[PATCH 3/7] TFTPFS: Restore tftpDriver.c
Fri Jun 3 23:05:25 UTC 2022
Is this really just a move/rename? Does it preserve the git blame info?
--joel
On Fri, Jun 3, 2022, 10:22 AM Frank Kuehndel <
frank.kuehndel at embedded-brains.de> wrote:
> From: Frank Kühndel <frank.kuehndel at embedded-brains.de>
>  cpukit/libfs/src/ftpfs/tftpDriver.c | 1088 +++++++++++++++++++++++++++
>  1 file changed, 1088 insertions(+)
>  create mode 100644 cpukit/libfs/src/ftpfs/tftpDriver.c
> diff --git a/cpukit/libfs/src/ftpfs/tftpDriver.c
> b/cpukit/libfs/src/ftpfs/tftpDriver.c
> new file mode 100644
> index 0000000000..d0eadcf99a
> --- /dev/null
> +++ b/cpukit/libfs/src/ftpfs/tftpDriver.c
> @@ -0,0 +1,1088 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> + * Trivial File Transfer Protocol file system (TFTP client) for RFC 1350.
> + * Transfer file to/from remote host
> + * Copyright (c) 1998 Eric Norum <eric at norum.ca>
> + * Modifications to support reference counting in the file system are
> + * Copyright (c) 2012 embedded brains GmbH.
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS
> BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
> THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <stdio.h>
> +#include <stdlib.h>
> +#include <errno.h>
> +#include <malloc.h>
> +#include <string.h>
> +#include <unistd.h>
> +#include <fcntl.h>
> +#include <rtems.h>
> +#include <rtems/libio_.h>
> +#include <rtems/seterr.h>
> +#include <rtems/tftp.h>
> +#include <rtems/thread.h>
> +#include <sys/types.h>
> +#include <sys/socket.h>
> +#include <netinet/in.h>
> +#include <arpa/inet.h>
> +#include <netdb.h>
> +#ifdef RTEMS_NETWORKING
> +#include <rtems/rtems_bsdnet.h>
> +#endif
> +#ifdef RTEMS_TFTP_DRIVER_DEBUG
> +int rtems_tftp_driver_debug = 1;
> +#endif
> + * Range of UDP ports to try
> +#define UDP_PORT_BASE        3180
> + * Default limits
> +#define PACKET_FIRST_TIMEOUT_MILLISECONDS  400L
> +#define PACKET_TIMEOUT_MILLISECONDS        6000L
> +#define OPEN_RETRY_LIMIT                   10
> +#define IO_RETRY_LIMIT                     10
> + * TFTP opcodes
> +#define TFTP_OPCODE_RRQ     1
> +#define TFTP_OPCODE_WRQ     2
> +#define TFTP_OPCODE_DATA    3
> +#define TFTP_OPCODE_ACK     4
> +#define TFTP_OPCODE_ERROR   5
> + * Largest data transfer
> +#define TFTP_BUFSIZE        512
> + * Packets transferred between machines
> +union tftpPacket {
> +     * RRQ/WRQ packet
> +    struct tftpRWRQ {
> +        uint16_t      opcode;
> +        char                filename_mode[TFTP_BUFSIZE];
> +    } tftpRWRQ;
> +     * DATA packet
> +    struct tftpDATA {
> +        uint16_t      opcode;
> +        uint16_t      blocknum;
> +        uint8_t       data[TFTP_BUFSIZE];
> +    } tftpDATA;
> +     * ACK packet
> +    struct tftpACK {
> +        uint16_t      opcode;
> +    } tftpACK;
> +     * ERROR packet
> +    struct tftpERROR {
> +        uint16_t      opcode;
> +        uint16_t      errorCode;
> +        char                errorMessage[TFTP_BUFSIZE];
> +    } tftpERROR;
> + * State of each TFTP stream
> +struct tftpStream {
> +     * Buffer for storing most recently-received packet
> +    union tftpPacket    pkbuf;
> +     * Last block number transferred
> +     * Data transfer socket
> +    int                 socket;
> +    struct sockaddr_in  myAddress;
> +    struct sockaddr_in  farAddress;
> +     * Indices into buffer
> +    int     nleft;
> +    int     nused;
> +     * Flags
> +    int     firstReply;
> +    int     eof;
> +    int     writing;
> + * Flags for filesystem info.
