[PATCH 00/13] jffs2: Update baseline version to Linux v5.9
Fri Jun 10 08:20:52 UTC 2022
Al Viro (1):
  jffs2: fix use-after-free on symlink traversal
Christoph Hellwig (1):
  jffs2: Remove jffs2_gc_fetch_page and jffs2_gc_release_page
Gustavo A. R. Silva (2):
  jffs2: Replace zero-length array with flexible-array
  treewide: Use fallthrough pseudo-keyword
Jia-Ju Bai (1):
  jffs2: Fix possible null-pointer dereferences in
    jffs2_add_frag_to_fragtree()
Joel Stanley (1):
  Revert "jffs2: Fix possible null-pointer dereferences in
    jffs2_add_frag_to_fragtree()"
Kees Cook (1):
  treewide: Remove uninitialized_var() usage
Masahiro Yamada (1):
  jffs2: Remove C++ style comments from uapi header
Matthew Wilcox (1):
  Convert jffs2 acl to struct_size
Sebastian Huber (2):
  jffs2: Use RTEMS_CONTAINER_OF
Wenwen Wang (1):
  jffs2: Fix memory leak in jffs2_scan_eraseblock() error path
Zhe Li (1):
  jffs2: fix jffs2 mounting failure
 cpukit/libfs/src/jffs2/VERSION                |  4 +--
 cpukit/libfs/src/jffs2/include/linux/jffs2.h  |  5 ---
 cpukit/libfs/src/jffs2/src/acl.h              |  1 +
 cpukit/libfs/src/jffs2/src/erase.c            |  2 +-
 cpukit/libfs/src/jffs2/src/fs-rtems.c         | 24 -------------
 cpukit/libfs/src/jffs2/src/gc.c               | 35 ++++++++++++++-----
 cpukit/libfs/src/jffs2/src/nodelist.h         |  2 +-
 cpukit/libfs/src/jffs2/src/os-rtems.h         |  5 +--
 cpukit/libfs/src/jffs2/src/readinode.c        |  5 +--
 .../libfs/src/jffs2/src/rtems-jffs2-config.h  |  1 +
 cpukit/libfs/src/jffs2/src/scan.c             |  8 +++--
 cpukit/libfs/src/jffs2/src/summary.h          |  4 +--
 12 files changed, 45 insertions(+), 51 deletions(-)
2.35.3
