[PATCH] CONTRIBUTING: Warn about white space changes
Sebastian Huber
Wed Jun 8 12:57:30 UTC 2022
CONTRIBUTING.rst | 12 ++++++------
1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/CONTRIBUTING.rst b/CONTRIBUTING.rst
index 79a42db1..36cd91de 100644
--- a/CONTRIBUTING.rst
+++ b/CONTRIBUTING.rst
@@ -279,6 +279,12 @@ original FreeBSD code.
Rules for Modifying FreeBSD Source
+Do not format original FreeBSD code. Do not perform white space changes even
+if you get git commit warnings. **Check your editor settings so that it
+does not perform white space changes automatically**, for example adding a
+newline to the end of the file. White space changes may result in conflicts
+during updates, especially changes at the end of a file.
Changes in FreeBSD files must be done using ``__rtems__`` C pre-processor guards.
This makes synchronization with the FreeBSD upstream easier and is very
important. Patches which do not follow these rules will be rejected. Only add
@@ -380,12 +386,6 @@ In general, provide empty header files and do not guard includes.
For new code use
`STYLE(9) <http://www.freebsd.org/cgi/man.cgi?query=style&apropos=0&sektion=9>`_.
-Do not format original FreeBSD code. Do not perform white space changes even
-if you get git commit warnings. Check your editor settings so that it doesn't
-perform white space changes automatically, for example adding a newline to the
-end of the file. White space changes may result in conflicts during updates,
-especially changes at the end of a file.
Automatically Generated FreeBSD Files
2.35.3
