral
+     configuration just to make available U(S)ART1 working */
+  .PeriphClockSelection = RCC_PERIPHCLK_USART1,
+  .Usart16ClockSelection = RCC_USART16CLKSOURCE_D2PCLK2
diff --git a/bsps/arm/stm32h7/boards/stm/stm32h747i-disco/system_stm32h7xx.c b/bsps/arm/stm32h7/boards/stm/stm32h747i-disco/system_stm32h7xx.c
index 0000000000..2dc9542597
--- /dev/null
+++ b/bsps/arm/stm32h7/boards/stm/stm32h747i-disco/system_stm32h7xx.c
@@ -0,0 +1,602 @@
+/* SPDX-License-Identifier: BSD-3-Clause */
+  * @file    system_stm32h7xx.c
+  * @author  MCD Application Team
+  * @brief   CMSIS Cortex-Mx Device Peripheral Access Layer System Source File.
+  *   This file provides two functions and one global variable to be called from
+  *   user application:
+  *      - SystemInit(): This function is called at startup just after reset and
+  *                      before branch to main program. This call is made inside
+  *                      the "startup_stm32h7xx.s" file.
+  *      - SystemCoreClock variable: Contains the core clock (HCLK), it can be used
+  *                                  by the user application to setup the SysTick
+  *                                  timer or configure other parameters.
+  *      - SystemCoreClockUpdate(): Updates the variable SystemCoreClock and must
+  *                                 be called whenever the core clock is changed
+  *                                 during program execution.
+  * @attention
+  * Copyright (c) 2019 STMicroelectronics.
+  * All rights reserved.
+  * This software is licensed under terms that can be found in the LICENSE file
+  * in the root directory of this software component.
+  * If no LICENSE file comes with this software, it is provided AS-IS.
+ * RTEMS committer clarification comment on license above:
+ * This file comes from STM32CubeH7 project from its Projects
+ * subdirectory. There is Templates subdirectory per every supported
+ * BSP there. The Templates contains the file. In our case the file is
+ * here:
+ * https://github.com/STMicroelectronics/STM32CubeH7/blob/master/Projects/STM32H747I-DISCO/Templates/BootCM4_CM7/Common/Src/system_stm32h7xx.c
+ * When we go up in the directory tree starting from the file, we find
+ * out that the "root directory" in the sense of license claim above is Templates
+ * directory here:
+ * This directory contains LICENSE.md file with a following license text:
+ * Copyright 2019 STMicroelectronics.
+ * Redistribution and use in source and binary forms, with or without modification,
+ * are permitted provided that the following conditions are met:
+ * 1. Redistributions of source code must retain the above copyright notice, this
+ * list of conditions and the following disclaimer.
+ * 2. Redistributions in binary form must reproduce the above copyright notice,
+ * this list of conditions and the following disclaimer in the documentation and/or
+ * other materials provided with the distribution.
+ * 3. Neither the name of the copyright holder nor the names of its contributors
+ * may be used to endorse or promote products derived from this software without
+ * specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
+ * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+ * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR
+ * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
+ * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
+ * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON
+ * ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+ * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
+ * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+/** @addtogroup CMSIS
+/** @addtogroup stm32h7xx_system
+/** @addtogroup STM32H7xx_System_Private_Includes
+#include "stm32h7xx.h"
+#include <math.h>
+#if !defined  (HSE_VALUE)
+#define HSE_VALUE    ((uint32_t)25000000) /*!< Value of the External oscillator in Hz */
+#endif /* HSE_VALUE */
+#if !defined  (CSI_VALUE)
+  #define CSI_VALUE    ((uint32_t)4000000) /*!< Value of the Internal oscillator in Hz*/
+#endif /* CSI_VALUE */
+#if !defined  (HSI_VALUE)
+  #define HSI_VALUE    ((uint32_t)64000000) /*!< Value of the Internal oscillator in Hz*/
+#endif /* HSI_VALUE */
+/** @addtogroup STM32H7xx_System_Private_TypesDefinitions
+/** @addtogroup STM32H7xx_System_Private_Defines
+/************************* Miscellaneous Configuration ************************/
+/*!< Uncomment the following line if you need to use external SDRAM mounted
+     on DISCO board as data memory  */
+/*#define DATA_IN_ExtSDRAM*/
+#ifdef __rtems__
+#define DATA_IN_ExtSDRAM
+#endif /* __rtems__ */
+/*!< Uncomment the following line if you need to relocate your vector Table in
+     Internal SRAM. */
+/* #define VECT_TAB_SRAM */
+#define VECT_TAB_OFFSET  0x00000000UL       /*!< Vector Table base offset field.