> +#define TFTPFS_VERBOSE (1 << 0)
> + * TFTP File system info.
> +typedef struct tftpfs_info_s {
> +  uint32_t flags;
> +  rtems_mutex tftp_mutex;
> +  int nStreams;
> +  struct tftpStream ** volatile tftpStreams;
> +} tftpfs_info_t;
> +#define tftpfs_info_mount_table(_mt) ((tftpfs_info_t*) ((_mt)->fs_info))
> +#define tftpfs_info_pathloc(_pl)     ((tftpfs_info_t*)
> ((_pl)->mt_entry->fs_info))
> +#define tftpfs_info_iop(_iop)        (tftpfs_info_pathloc
> (&((_iop)->pathinfo)))
> + * Number of streams open at the same time
> +static const rtems_filesystem_operations_table  rtems_tftp_ops;
> +static const rtems_filesystem_file_handlers_r   rtems_tftp_handlers;
> +static bool rtems_tftp_is_directory(
> +    const char *path,
> +    size_t pathlen
> +    return path [pathlen - 1] == '/';
> +int rtems_tftpfs_initialize(
> +  rtems_filesystem_mount_table_entry_t *mt_entry,
> +  const void                           *data
> +  const char *device = mt_entry->dev;
> +  size_t devicelen = strlen (device);
> +  tftpfs_info_t *fs = NULL;
> +  char *root_path;
> +  if (devicelen == 0) {
> +    root_path = malloc (1);
> +    if (root_path == NULL)
> +      goto error;
> +    root_path [0] = '\0';
> +  else {
> +    root_path = malloc (devicelen + 2);
> +      goto error;
> +    root_path = memcpy (root_path, device, devicelen);
> +    root_path [devicelen] = '/';
> +    root_path [devicelen + 1] = '\0';
> +  fs = malloc (sizeof (*fs));
> +  if (fs == NULL)
> +    goto error;
> +  fs->flags = 0;
> +  fs->nStreams = 0;
> +  fs->tftpStreams = 0;
> +  mt_entry->fs_info = fs;
> +  mt_entry->mt_fs_root->location.node_access = root_path;
> +  mt_entry->mt_fs_root->location.handlers = &rtems_tftp_handlers;
> +  mt_entry->ops = &rtems_tftp_ops;
> +   *  Now allocate a semaphore for mutual exclusion.
> +   *  NOTE:  This could be in an fsinfo for this filesystem type.
