[PATCH 0/7] TFTPFS: Add block and window size options
Frank Kuehndel
frank.kuehndel at embedded-brains.de
Fri Jun 3 15:22:39 UTC 2022
From: Frank Kühndel <frank.kuehndel at embedded-brains.de>
The following patches extend the TFTP file system to support
* RFC 2347 TFTP Option Extension
* RFC 2348 TFTP Blocksize Option
* RFC 7440 TFTP Windowsize Option
To benefit from improved download and upload speeds, a TFTP
server which supports at least the blocksize option must be used.
The code is still downward compatible to simple/old servers
which implement only RFC 1350.
The patches contain an extensive test suite.
The original code was in the single file tftpDriver.c where
the file system and the network aspects where entangled.
The patches split the code into files tftpfs.c for the file
system part and tftpDriver.c for the network related part.
Since both files are derived from the original tftpDriver.c,
it is possible to keep the git history working for both files
when committing the patches to the git repository. For example,
as described here:
https://devblogs.microsoft.com/oldnewthing/20190919-00/?p=102904
Yet, this method requires a merge and the history gets lost
when the commits are "rebased". I cannot say whether this
would be worth the trouble.
TFTP Files
``cpukit/include/rtems/tftp.h``
This file declares the public constants, structures, and functions
of the Trivial File Transfer Protocol (TFTP) file system.
``cpukit/libfs/src/ftpfs/tftpDriver.c``
This source file contains the implementation of a Trivial File
Transfer Protocol (TFTP) client library --- the network related
part of the code.
``cpukit/libfs/src/ftpfs/tftp_driver.h``
This file declares private functions of the Trivial File Transfer
Protocol (TFTP) client library.
``cpukit/libfs/src/ftpfs/tftpfs.c``
This source file contains the implementation of the Trivial File
Transfer Protocol (TFTP) filesystem. The code in this file handles
the file system operations (such as ``mount()``, ``open()``,
``read()``, ``write()``, ``close()`` etc.).
``spec/build/cpukit/libtftpfs.yml``
This file specifies how the RTEMS WAF build system has to compile,
link and install ``libtftpfs``.
``spec/build/testsuites/fstests/grp.yml``
link and install all filesystem test suites. The TFTP test suite
must be mentioned in this file to be build.
``spec/build/testsuites/fstests/tftpfs.yml``
link and install the TFTP test suite.
``testsuites/fstests/tftpfs/init.c``
This source file contains the test suite with all tests for
``libtftpfs``. The test suite uses functions from files
``tftpfs_interactions.c`` and ``tftpfs_udp_network_fake.c`` as
private helpers.
``testsuites/fstests/tftpfs/tftpfs_interactions.h``
This header file provides definitions and declarations of data
structures and functions used to implement network interactions
of the UDP network fake for ``libtftpfs`` tests.
``testsuites/fstests/tftpfs/tftpfs_interactions.c``
This source file contains the implementation of network interaction
functions related to the UDP network fake for ``libtftpfs`` tests.
``testsuites/fstests/tftpfs/tftpfs_udp_network_fake.h``
structures and functions used to implement the UDP network fake
``testsuites/fstests/tftpfs/tftpfs_udp_network_fake.c``
This source file contains the implementation of UDP network fake
functions related to ``libtftpfs`` testing. This code provides
fake implementations for functions like ``socket()``, ``bind()``,
``sendto()``, ``recvfrom()``, etc. which would normally be
provided by libbsd.
Frank Kühndel (7):
TFTPFS: Cleanup: Remove spaces at lines ends
TFTPFS: Duplicate tftpDriver.c to tftpfs.c
TFTPFS: Restore tftpDriver.c
TFTPFS: Implement block and window size options
TFTPFS: Add test suite framework
TFTPFS: Add tests
TFTPFS: Add more tests
cpukit/include/rtems/tftp.h | 404 +-
cpukit/libfs/src/ftpfs/tftpDriver.c | 1780 ++--
cpukit/libfs/src/ftpfs/tftp_driver.h | 76 +
cpukit/libfs/src/ftpfs/tftpfs.c | 624 ++
spec/build/cpukit/libtftpfs.yml | 3 +-
spec/build/testsuites/fstests/grp.yml | 2 +
spec/build/testsuites/fstests/tftpfs.yml | 25 +
testsuites/fstests/tftpfs/init.c | 7318 +++++++++++++++++
.../fstests/tftpfs/tftpfs_interactions.c | 984 +++
.../fstests/tftpfs/tftpfs_interactions.h | 205 +
.../fstests/tftpfs/tftpfs_udp_network_fake.c | 983 +++
.../fstests/tftpfs/tftpfs_udp_network_fake.h | 283 +
12 files changed, 12024 insertions(+), 663 deletions(-)
create mode 100644 cpukit/libfs/src/ftpfs/tftp_driver.h
create mode 100644 cpukit/libfs/src/ftpfs/tftpfs.c
create mode 100644 spec/build/testsuites/fstests/tftpfs.yml
create mode 100644 testsuites/fstests/tftpfs/init.c
create mode 100644 testsuites/fstests/tftpfs/tftpfs_interactions.c
create mode 100644 testsuites/fstests/tftpfs/tftpfs_interactions.h
create mode 100644 testsuites/fstests/tftpfs/tftpfs_udp_network_fake.c
create mode 100644 testsuites/fstests/tftpfs/tftpfs_udp_network_fake.h
2.35.3
