[PATCH 5/5] testsuites/libtests/malloctest: fix warning
Thu Jun 9 06:03:50 UTC 2022
On 08/06/2022 15:34, Matthew Joyce wrote:
> @@ -118,13 +116,6 @@ static void test_realloc(void)
>     malloc_walk_ok = malloc_walk( 1234, false );
>     rtems_test_assert( malloc_walk_ok );
>     _Thread_Dispatch_enable( _Per_CPU_Get() );
> -   *  Realloc with a bad pointer to force a point
> -  p4 = realloc( test_realloc, 32 );
> -  p4 = _realloc_r( NULL, NULL, 1 );
>   #define TEST_HEAP_SIZE 2048
> @@ -1526,8 +1517,6 @@ static void test_early_malloc( void )
>     rtems_test_assert( p != q );
>     rtems_test_assert( q[0] == 0 );
> -  free( q );
>     r = realloc( q, 128 );
>     rtems_test_assert( r == q );
Some tests do things you should normally not do. So, sometimes a warning
is hard to avoid. We should definitely not remove valid tests cases to
fix warnings.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