> +  rtems_mutex_init (&fs->tftp_mutex, "TFTPFS");
> +  if (data) {
> +      char* config = (char*) data;
> +      char* token;
> +      char* saveptr;
> +      token = strtok_r (config, " ", &saveptr);
> +      while (token) {
> +          if (strcmp (token, "verbose") == 0)
> +              fs->flags |= TFTPFS_VERBOSE;
> +          token = strtok_r (NULL, " ", &saveptr);
> +  return 0;
> +error:
> +  free (fs);
> +  free (root_path);
> +  rtems_set_errno_and_return_minus_one (ENOMEM);
> + * Release a stream and clear the pointer to it
> +static void
> +releaseStream (tftpfs_info_t *fs, int s)
> +    if (fs->tftpStreams[s] && (fs->tftpStreams[s]->socket >= 0))
> +        close (fs->tftpStreams[s]->socket);
> +    rtems_mutex_lock (&fs->tftp_mutex);
> +    free (fs->tftpStreams[s]);
> +    fs->tftpStreams[s] = NULL;
> +    rtems_mutex_unlock (&fs->tftp_mutex);
> +static void
> +rtems_tftpfs_shutdown (rtems_filesystem_mount_table_entry_t* mt_entry)
> +  tftpfs_info_t *fs = tftpfs_info_mount_table (mt_entry);
> +  int            s;
> +  for (s = 0; s < fs->nStreams; s++)
> +      releaseStream (fs, s);
> +  rtems_mutex_destroy (&fs->tftp_mutex);
> +  free (fs);
> +  free (mt_entry->mt_fs_root->location.node_access);
> + * Map error message
> +static int
> +tftpErrno (struct tftpStream *tp)
> +    unsigned int tftpError;
> +    static const int errorMap[] = {
> +        EINVAL,
> +        ENOENT,
> +        EPERM,
> +        ENOSPC,
> +        EINVAL,
> +        ENXIO,
> +        EEXIST,
> +        ESRCH,
> +    tftpError = ntohs (tp->pkbuf.tftpERROR.errorCode);
> +    if (tftpError < (sizeof errorMap / sizeof errorMap[0]))
> +        return errorMap[tftpError];
> +    else
> +        return 1000 + tftpError;
> + * Send a message to make the other end shut up
> +static void
> +sendStifle (struct tftpStream *tp, struct sockaddr_in *to)
> +    int len;
> +    struct {
> +        uint16_t      opcode;
> +        char                errorMessage[12];
> +    } msg;
> +     * Create the error packet (Unknown transfer ID).
> +    msg.opcode = htons (TFTP_OPCODE_ERROR);
> +    msg.errorCode = htons (5);
> +    len = sizeof msg.opcode + sizeof msg.errorCode + 1;
> +    len += sprintf (msg.errorMessage, "GO AWAY");
> +     * Send it
> +    sendto (tp->socket, (char *)&msg, len, 0, (struct sockaddr *)to,
> sizeof *to);
> + * Wait for a data packet
> +static int
> +getPacket (struct tftpStream *tp, int retryCount)
> +    int len;
> +    struct timeval tv;
> +    if (retryCount == 0) {
> +        tv.tv_sec = PACKET_FIRST_TIMEOUT_MILLISECONDS / 1000L;
> +        tv.tv_usec = (PACKET_FIRST_TIMEOUT_MILLISECONDS % 1000L) * 1000L;
> +    else {
> +        tv.tv_sec = PACKET_TIMEOUT_MILLISECONDS / 1000L;
> +        tv.tv_usec = (PACKET_TIMEOUT_MILLISECONDS % 1000L) * 1000L;
> +    setsockopt (tp->socket, SOL_SOCKET, SO_RCVTIMEO, &tv, sizeof tv);
> +    for (;;) {
> +        union {
> +            struct sockaddr s;
> +            struct sockaddr_in i;
> +        } from;
> +        socklen_t fromlen = sizeof from;
> +        len = recvfrom (tp->socket, &tp->pkbuf,
> +                        sizeof tp->pkbuf, 0,
> +                        &from.s, &fromlen);
> +        if (len < 0)
> +            break;
> +        if (from.i.sin_addr.s_addr == tp->farAddress.sin_addr.s_addr) {
> +            if (tp->firstReply) {
> +                tp->firstReply = 0;
> +                tp->farAddress.sin_port = from.i.sin_port;
> +            if (tp->farAddress.sin_port == from.i.sin_port)
> +                break;
> +         * Packet is from someone with whom we are
> +         * not interested.  Tell them to go away.