+                                      This value must be a multiple of 0x200. */
+/** @addtogroup STM32H7xx_System_Private_Macros
+/** @addtogroup STM32H7xx_System_Private_Variables
+  /* This variable is updated in three ways:
+      1) by calling CMSIS function SystemCoreClockUpdate()
+      2) by calling HAL API function HAL_RCC_GetHCLKFreq()
+      3) each time HAL_RCC_ClockConfig() is called to configure the system clock frequency
+         Note: If you use this function to configure the system clock; then there
+               is no need to call the 2 first functions listed above, since SystemCoreClock
+               variable is updated automatically.
+  uint32_t SystemCoreClock = 64000000;
+  uint32_t SystemD2Clock = 64000000;
+  const  uint8_t D1CorePrescTable[16] = {0, 0, 0, 0, 1, 2, 3, 4, 1, 2, 3, 4, 6, 7, 8, 9};
+/** @addtogroup STM32H7xx_System_Private_FunctionPrototypes
+#ifndef __rtems__
+#if defined (DATA_IN_ExtSDRAM)
+  static void SystemInit_ExtMemCtl(void);
+#endif /* DATA_IN_ExtSDRAM */
+/** @addtogroup STM32H7xx_System_Private_Functions
+  * @brief  Setup the microcontroller system
+  *         Initialize the FPU setting, vector table location and External memory
+  *         configuration.
+  * @param  None
+  * @retval None
+void SystemInit (void)
+  /* FPU settings ------------------------------------------------------------*/
+  #if (__FPU_PRESENT == 1) && (__FPU_USED == 1)
+    SCB->CPACR |= ((3UL << (10*2))|(3UL << (11*2)));  /* set CP10 and CP11 Full Access */
+  #endif
+  /*SEVONPEND enabled so that an interrupt coming from the CPU(n) interrupt signal is
+    detectable by the CPU after a WFI/WFE instruction.*/
+ SCB->SCR |= SCB_SCR_SEVONPEND_Msk;
+#ifdef CORE_CM7
+  /* Reset the RCC clock configuration to the default reset state ------------*/
+  /* Set HSION bit */
+  RCC->CR |= RCC_CR_HSION;
+  /* Reset CFGR register */
+  RCC->CFGR = 0x00000000;
+  /* Reset HSEON, CSSON , CSION,RC48ON, CSIKERON PLL1ON, PLL2ON and PLL3ON bits */
+  RCC->CR &= 0xEAF6ED7FU;
+  /* Reset D1CFGR register */
+  RCC->D1CFGR = 0x00000000;
+  /* Reset D2CFGR register */
+  RCC->D2CFGR = 0x00000000;
+  /* Reset D3CFGR register */
+  RCC->D3CFGR = 0x00000000;
+  /* Reset PLLCKSELR register */
+  RCC->PLLCKSELR = 0x00000000;
+  /* Reset PLLCFGR register */
+  RCC->PLLCFGR = 0x00000000;
+  /* Reset PLL1DIVR register */
+  RCC->PLL1DIVR = 0x00000000;
+  /* Reset PLL1FRACR register */
+  RCC->PLL1FRACR = 0x00000000;
+  /* Reset PLL2DIVR register */
+  RCC->PLL2DIVR = 0x00000000;
+  /* Reset PLL2FRACR register */
+  RCC->PLL2FRACR = 0x00000000;
+  /* Reset PLL3DIVR register */
+  RCC->PLL3DIVR = 0x00000000;
+  /* Reset PLL3FRACR register */
+  RCC->PLL3FRACR = 0x00000000;
+  /* Reset HSEBYP bit */
+  RCC->CR &= 0xFFFBFFFFU;
+  /* Disable all interrupts */
+  RCC->CIER = 0x00000000;
+  /* Enable CortexM7 HSEM EXTI line (line 78)*/
+  EXTI_D2->EMR3 |= 0x4000UL;
+  /* Change  the switch matrix read issuing capability to 1 for the AXI SRAM target (Target 7) */
+  if((DBGMCU->IDCODE & 0xFFFF0000U) < 0x20000000U)
+    /* if stm32h7 revY*/
+    *((__IO uint32_t*)0x51008108) = 0x00000001U;
+   * Disable the FMC bank1 (enabled after reset).
