[libbsd 0/9] Remove dependency on RTEMS_POSIX_API
Fri Jun 10 06:08:26 UTC 2022
Sebastian Huber (9):
  ipsec-tools: Do not use signals
  wpa: Do not use signals
  wpa: Use CONFIG_ELOOP_KQUEUE
  openssl: Do not use signals
  ping: Do not use signals
  ping6: Do not use signals
  wlanstats: Do not use signals
  netstat: Do not use signals
  build: Do not require RTEMS_POSIX_API
 freebsd/contrib/wpa/src/utils/eloop.c         | 19 +++++++++++++++
 freebsd/crypto/openssl/apps/ocsp.c            |  2 +-
 freebsd/crypto/openssl/apps/openssl.c         |  2 ++
 .../apps/rtems-bsd-openssl-ocsp-data.h        |  2 --
 freebsd/crypto/openssl/crypto/ui/ui_openssl.c | 10 ++++++++
 freebsd/sbin/ping/ping.c                      |  8 +++++++
 freebsd/sbin/ping6/ping6.c                    | 16 +++++++++++++
 freebsd/tools/tools/net80211/wlanstats/main.c | 22 +++++++-----------
 .../wlanstats/rtems-bsd-wlanstats-main-data.h |  2 --
 freebsd/usr.bin/netstat/if.c                  | 19 ++++-----------
 .../netstat/rtems-bsd-netstat-if-data.h       |  2 --
 ipsec-tools/src/racoon/privsep.c              | 12 +++++++++-
 .../racoon/rtems-bsd-racoon-session-data.h    |  3 ---
 ipsec-tools/src/racoon/session.c              | 23 +++++++++++--------
 wscript                                       |  4 ----
 15 files changed, 92 insertions(+), 54 deletions(-)
2.35.3