> +        sendStifle (tp, &from.i);
> +    tv.tv_sec = 0;
> +    tv.tv_usec = 0;
> +    if (rtems_tftp_driver_debug) {
> +        if (len >= (int) sizeof tp->pkbuf.tftpACK) {
> +            int opcode = ntohs (tp->pkbuf.tftpDATA.opcode);
> +            switch (opcode) {
> +            default:
> +                printf ("TFTP: OPCODE %d\n", opcode);
> +                break;
> +            case TFTP_OPCODE_DATA:
> +                printf ("TFTP: RECV %d\n", ntohs
> (tp->pkbuf.tftpDATA.blocknum));
> +                break;
> +            case TFTP_OPCODE_ACK:
> +                printf ("TFTP: GOT ACK %d\n", ntohs
> (tp->pkbuf.tftpACK.blocknum));
> +                break;
> +        else {
> +            printf ("TFTP: %d-byte packet\n", len);
> +#endif
> +    return len;
> + * Send an acknowledgement
> +static int
> +sendAck (struct tftpStream *tp)
> +        printf ("TFTP: ACK %d\n", tp->blocknum);
> +#endif
> +     * Create the acknowledgement
> +    tp->pkbuf.tftpACK.opcode = htons (TFTP_OPCODE_ACK);
> +    tp->pkbuf.tftpACK.blocknum = htons (tp->blocknum);
> +     * Send it
> +    if (sendto (tp->socket, (char *)&tp->pkbuf, sizeof tp->pkbuf.tftpACK,
> 0,
> +                                    (struct sockaddr *)&tp->farAddress,
> +                                    sizeof tp->farAddress) < 0)
> +        return errno;
> +    return 0;
> + * Convert a path to canonical form
> +static void
> +fixPath (char *path)
> +    char *inp, *outp, *base;
> +    outp = inp = path;
> +    base = NULL;
> +    for (;;) {
> +        if (inp[0] == '.') {
> +            if (inp[1] == '\0')
> +                break;
> +            if (inp[1] == '/') {
> +                inp += 2;
> +                continue;
> +            if (inp[1] == '.') {
> +                if (inp[2] == '\0') {
> +                    if ((base != NULL) && (outp > base)) {
> +                        outp--;
> +                        while ((outp > base) && (outp[-1] != '/'))
> +                            outp--;
> +                    break;
> +                if (inp[2] == '/') {
> +                    inp += 3;
> +                    if (base == NULL)
> +                        continue;
> +                    if (outp > base) {
> +                        outp--;
> +                            outp--;
> +                    continue;
> +        if (base == NULL)
> +            base = inp;
> +        while (inp[0] != '/') {
> +            if ((*outp++ = *inp++) == '\0')
> +                return;
> +        *outp++ = '/';
> +        while (inp[0] == '/')
> +            inp++;
> +    *outp = '\0';
> +    return;
> +static void rtems_tftp_eval_path(rtems_filesystem_eval_path_context_t
> *self)
> +    int eval_flags = rtems_filesystem_eval_path_get_flags (self);
> +    if ((eval_flags & RTEMS_FS_MAKE) == 0) {
> +        int rw = RTEMS_FS_PERMS_READ | RTEMS_FS_PERMS_WRITE;
> +        if ((eval_flags & rw) != rw) {
> +            rtems_filesystem_location_info_t *currentloc =
> +                rtems_filesystem_eval_path_get_currentloc (self);
> +            char *current = currentloc->node_access;
> +            size_t currentlen = strlen (current);
> +            const char *path = rtems_filesystem_eval_path_get_path (self);
> +            size_t pathlen = rtems_filesystem_eval_path_get_pathlen
> (self);
> +            size_t len = currentlen + pathlen;
> +            rtems_filesystem_eval_path_clear_path (self);
> +            current = realloc (current, len + 1);
> +            if (current != NULL) {
> +                memcpy (current + currentlen, path, pathlen);
> +                current [len] = '\0';
> +                if (!rtems_tftp_is_directory (current, len)) {
> +                    fixPath (current);
> +                currentloc->node_access = current;
> +            } else {
> +                rtems_filesystem_eval_path_error (self, ENOMEM);
> +        } else {
> +            rtems_filesystem_eval_path_error (self, EINVAL);
> +    } else {
> +        rtems_filesystem_eval_path_error (self, EIO);
> + * The routine which does most of the work for the IMFS open handler
> +static int rtems_tftp_open_worker(
> +    rtems_libio_t *iop,
> +    char          *full_path_name,
> +    int            oflag
> +    tftpfs_info_t        *fs;
> +    struct tftpStream    *tp;
> +    int                  retryCount;
> +    struct in_addr       farAddress;
> +    int                  s;
> +    int                  len;
> +    char                 *cp1;
> +    char                 *cp2;
> +    char                 *remoteFilename;
> +    rtems_interval       now;
> +    char                 *hostname;
> +     * Get the file system info.
