[PATCH 2/5] bsps/stm32h7: import stm32h757i-eval QSPI memory high-level driver
Karel Gardas karel at functional.vision
Fri Jun 10 12:49:27 UTC 2022
Sponsored-By:	Precidata
 .../stm32h757i-eval/stm32h747i_eval_conf.h    |  130 ++
 .../stm32h757i-eval/stm32h747i_eval_errno.h   |  105 ++
 .../stm32h757i-eval/stm32h747i_eval_qspi.c    | 1088 +++++++++++++++++
 .../stm32h757i-eval/stm32h747i_eval_qspi.h    |  284 +++++
 4 files changed, 1607 insertions(+)
 create mode 100644 bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h747i_eval_conf.h
 create mode 100644 bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h747i_eval_errno.h
 create mode 100644 bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h747i_eval_qspi.c
 create mode 100644 bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h747i_eval_qspi.h
diff --git a/bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h747i_eval_conf.h b/bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h747i_eval_conf.h
new file mode 100644
index 0000000000..673125eec3
--- /dev/null
+++ b/bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h747i_eval_conf.h
@@ -0,0 +1,130 @@
+/* SPDX-License-Identifier: BSD-3-Clause */
+  * @file    stm32h747i_eval_config.h
+  * @author  MCD Application Team
+  * @brief   STM32H747I_EVAL board configuration file.
+  * @attention
+  * Copyright (c) 2019 STMicroelectronics.
+  * All rights reserved.
+  * This software is licensed under terms that can be found in the LICENSE file
+  * in the root directory of this software component.
+  * If no LICENSE file comes with this software, it is provided AS-IS.
+ * RTEMS committer clarification comment on license above:
+ * This file comes from STM32CubeH7 project and is located here:
+ * https://github.com/STMicroelectronics/STM32CubeH7/blob/master/Drivers/BSP/STM32H747I-EVAL/stm32h747i_eval_conf_template.h
+ * The file root directory is:
+ * https://github.com/STMicroelectronics/STM32CubeH7/tree/master/Drivers/BSP/STM32H747I-EVAL
+ * This directory contains LICENSE.md file with a following license text:
+ * Copyright 2019 STMicroelectronics.
+ * Redistribution and use in source and binary forms, with or without modification,
+ * are permitted provided that the following conditions are met:
+ * 1. Redistributions of source code must retain the above copyright notice, this
+ * list of conditions and the following disclaimer.
+ * 2. Redistributions in binary form must reproduce the above copyright notice,
+ * this list of conditions and the following disclaimer in the documentation and/or
+ * other materials provided with the distribution.
+ * 3. Neither the name of the copyright holder nor the names of its contributors
+ * may be used to endorse or promote products derived from this software without
+ * specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
+ * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+ * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR
+ * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
+ * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
+ * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON
+ * ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+ * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
+ * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+/* Define to prevent recursive inclusion -------------------------------------*/
+#ifndef STM32H747I_EVAL_CONFIG_H
+#define STM32H747I_EVAL_CONFIG_H
+#ifdef __cplusplus
+ extern "C" {
+#endif
+/* Includes ------------------------------------------------------------------*/
+#include "stm32h7xx_hal.h"
+   /* COM define */
+#define USE_COM_LOG                         0U
+   /* IO class usage define */
+#define USE_BSP_IO_CLASS                    1U
+   /* JOY usage define */
+#define USE_BSP_JOY_FEATURE                 1U
+   /* POT usage define */
+#define USE_BSP_POT_FEATURE                 1U
+   /* LCD controllers defines */
+#define USE_LCD_CTRL_OTM8009A               1U
+#define USE_LCD_CTRL_ADV7533                1U
+#define LCD_LAYER_0_ADDRESS                 0xD0000000U
+#define LCD_LAYER_1_ADDRESS                 0xD0200000U
+   /* SD high performance usage define */
+#define USE_SD_HIGH_PERFORMANCE             0U
+   /*DMA2D to fill RGB rectangle usage define*/
+#define USE_DMA2D_TO_FILL_RGB_RECT          0U
+   /* Audio codecs defines */
+#define USE_AUDIO_CODEC_WM8994              1U
+#define USE_AUDIO_CODEC_ADV7533             1U
+   /* Default Audio IN internal buffer size */
+#define DEFAULT_AUDIO_IN_BUFFER_SIZE        256U
+/* TS supported features defines */
+#define USE_TS_GESTURE                      1U
+#define USE_TS_MULTI_TOUCH                  1U
+/* Default TS touch number */
+#define TS_TOUCH_NBR                        2U
+/* Default EEPROM max trials */
+#define EEPROM_MAX_TRIALS                   3000U
+/* IRQ priorities */
+#define BSP_SRAM_IT_PRIORITY                15U
+#define BSP_SDRAM_IT_PRIORITY               15U
+#define BSP_IOEXPANDER_IT_PRIORITY          15U
+#define BSP_BUTTON_USER_IT_PRIORITY         15U
+#define BSP_BUTTON_WAKEUP_IT_PRIORITY       15U
+#define BSP_BUTTON_TAMPER_IT_PRIORITY       15U
+#define BSP_AUDIO_OUT_IT_PRIORITY           14U
+#define BSP_AUDIO_IN_IT_PRIORITY            15U
+#define BSP_SD_IT_PRIORITY                  14U
+#define BSP_SD_RX_IT_PRIORITY               14U
+#define BSP_SD_TX_IT_PRIORITY               15U
+#define BSP_TS_IT_PRIORITY                  15U
+#ifdef __cplusplus
+#endif
+#endif /* STM32H747I_EVAL_CONFIG_H */
diff --git a/bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h747i_eval_errno.h b/bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h747i_eval_errno.h
index 0000000000..8b928c98a1
--- /dev/null
+++ b/bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h747i_eval_errno.h
@@ -0,0 +1,105 @@
+* @file    stm32h747i_eval_errno.h
+* @author  MCD Application Team
+* @brief   Error Code.