+   * This, prevents CPU speculation access on this bank which blocks the use of FMC during
+   * 24us. During this time the others FMC master (such as LTDC) cannot use it!
+  FMC_Bank1_R->BTCR[0] = 0x000030D2;
+  SystemInit_ExtMemCtl();
+#endif /* CORE_CM7*/
+#ifdef CORE_CM4
+  /* Configure the Vector Table location add offset address ------------------*/
+#ifdef VECT_TAB_SRAM
+  SCB->VTOR = D2_AXISRAM_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal SRAM */
+#else
+  SCB->VTOR = FLASH_BANK2_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal FLASH */
+#endif
+#else
+#ifdef CORE_CM7
+  SCB->VTOR = D1_AXISRAM_BASE  | VECT_TAB_OFFSET;       /* Vector Table Relocation in Internal SRAM */
+#else
+  SCB->VTOR = FLASH_BANK1_BASE | VECT_TAB_OFFSET;       /* Vector Table Relocation in Internal FLASH */
+#endif
+#else
+#error Please #define CORE_CM4 or CORE_CM7
+#endif
+#endif
+   * @brief  Update SystemCoreClock variable according to Clock Register Values.
+  *         The SystemCoreClock variable contains the core clock , it can
+  *         be used by the user application to setup the SysTick timer or configure
+  *         other parameters.
+  * @note   Each time the core clock changes, this function must be called
+  *         to update SystemCoreClock variable value. Otherwise, any configuration
+  *         based on this variable will be incorrect.
+  * @note   - The system frequency computed by this function is not the real
+  *           frequency in the chip. It is calculated based on the predefined
+  *           constant and the selected clock source:
+  *           - If SYSCLK source is CSI, SystemCoreClock will contain the CSI_VALUE(*)
+  *           - If SYSCLK source is HSI, SystemCoreClock will contain the HSI_VALUE(**)
+  *           - If SYSCLK source is HSE, SystemCoreClock will contain the HSE_VALUE(***)
+  *           - If SYSCLK source is PLL, SystemCoreClock will contain the CSI_VALUE(*),
+  *             HSI_VALUE(**) or HSE_VALUE(***) multiplied/divided by the PLL factors.
+  *         (*) CSI_VALUE is a constant defined in stm32h7xx_hal.h file (default value
+  *             4 MHz) but the real value may vary depending on the variations
+  *             in voltage and temperature.
+  *         (**) HSI_VALUE is a constant defined in stm32h7xx_hal.h file (default value
+  *             64 MHz) but the real value may vary depending on the variations
+  *         (***)HSE_VALUE is a constant defined in stm32h7xx_hal.h file (default value
+  *              25 MHz), user has to ensure that HSE_VALUE is same as the real
+  *              frequency of the crystal used. Otherwise, this function may
+  *              have wrong result.
+  *         - The result of this function could be not correct when using fractional
+  *           value for HSE crystal.