> +    fs = tftpfs_info_iop (iop);
> +     * Extract the host name component
> +    if (*full_path_name == '/')
> +      full_path_name++;
> +    hostname = full_path_name;
> +    cp1 = strchr (full_path_name, ':');
> +    if (!cp1) {
> +        hostname = "BOOTP_HOST";
> +#endif
> +    } else {
> +        *cp1 = '\0';
> +        ++cp1;
> +     * Convert hostname to Internet address
> +    if (strcmp (hostname, "BOOTP_HOST") == 0)
> +        farAddress = rtems_bsdnet_bootp_server_address;
> +    else
> +#endif
> +    if (inet_aton (hostname, &farAddress) == 0) {
> +        struct hostent *he = gethostbyname(hostname);
> +        if (he == NULL)
> +            return ENOENT;
> +        memcpy (&farAddress, he->h_addr, sizeof (farAddress));
> +     * Extract file pathname component
> +    if (strcmp (cp1, "BOOTP_FILE") == 0) {
> +        cp1 = rtems_bsdnet_bootp_boot_file_name;
> +#endif
> +    if (*cp1 == '\0')
> +        return ENOENT;
> +    remoteFilename = cp1;
> +    if (strlen (remoteFilename) > (TFTP_BUFSIZE - 10))
> +        return ENOENT;
> +     * Find a free stream
> +    for (s = 0 ; s < fs->nStreams ; s++) {
> +        if (fs->tftpStreams[s] == NULL)
> +        break;
> +    if (s == fs->nStreams) {
> +         * Reallocate stream pointers
> +         * Guard against the case where realloc() returns NULL.
> +        struct tftpStream **np;
> +        np = realloc (fs->tftpStreams, ++fs->nStreams * sizeof
> *fs->tftpStreams);
> +        if (np == NULL) {
> +            return ENOMEM;
> +        fs->tftpStreams = np;
> +    tp = fs->tftpStreams[s] = malloc (sizeof (struct tftpStream));
> +    if (tp == NULL)
> +        return ENOMEM;
> +    iop->data0 = s;
> +    iop->data1 = tp;
> +     * Create the socket
> +    if ((tp->socket = socket (AF_INET, SOCK_DGRAM, 0)) < 0) {
> +        return ENOMEM;
> +     * Bind the socket to a local address
> +    retryCount = 0;
> +    now = rtems_clock_get_ticks_since_boot();
> +    for (;;) {
> +        int try = (now + retryCount) % 10;
> +        tp->myAddress.sin_family = AF_INET;
> +        tp->myAddress.sin_port = htons (UDP_PORT_BASE + fs->nStreams *
> try + s);
> +        tp->myAddress.sin_addr.s_addr = htonl (INADDR_ANY);
> +        if (bind (tp->socket, (struct sockaddr *)&tp->myAddress, sizeof
> tp->myAddress) >= 0)
> +            break;
> +        if (++retryCount == 10) {
> +            return EBUSY;
> +     * Set the UDP destination to the TFTP server
> +     * port on the remote machine.
