[PATCH rtems-libbsd 1/2] if_ffec: Reduce buffer size
Joel Sherrill
joel at rtems.org
Thu Jun 2 16:07:53 UTC 2022
On Thu, Jun 2, 2022, 9:58 AM Christian MAUDERER <
christian.mauderer at embedded-brains.de> wrote:
> Am 02.06.22 um 16:19 schrieb Joel Sherrill:
> > On Thu, Jun 2, 2022 at 8:58 AM Christian MAUDERER
> > <christian.mauderer at embedded-brains.de
> > <mailto:christian.mauderer at embedded-brains.de>> wrote:
> > Am 02.06.22 um 15:49 schrieb Gedare Bloom:
> > > On Thu, Jun 2, 2022 at 2:28 AM Sebastian Huber
> > > <sebastian.huber at embedded-brains.de
> > <mailto:sebastian.huber at embedded-brains.de>> wrote:
> > >> On 02/06/2022 09:27, Christian MAUDERER wrote:
> > >>> Am 01.06.22 um 14:46 schrieb Gedare Bloom:
> > >>>> On Mon, May 23, 2022 at 6:21 AM Christian Mauderer
> > >>>>> Typical embedded systems don't have that much memory. Reduce
> > the buffer
> > >>>>> size to something more sensible for the usual type of
> > application.
> > >>>>> freebsd/sys/dev/ffec/if_ffec.c | 8 ++++++++
> > >>>>> 1 file changed, 8 insertions(+)
> > >>>>> diff --git a/freebsd/sys/dev/ffec/if_ffec.c
> > >>>>> b/freebsd/sys/dev/ffec/if_ffec.c
> > >>>>> index 47c0f770..4c1e147b 100644
> > >>>>> --- a/freebsd/sys/dev/ffec/if_ffec.c
> > >>>>> +++ b/freebsd/sys/dev/ffec/if_ffec.c
> > >>>>> @@ -139,9 +139,17 @@ static struct ofw_compat_data
> > compat_data[] = {
> > >>>>> * Driver data and defines. The descriptor counts must be
> > a power
> > >>>>> of two.
> > >>>>> +#ifndef __rtems__
> > >>>>> #define RX_DESC_COUNT 512
> > >>>>> +#else /* __rtems__ */
> > >>>>> +#define RX_DESC_COUNT 64
> > >>>>> +#endif /* __rtems__ */
> > >>>> Do we need some way to control this parameter? Or, how will
> this
> > >>>> appear if it breaks something?
> > >>> I don't expect that there will be any problems. But I can take
> > a look
> > >>> how I can make that a parameter.
> > >> Can we please keep this a compile time constant as it is. The 64
> > >> descriptors should be more than enough.
> > > I don't mind the reduction of the constant, but it would be good
> to
> > > predict what behavior might indicate this was exceeded. I guess it
> > > should be some kind of errno on an allocation request though? So
> it
> > > should be fine, but if a user hits this limit, I guess they have
> > > pretty limited options to overcome it.
> > Reducing the limit won't cause errors. It will only means that if you
> > flood the target with network packets, it will cache less packets and
> > start dropping them earlier. That means:
> > On a short packet burst, some packets will be dropped and (for TCP)
> > some
> > have to be re-transmitted. So for short bursts it can be a slight
> > disadvantage.
> > On a constant overload situation: It doesn't really make a difference
> > because the target wouldn't be able to process the packages anyway.
> It
> > might even is an advantage because the processor doesn't have to
> > process
> > packets that are already outdated and maybe re-transmitted.
> > How much RAM does this save versus having control over the size of
> > UDP and TCP RX/TX buffers like we had in the legacy stack? I recall
> > being able to control the various buffer sizes saved a LOT of memory
> > on applications I used these parameters on.
> > There we had four configuration values. Any chance this has a hint
> > in FreeBSD now or we can provide the same tuning?
> > rtems_set_udp_buffer_sizes(
> > rtems_bsdnet_config.udp_tx_buf_size,
> > rtems_bsdnet_config.udp_rx_buf_size
> > rtems_set_tcp_buffer_sizes(
> > rtems_bsdnet_config.tcp_tx_buf_size,
> > rtems_bsdnet_config.tcp_rx_buf_size
> Are you sure that this is the same buffer? The parameter in this patch
> is a driver specific ring buffer of rx descriptors. The parameter that
> you mention sounds more like a general network stack buffer (although I
> have to say that I don't know these functions of the old stack).
I know it isn't the same buffers. It is just likely this has an impact also
on fitting into a lower ram environment. And would be general not specific
to a driver.
> Regarding the sizes:
> The driver allocates one mbuf for each buffer. It's a bit tricky to tell
> exactly how big one MBUF is. FreeBSD does a lot of abstraction there.
> But a debugger tells me that after the initialization one buffer is:
> sc->rxbuf_map[0].mbuf->m_len = 2048
> That means that I reduced the buffers that are cached in the driver for
> sending data from 512 * 2kiB = 1MiB to 64 * 2kiB = 128kiB for the
> receive direction. Note that our default size for all mbufs in the stack
> is 8MiB (RTEMS_BSD_ALLOCATOR_DOMAIN_PAGE_MBUF_DEFAULT). So 1MiB is a
> relevant part of that. And that's only for one direction!
> The Tx buffers only have some management information allocated. They
> will get buffers as soon as there is something to send. But if the
> device can't send fast enough to get rid of the data, it will be most
> likely a similar amount of memory.
Yep. Just wondering if more was needed.
> Again: That's only the buffers in the driver. Not any buffers on higher
> layers.
> Best regards
> Christian
> > --joel
> > Best regards
> > Christian
> embedded brains GmbH
> Herr Christian MAUDERER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> phone: +49-89-18 94 741 - 18
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220602/f81ad8a5/attachment-0001.htm>
