[PATCH rtems] bsps/atsam: Fix type of options
Gedare Bloom
gedare at rtems.org
Wed Jun 1 12:51:35 UTC 2022
ok
On Mon, May 23, 2022 at 6:16 AM Christian Mauderer
<christian.mauderer at embedded-brains.de> wrote:
> ATSAM_CONSOLE_DEVICE_INDEX and ATSAM_CONSOLE_DEVICE_TYPE have to be
> integers like suggested by their description. Otherwise it's not
> possible to select (for example) USART2 as console device.
> spec/build/bsps/arm/atsam/optconidx.yml | 4 ++--
> spec/build/bsps/arm/atsam/optcontype.yml | 4 ++--
> 2 files changed, 4 insertions(+), 4 deletions(-)
> diff --git a/spec/build/bsps/arm/atsam/optconidx.yml b/spec/build/bsps/arm/atsam/optconidx.yml
> index 42fb3b142a..1c0723c594 100644
> --- a/spec/build/bsps/arm/atsam/optconidx.yml
> +++ b/spec/build/bsps/arm/atsam/optconidx.yml
> @@ -1,11 +1,11 @@
> SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> actions:
> -- get-boolean: null
> +- get-integer: null
> - define-condition: null
> build-type: option
> copyrights:
> - Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
> -default: true
> +default: 1
> default-by-variant: []
> description: |
> device index for /dev/console (default 1, e.g. USART1)
> diff --git a/spec/build/bsps/arm/atsam/optcontype.yml b/spec/build/bsps/arm/atsam/optcontype.yml
> index eddbee1063..fd0daa8999 100644
> --- a/spec/build/bsps/arm/atsam/optcontype.yml
> +++ b/spec/build/bsps/arm/atsam/optcontype.yml
> @@ -1,11 +1,11 @@
> actions:
> build-type: option
> copyrights:
> -default: false
> +default: 0
> description: |
> device type for /dev/console, use 0 for USART and 1 for UART (default USART)
> 2.35.3
> devel mailing list
> devel at rtems.org