> +    tp->farAddress.sin_family = AF_INET;
> +    tp->farAddress.sin_addr = farAddress;
> +    tp->farAddress.sin_port = htons (69);
> +     * Start the transfer
> +    tp->firstReply = 1;
> +    retryCount = 0;
> +    for (;;) {
> +         * Create the request
> +        if ((oflag & O_ACCMODE) == O_RDONLY) {
> +            tp->writing = 0;
> +            tp->pkbuf.tftpRWRQ.opcode = htons (TFTP_OPCODE_RRQ);
> +        else {
> +            tp->writing = 1;
> +            tp->pkbuf.tftpRWRQ.opcode = htons (TFTP_OPCODE_WRQ);
> +        cp1 = (char *) tp->pkbuf.tftpRWRQ.filename_mode;
> +        cp2 = (char *) remoteFilename;
> +        while ((*cp1++ = *cp2++) != '\0')
> +            continue;
> +        cp2 = "octet";
> +            continue;
> +        len = cp1 - (char *)&tp->pkbuf.tftpRWRQ;
> +         * Send the request
> +        if (sendto (tp->socket, (char *)&tp->pkbuf, len, 0,
> +                    sizeof tp->farAddress) < 0) {
> +            return EIO;
> +         * Get reply
> +        len = getPacket (tp, retryCount);
> +            if (!tp->writing
> +             && (opcode == TFTP_OPCODE_DATA)
> +             && (ntohs (tp->pkbuf.tftpDATA.blocknum) == 1)) {
> +                tp->nused = 0;
> +                tp->blocknum = 1;
> +                tp->nleft = len - 2 * sizeof (uint16_t  );
> +                tp->eof = (tp->nleft < TFTP_BUFSIZE);
> +                if (sendAck (tp) != 0) {
> +                    return EIO;
> +                break;
> +            if (tp->writing
> +             && (opcode == TFTP_OPCODE_ACK)
> +             && (ntohs (tp->pkbuf.tftpACK.blocknum) == 0)) {
> +                tp->nused = 0;
> +                tp->blocknum = 1;
> +                break;
> +            if (opcode == TFTP_OPCODE_ERROR) {
> +                int e = tftpErrno (tp);
> +                return e;
> +         * Keep trying
> +        if (++retryCount >= OPEN_RETRY_LIMIT) {
> +            return EIO;
> +    return 0;
> +static int rtems_tftp_open(
> +    const char    *new_name,
> +    int            oflag,
> +    mode_t         mode
> +    char          *full_path_name;
> +    int           err;
> +    full_path_name = iop->pathinfo.node_access;
> +    if (rtems_tftp_is_directory (full_path_name, strlen
> (full_path_name))) {
> +        rtems_set_errno_and_return_minus_one (ENOTSUP);
> +    if (fs->flags & TFTPFS_VERBOSE)
> +      printf ("TFTPFS: %s\n", full_path_name);
> +    err = rtems_tftp_open_worker (iop, full_path_name, oflag);
> +    if (err != 0) {
> +       rtems_set_errno_and_return_minus_one (err);
> +    return 0;
> + * Read from a TFTP stream
> +static ssize_t rtems_tftp_read(
> +    void          *buffer,
> +    size_t         count
> +    char              *bp;
> +    struct tftpStream *tp = iop->data1;
> +    int               retryCount;
> +    int               nwant;
> +    if (!tp)
> +        rtems_set_errno_and_return_minus_one( EIO );
> +     * Read till user request is satisfied or EOF is reached
> +    bp = buffer;
> +    nwant = count;
> +    while (nwant) {
> +        if (tp->nleft) {
> +            int ncopy;
> +            if (nwant < tp->nleft)
> +                ncopy = nwant;
> +            else
> +                ncopy = tp->nleft;
> +            memcpy (bp, &tp->pkbuf.tftpDATA.data[tp->nused], ncopy);
> +            tp->nused += ncopy;
> +            tp->nleft -= ncopy;
> +            bp += ncopy;
> +            nwant -= ncopy;
> +            if (nwant == 0)
> +                break;
> +        if (tp->eof)
> +            break;
> +         * Wait for the next packet
> +        retryCount = 0;
> +        for (;;) {
> +            int len = getPacket (tp, retryCount);
> +            if (len >= (int)sizeof tp->pkbuf.tftpACK) {
> +                uint16_t   nextBlock = tp->blocknum + 1;
> +                if ((opcode == TFTP_OPCODE_DATA)
> +                 && (ntohs (tp->pkbuf.tftpDATA.blocknum) == nextBlock)) {
> +                    tp->nused = 0;
> +                    tp->nleft = len - 2 * sizeof (uint16_t);
> +                    tp->blocknum++;
> +                        rtems_set_errno_and_return_minus_one (EIO);
> +                    break;
> +                    rtems_set_errno_and_return_minus_one (tftpErrno (tp));
> +             * Keep trying?