+  * @param  None
+  * @retval None
+void SystemCoreClockUpdate (void)
+  uint32_t pllp, pllsource, pllm, pllfracen, hsivalue, tmp;
+  uint32_t common_system_clock;
+  float_t fracn1, pllvco;
+  /* Get SYSCLK source -------------------------------------------------------*/
+  switch (RCC->CFGR & RCC_CFGR_SWS)
+  case RCC_CFGR_SWS_HSI:  /* HSI used as system clock source */
+    common_system_clock = (uint32_t) (HSI_VALUE >> ((RCC->CR & RCC_CR_HSIDIV)>> 3));
+    break;
+  case RCC_CFGR_SWS_CSI:  /* CSI used as system clock  source */
+    common_system_clock = CSI_VALUE;
+    break;
+  case RCC_CFGR_SWS_HSE:  /* HSE used as system clock  source */
+    common_system_clock = HSE_VALUE;
+    break;
+  case RCC_CFGR_SWS_PLL1:  /* PLL1 used as system clock  source */
+    /* PLL_VCO = (HSE_VALUE or HSI_VALUE or CSI_VALUE/ PLLM) * PLLN
+    SYSCLK = PLL_VCO / PLLR
+    pllsource = (RCC->PLLCKSELR & RCC_PLLCKSELR_PLLSRC);
+    pllm = ((RCC->PLLCKSELR & RCC_PLLCKSELR_DIVM1)>> 4)  ;
+    pllfracen = ((RCC->PLLCFGR & RCC_PLLCFGR_PLL1FRACEN)>>RCC_PLLCFGR_PLL1FRACEN_Pos);
+    fracn1 = (float_t)(uint32_t)(pllfracen* ((RCC->PLL1FRACR & RCC_PLL1FRACR_FRACN1)>> 3));
+    if (pllm != 0U)
+      switch (pllsource)
+        case RCC_PLLCKSELR_PLLSRC_HSI:  /* HSI used as PLL clock source */
+        hsivalue = (HSI_VALUE >> ((RCC->CR & RCC_CR_HSIDIV)>> 3)) ;
+        pllvco = ( (float_t)hsivalue / (float_t)pllm) * ((float_t)(uint32_t)(RCC->PLL1DIVR & RCC_PLL1DIVR_N1) + (fracn1/(float_t)0x2000) +(float_t)1 );
+        break;
+        case RCC_PLLCKSELR_PLLSRC_CSI:  /* CSI used as PLL clock source */
+          pllvco = ((float_t)CSI_VALUE / (float_t)pllm) * ((float_t)(uint32_t)(RCC->PLL1DIVR & RCC_PLL1DIVR_N1) + (fracn1/(float_t)0x2000) +(float_t)1 );
+        break;
+        case RCC_PLLCKSELR_PLLSRC_HSE:  /* HSE used as PLL clock source */
+          pllvco = ((float_t)HSE_VALUE / (float_t)pllm) * ((float_t)(uint32_t)(RCC->PLL1DIVR & RCC_PLL1DIVR_N1) + (fracn1/(float_t)0x2000) +(float_t)1 );
+        break;
+      default:
+        break;
+      pllp = (((RCC->PLL1DIVR & RCC_PLL1DIVR_P1) >>9) + 1U ) ;
+      common_system_clock =  (uint32_t)(float_t)(pllvco/(float_t)pllp);
+    else
+      common_system_clock = 0U;
+    break;
+  default:
+    break;
+  /* Compute SystemClock frequency --------------------------------------------------*/
+  tmp = D1CorePrescTable[(RCC->D1CFGR & RCC_D1CFGR_D1CPRE)>> RCC_D1CFGR_D1CPRE_Pos];
+  /* common_system_clock frequency : CM7 CPU frequency  */
+  common_system_clock >>= tmp;
+  /* SystemD2Clock frequency : CM4 CPU, AXI and AHBs Clock frequency  */
+  SystemD2Clock = (common_system_clock >> ((D1CorePrescTable[(RCC->D1CFGR & RCC_D1CFGR_HPRE)>> RCC_D1CFGR_HPRE_Pos]) & 0x1FU));
+#if defined(DUAL_CORE) && defined(CORE_CM4)
+  SystemCoreClock = SystemD2Clock;
+#else
+  SystemCoreClock = common_system_clock;
+#endif /* DUAL_CORE && CORE_CM4 */
+  * @brief  Setup the external memory controller.
