[PATCH rtems-libbsd 1/2] if_ffec: Reduce buffer size
Thu Jun 2 14:19:19 UTC 2022
On Thu, Jun 2, 2022 at 8:58 AM Christian MAUDERER <
christian.mauderer at embedded-brains.de> wrote:
> Am 02.06.22 um 15:49 schrieb Gedare Bloom:
> > On Thu, Jun 2, 2022 at 2:28 AM Sebastian Huber
> > <sebastian.huber at embedded-brains.de> wrote:
> >> On 02/06/2022 09:27, Christian MAUDERER wrote:
> >>> Am 01.06.22 um 14:46 schrieb Gedare Bloom:
> >>>> On Mon, May 23, 2022 at 6:21 AM Christian Mauderer
> >>>> <christian.mauderer at embedded-brains.de> wrote:
> >>>>> Typical embedded systems don't have that much memory. Reduce the
> buffer
> >>>>> size to something more sensible for the usual type of application.
> >>>>>    freebsd/sys/dev/ffec/if_ffec.c | 8 ++++++++
> >>>>>    1 file changed, 8 insertions(+)
> >>>>> diff --git a/freebsd/sys/dev/ffec/if_ffec.c
> >>>>> b/freebsd/sys/dev/ffec/if_ffec.c
> >>>>> index 47c0f770..4c1e147b 100644
> >>>>> --- a/freebsd/sys/dev/ffec/if_ffec.c
> >>>>> +++ b/freebsd/sys/dev/ffec/if_ffec.c
> >>>>> @@ -139,9 +139,17 @@ static struct ofw_compat_data compat_data[] = {
> >>>>>     * Driver data and defines.  The descriptor counts must be a power
> >>>>> of two.
> >>>>> +#ifndef __rtems__
> >>>>>    #define        RX_DESC_COUNT   512
> >>>>> +#else /* __rtems__ */
> >>>>> +#define        RX_DESC_COUNT   64
> >>>>> +#endif /* __rtems__ */
> >>>> Do we need some way to control this parameter? Or, how will this
> >>>> appear if it breaks something?
> >>> I don't expect that there will be any problems. But I can take a look
> >>> how I can make that a parameter.
> >> Can we please keep this a compile time constant as it is.  The 64
> >> descriptors should be more than enough.
> > I don't mind the reduction of the constant, but it would be good to
> > predict what behavior might indicate this was exceeded. I guess it
> > should be some kind of errno on an allocation request though? So it
> > should be fine, but if a user hits this limit, I guess they have
> > pretty limited options to overcome it.
> Reducing the limit won't cause errors. It will only means that if you
> flood the target with network packets, it will cache less packets and
> start dropping them earlier. That means:
> On a short packet burst, some packets will be dropped and (for TCP) some
> have to be re-transmitted. So for short bursts it can be a slight
> disadvantage.
> On a constant overload situation: It doesn't really make a difference
> because the target wouldn't be able to process the packages anyway. It
> might even is an advantage because the processor doesn't have to process
> packets that are already outdated and maybe re-transmitted.
How much RAM does this save versus having control over the size of
UDP and TCP RX/TX buffers like we had in the legacy stack? I recall
being able to control the various buffer sizes saved a LOT of memory
on applications I used these parameters on.
There we had four configuration values. Any chance this has a hint
in FreeBSD now or we can provide the same tuning?
        rtems_set_udp_buffer_sizes(
          rtems_bsdnet_config.udp_tx_buf_size,
          rtems_bsdnet_config.udp_rx_buf_size
        rtems_set_tcp_buffer_sizes(
          rtems_bsdnet_config.tcp_tx_buf_size,
          rtems_bsdnet_config.tcp_rx_buf_size
--joel
> Best regards
> Christian
> embedded brains GmbH
> Herr Christian MAUDERER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> phone: +49-89-18 94 741 - 18
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220602/b375ddd3/attachment-0001.htm>