> +            if (++retryCount == IO_RETRY_LIMIT)
> +    return count - nwant;
> + * Flush a write buffer and wait for acknowledgement
> +static int rtems_tftp_flush (struct tftpStream *tp)
> +    int wlen, rlen;
> +    int retryCount = 0;
> +    wlen = tp->nused + 2 * sizeof (uint16_t  );
> +    for (;;) {
> +        tp->pkbuf.tftpDATA.opcode = htons (TFTP_OPCODE_DATA);
> +        tp->pkbuf.tftpDATA.blocknum = htons (tp->blocknum);
> +            printf ("TFTP: SEND %d (%d)\n", tp->blocknum, tp->nused);
> +#endif
> +        if (sendto (tp->socket, (char *)&tp->pkbuf, wlen, 0,
> +                                        (struct sockaddr
> *)&tp->farAddress,
> +            return EIO;
> +        rlen = getPacket (tp, retryCount);
> +         * Our last packet won't necessarily be acknowledged!
> +        if ((rlen < 0) && (tp->nused < sizeof tp->pkbuf.tftpDATA.data))
> +                return 0;
> +        if (rlen >= (int)sizeof tp->pkbuf.tftpACK) {
> +            int opcode = ntohs (tp->pkbuf.tftpACK.opcode);
> +            if ((opcode == TFTP_OPCODE_ACK)
> +             && (ntohs (tp->pkbuf.tftpACK.blocknum) == tp->blocknum)) {
> +                tp->nused = 0;
> +                tp->blocknum++;
> +                return 0;
> +                return tftpErrno (tp);
> +         * Keep trying?
> +            return EIO;
> + * Close a TFTP stream
> +static int rtems_tftp_close(
> +    int                e = 0;
> +    if (!tp)
> +    if (tp->writing)
> +        e = rtems_tftp_flush (tp);
> +    if (!tp->eof && !tp->firstReply) {
> +         * Tell the other end to stop
> +        rtems_interval ticksPerSecond;
> +        sendStifle (tp, &tp->farAddress);
> +        ticksPerSecond = rtems_clock_get_ticks_per_second();
> +        rtems_task_wake_after (1 + ticksPerSecond / 10);
> +    releaseStream (fs, iop->data0);
> +    if (e)
> +        rtems_set_errno_and_return_minus_one (e);
> +    return 0;
> +static ssize_t rtems_tftp_write(
> +    const void      *buffer,
> +    size_t           count
> +    const char        *bp;
> +    int               nleft, nfree, ncopy;
> +     * Bail out if an error has occurred
> +    if (!tp->writing)
> +     * Write till user request is satisfied
> +     * Notice that the buffer is flushed as soon as it is filled rather
> +     * than waiting for the next write or a close.  This ensures that
> +     * the flush in close writes a less than full buffer so the far
> +     * end can detect the end-of-file condition.
> +    bp = buffer;
> +    nleft = count;
> +    while (nleft) {
> +        nfree = sizeof tp->pkbuf.tftpDATA.data - tp->nused;
> +        if (nleft < nfree)
> +            ncopy = nleft;
> +        else
> +            ncopy = nfree;
> +        memcpy (&tp->pkbuf.tftpDATA.data[tp->nused], bp, ncopy);
> +        nleft -= ncopy;
> +        bp += ncopy;
> +        if (tp->nused == sizeof tp->pkbuf.tftpDATA.data) {
> +            int e = rtems_tftp_flush (tp);
> +            if (e) {
> +                tp->writing = 0;
> +    return count;
> + * Dummy version to let fopen(xxxx,"w") work properly.