+  *         Called in startup_stm32h7xx.s before jump to main.
+  *         This function configures the external memories SDRAM
+  *         This SDRAM will be used as program data memory (including heap and stack).
+  * @param  None
+  * @retval None
+void SystemInit_ExtMemCtl(void)
+  __IO uint32_t tmp = 0;
+  register uint32_t tmpreg = 0, timeout = 0xFFFF;
+  register __IO uint32_t index;
+  /* Enable GPIOD, GPIOE, GPIOF, GPIOG, GPIOH and GPIOI interface
+      clock */
+  RCC->AHB4ENR |= 0x000001F8;
+  /* Delay after an RCC peripheral clock enabling */
+  tmp = READ_BIT(RCC->AHB4ENR, RCC_AHB4ENR_GPIOEEN);
+  /* Connect PDx pins to FMC Alternate function */
+  GPIOD->AFR[0]  = 0x000000CC;
+  GPIOD->AFR[1]  = 0xCC000CCC;
+  /* Configure PDx pins in Alternate function mode */
+  GPIOD->MODER   = 0xAFEAFFFA;
+  /* Configure PDx pins speed to 100 MHz */
+  GPIOD->OSPEEDR = 0xF03F000F;
+  /* Configure PDx pins Output type to push-pull */
+  GPIOD->OTYPER  = 0x00000000;
+  /* Configure PDx pins in Pull-up */
+  GPIOD->PUPDR   = 0x50150005;
+  /* Connect PEx pins to FMC Alternate function */
+  GPIOE->AFR[0]  = 0xC00000CC;
+  GPIOE->AFR[1]  = 0xCCCCCCCC;
+  /* Configure PEx pins in Alternate function mode */
+  GPIOE->MODER   = 0xAAAABFFA;
+  /* Configure PEx pins speed to 100 MHz */
+  GPIOE->OSPEEDR = 0xFFFFC00F;
+  /* Configure PEx pins Output type to push-pull */
+  GPIOE->OTYPER  = 0x00000000;
+  /* Configure PEx pins in Pull-up */
+  GPIOE->PUPDR   = 0x55554005;
+  /* Connect PFx pins to FMC Alternate function */
+  GPIOF->AFR[0]  = 0x00CCCCCC;
+  GPIOF->AFR[1]  = 0xCCCCC000;
+  /* Configure PFx pins in Alternate function mode */
+  GPIOF->MODER   = 0xAABFFAAA;
+  /* Configure PFx pins speed to 100 MHz */
+  GPIOF->OSPEEDR = 0xFFC00FFF;
+  /* Configure PFx pins Output type to push-pull */
+  GPIOF->OTYPER  = 0x00000000;
+  /* Configure PFx pins in Pull-up */
+  GPIOF->PUPDR   = 0x55400555;
+  /* Connect PGx pins to FMC Alternate function */
+  GPIOG->AFR[0]  = 0x00CCCCCC;
+  GPIOG->AFR[1]  = 0xC000000C;
+  /* Configure PGx pins in Alternate function mode */
+  GPIOG->MODER   = 0xBFFEFAAA;
+ /* Configure PGx pins speed to 100 MHz */
+  GPIOG->OSPEEDR = 0xC0030FFF;
+  /* Configure PGx pins Output type to push-pull */
+  GPIOG->OTYPER  = 0x00000000;
+  /* Configure PGx pins in Pull-up */
+  GPIOG->PUPDR   = 0x40010555;
+  /* Connect PHx pins to FMC Alternate function */
+  GPIOH->AFR[0]  = 0xCCC00000;
+  GPIOH->AFR[1]  = 0xCCCCCCCC;
+  /* Configure PHx pins in Alternate function mode */
+  GPIOH->MODER   = 0xAAAAABFF;
