[PATCH 1/6] bsp/lpc32xx: Fix FIQ interrupt support
Wed Jun 8 00:52:07 UTC 2022
OK
Thanks
On 8/6/2022 12:02 am, Sebastian Huber wrote:
> Do not sporadically service interrupts configured as FIQ by the IRQ
> interrupt dispatch.
>  bsps/arm/lpc32xx/irq/irq.c | 23 +++++++++++++----------
>  1 file changed, 13 insertions(+), 10 deletions(-)
> diff --git a/bsps/arm/lpc32xx/irq/irq.c b/bsps/arm/lpc32xx/irq/irq.c
> index e10393265b..947faca52c 100644
> --- a/bsps/arm/lpc32xx/irq/irq.c
> +++ b/bsps/arm/lpc32xx/irq/irq.c
> @@ -7,7 +7,7 @@
> - * Copyright (c) 2009 embedded brains GmbH.  All rights reserved.
> + * Copyright (C) 2009, 2022 embedded brains GmbH
>   * The license and distribution terms for this file may be
>   * found in the file LICENSE in this distribution or at
> @@ -23,12 +23,8 @@
>  #include <bsp/linker-symbols.h>
>  #include <bsp/mmu.h>
> - * Mask out SIC 1 and 2 IRQ request. There is no need to mask out the FIQ,
> - * since a pending FIQ would be a fatal error.  The default handler will be
> - * invoked in this case.
> -#define LPC32XX_MIC_STATUS_MASK (~0x3U)
> +/* Mask out SIC 1 and 2 IRQ/FIQ requests */
> +#define LPC32XX_MIC_STATUS_MASK 0x3ffffffcU
>  typedef union {
>    struct {
> @@ -211,7 +207,14 @@ lpc32xx_irq_activation_type lpc32xx_irq_get_activation_type(rtems_vector_number
>  void bsp_interrupt_dispatch(void)
> -  uint32_t status = lpc32xx.mic.sr & LPC32XX_MIC_STATUS_MASK;
> +   * Do not dispatch interrupts configured as FIQ.  Use the corresponding
> +   * interrupt type register to mask these interrupts.  The status register may
> +   * indicate an interrupt configured for FIQ before the FIQ exception is
> +   * serviced by the processor.
> +  uint32_t status = (lpc32xx.mic.sr & ~lpc32xx.mic.itr) &
> +    LPC32XX_MIC_STATUS_MASK;
>    uint32_t er_mic = lpc32xx.mic.er;
>    uint32_t er_sic_1 = lpc32xx.sic_1.er;
>    uint32_t er_sic_2 = lpc32xx.sic_2.er;
> @@ -223,11 +226,11 @@ void bsp_interrupt_dispatch(void)
>    if (status != 0) {
>      vector = lpc32xx_irq_get_index(status);
>    } else {
> -    status = lpc32xx.sic_1.sr;
> +    status = lpc32xx.sic_1.sr & ~lpc32xx.sic_1.itr;
>      if (status != 0) {
>        vector = lpc32xx_irq_get_index(status) + LPC32XX_IRQ_MODULE_SIC_1;
>      } else {
> -      status = lpc32xx.sic_2.sr;
> +      status = lpc32xx.sic_2.sr & ~lpc32xx.sic_2.itr;
>        if (status != 0) {
>          vector = lpc32xx_irq_get_index(status) + LPC32XX_IRQ_MODULE_SIC_2;
>        } else {