> +static int rtems_tftp_ftruncate(
> +    rtems_libio_t   *iop RTEMS_UNUSED,
> +    off_t            count RTEMS_UNUSED
> +    return 0;
> +static int rtems_tftp_fstat(
> +    const rtems_filesystem_location_info_t *loc,
> +    struct stat                            *buf
> +    const char *path = loc->node_access;
> +    size_t pathlen = strlen (path);
> +    buf->st_mode = S_IRWXU | S_IRWXG | S_IRWXO
> +        | (rtems_tftp_is_directory (path, pathlen) ? S_IFDIR : S_IFREG);
> +    return 0;
> +static int rtems_tftp_clone(
> +    rtems_filesystem_location_info_t *loc
> +    int rv = 0;
> +    loc->node_access = strdup (loc->node_access);
> +    if (loc->node_access == NULL) {
> +        errno = ENOMEM;
> +        rv = -1;
> +    return rv;
> +static void rtems_tftp_free_node_info(
> +    free (loc->node_access);
> +static bool rtems_tftp_are_nodes_equal(
> +  const rtems_filesystem_location_info_t *a,
> +  const rtems_filesystem_location_info_t *b
> +  return strcmp (a->node_access, b->node_access) == 0;
> +static const rtems_filesystem_operations_table  rtems_tftp_ops = {
> +    .lock_h = rtems_filesystem_default_lock,
> +    .unlock_h = rtems_filesystem_default_unlock,
> +    .eval_path_h = rtems_tftp_eval_path,
> +    .link_h = rtems_filesystem_default_link,
> +    .are_nodes_equal_h = rtems_tftp_are_nodes_equal,
> +    .mknod_h = rtems_filesystem_default_mknod,
> +    .rmnod_h = rtems_filesystem_default_rmnod,
> +    .fchmod_h = rtems_filesystem_default_fchmod,
> +    .chown_h = rtems_filesystem_default_chown,
> +    .clonenod_h = rtems_tftp_clone,
> +    .freenod_h = rtems_tftp_free_node_info,
> +    .mount_h = rtems_filesystem_default_mount,
> +    .unmount_h = rtems_filesystem_default_unmount,
> +    .fsunmount_me_h = rtems_tftpfs_shutdown,
> +    .utimens_h = rtems_filesystem_default_utimens,
> +    .symlink_h = rtems_filesystem_default_symlink,
> +    .readlink_h = rtems_filesystem_default_readlink,
> +    .rename_h = rtems_filesystem_default_rename,
> +    .statvfs_h = rtems_filesystem_default_statvfs
> +static const rtems_filesystem_file_handlers_r rtems_tftp_handlers = {
> +   .open_h = rtems_tftp_open,
> +   .close_h = rtems_tftp_close,
> +   .read_h = rtems_tftp_read,
> +   .write_h = rtems_tftp_write,
> +   .ioctl_h = rtems_filesystem_default_ioctl,
> +   .lseek_h = rtems_filesystem_default_lseek,
> +   .fstat_h = rtems_tftp_fstat,
> +   .ftruncate_h = rtems_tftp_ftruncate,
> +   .fsync_h = rtems_filesystem_default_fsync_or_fdatasync,
> +   .fdatasync_h = rtems_filesystem_default_fsync_or_fdatasync,
> +   .fcntl_h = rtems_filesystem_default_fcntl,
> +   .kqfilter_h = rtems_filesystem_default_kqfilter,
> +   .mmap_h = rtems_filesystem_default_mmap,
> +   .poll_h = rtems_filesystem_default_poll,
> +   .readv_h = rtems_filesystem_default_readv,
> +   .writev_h = rtems_filesystem_default_writev
> 2.35.3
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220603/82c2ce0f/attachment-0001.htm>