+  /* Configure PHx pins speed to 100 MHz */
+  GPIOH->OSPEEDR = 0xFFFFFC00;
+  /* Configure PHx pins Output type to push-pull */
+  GPIOH->OTYPER  = 0x00000000;
+  /* Configure PHx pins in Pull-up */
+  GPIOH->PUPDR   = 0x55555400;
+  /* Connect PIx pins to FMC Alternate function */
+  GPIOI->AFR[0]  = 0xCCCCCCCC;
+  GPIOI->AFR[1]  = 0x00000CC0;
+  /* Configure PIx pins in Alternate function mode */
+  GPIOI->MODER   = 0xFFEBAAAA;
+  /* Configure PIx pins speed to 100 MHz */
+  GPIOI->OSPEEDR = 0x003CFFFF;
+  /* Configure PIx pins Output type to push-pull */
+  GPIOI->OTYPER  = 0x00000000;
+  /* Configure PIx pins in Pull-up */
+  GPIOI->PUPDR   = 0x00145555;
+/*-- FMC Configuration ------------------------------------------------------*/
+  /* Enable the FMC interface clock */
+  (RCC->AHB3ENR |= (RCC_AHB3ENR_FMCEN));
+  /*SDRAM Timing and access interface configuration*/
+  /*LoadToActiveDelay  = 2
+    ExitSelfRefreshDelay = 6
+    SelfRefreshTime      = 4
+    RowCycleDelay        = 6
+    WriteRecoveryTime    = 2
+    RPDelay              = 2
+    RCDDelay             = 2
+    SDBank             = FMC_SDRAM_BANK2
+    ColumnBitsNumber   = FMC_SDRAM_COLUMN_BITS_NUM_9
+    RowBitsNumber      = FMC_SDRAM_ROW_BITS_NUM_12
+    MemoryDataWidth    = FMC_SDRAM_MEM_BUS_WIDTH_32
+    InternalBankNumber = FMC_SDRAM_INTERN_BANKS_NUM_4
+    CASLatency         = FMC_SDRAM_CAS_LATENCY_2
+    WriteProtection    = FMC_SDRAM_WRITE_PROTECTION_DISABLE
+    SDClockPeriod      = FMC_SDRAM_CLOCK_PERIOD_2
+    ReadBurst          = FMC_SDRAM_RBURST_ENABLE
+    ReadPipeDelay      = FMC_SDRAM_RPIPE_DELAY_0*/
+  FMC_Bank5_6_R->SDCR[0] = 0x00001800;
+  FMC_Bank5_6_R->SDCR[1] = 0x00000165;
+  FMC_Bank5_6_R->SDTR[0] = 0x00105000;
+  FMC_Bank5_6_R->SDTR[1] = 0x01010351;
+  /* SDRAM initialization sequence */
+  /* Clock enable command */
+  FMC_Bank5_6_R->SDCMR = 0x00000009;
+  tmpreg = FMC_Bank5_6_R->SDSR & 0x00000020;
+  while((tmpreg != 0) && (timeout-- > 0))
+  /* Delay */
+  for (index = 0; index<1000; index++);
+  /* PALL command */
+    FMC_Bank5_6_R->SDCMR = 0x0000000A;
+  timeout = 0xFFFF;
+  FMC_Bank5_6_R->SDCMR = 0x000000EB;
+  timeout = 0xFFFF;
+  FMC_Bank5_6_R->SDCMR = 0x0004400C;
+  timeout = 0xFFFF;
+  /* Set refresh count */
+  tmpreg = FMC_Bank5_6_R->SDRTR;
+  FMC_Bank5_6_R->SDRTR = (tmpreg | (0x00000603<<1));
+  /* Disable write protection */
+  tmpreg = FMC_Bank5_6_R->SDCR[1];
+  FMC_Bank5_6_R->SDCR[1] = (tmpreg & 0xFFFFFDFF);
+   /*FMC controller Enable*/
+  FMC_Bank1_R->BTCR[0]  |= 0x80000000;
+  (void)(tmp);
2.25.1