+* @attention
+* Copyright (c) 2019 STMicroelectronics.
+* All rights reserved.
+* This software is licensed under terms that can be found in the LICENSE file
+* in the root directory of this software component.
+* If no LICENSE file comes with this software, it is provided AS-IS.
+ * https://github.com/STMicroelectronics/STM32CubeH7/blob/master/Drivers/BSP/STM32H747I-EVAL/stm32h747i_eval_errno.h
+#ifndef STM32H747I_EVAL_ERRNO_H
+#define STM32H747I_EVAL_ERRNO_H
+#ifdef __cplusplus
+extern "C" {
+#endif
+/* Common Error codes */
+#define BSP_ERROR_NONE                    0
+#define BSP_ERROR_NO_INIT                -1
+#define BSP_ERROR_WRONG_PARAM            -2
+#define BSP_ERROR_BUSY                   -3
+#define BSP_ERROR_PERIPH_FAILURE         -4
+#define BSP_ERROR_COMPONENT_FAILURE      -5
+#define BSP_ERROR_UNKNOWN_FAILURE        -6
+#define BSP_ERROR_UNKNOWN_COMPONENT      -7
+#define BSP_ERROR_BUS_FAILURE            -8
+#define BSP_ERROR_CLOCK_FAILURE          -9
+#define BSP_ERROR_MSP_FAILURE            -10
+#define BSP_ERROR_FEATURE_NOT_SUPPORTED  -11
+/* BSP OSPI error codes */
+#define BSP_ERROR_QSPI_ASSIGN_FAILURE     -24
+#define BSP_ERROR_QSPI_SETUP_FAILURE      -25
+#define BSP_ERROR_QSPI_MMP_LOCK_FAILURE   -26
+#define BSP_ERROR_QSPI_MMP_UNLOCK_FAILURE -27
+/* BSP TS error code */
+#define BSP_ERROR_TS_TOUCH_NOT_DETECTED   -30
+/* BSP BUS error codes */
+#define BSP_ERROR_BUS_TRANSACTION_FAILURE    -100
+#define BSP_ERROR_BUS_ARBITRATION_LOSS       -101
+#define BSP_ERROR_BUS_ACKNOWLEDGE_FAILURE    -102
+#define BSP_ERROR_BUS_PROTOCOL_FAILURE       -103
+#define BSP_ERROR_BUS_MODE_FAULT             -104
+#define BSP_ERROR_BUS_FRAME_ERROR            -105
+#define BSP_ERROR_BUS_CRC_ERROR              -106
+#define BSP_ERROR_BUS_DMA_FAILURE            -107
+#ifdef __cplusplus
+#endif
+#endif /* STM32H747I_EVAL_ERRNO_H */
diff --git a/bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h747i_eval_qspi.c b/bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h747i_eval_qspi.c
index 0000000000..6614200509
--- /dev/null
+++ b/bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h747i_eval_qspi.c
@@ -0,0 +1,1088 @@
+  * @file    stm32h747i_eval_qspi.c
+  * @brief   This file includes a standard driver for the MT25TL01G QSPI
+  *          memory mounted on STM32H747I-EVAL board.
+  @verbatim
+  How To use this driver:
+   - This driver is used to drive the MT25TL01G QSPI external
+       memory mounted on STM32H747I-EVAL evaluation board.
+   - This driver need a specific component driver (MT25TL01G) to be included with.
+  Driver description:
+   - Initialization steps:
+       + Initialize the QPSI external memory using the BSP_QSPI_Init() function. This
+            function includes the MSP layer hardware resources initialization and the
+            QSPI interface with the external memory.
+         STR and DTR transfer rates are supported.
+         SPI, SPI 2-IO, SPI-4IO and QPI modes are supported
+   - QSPI memory operations
+       + QSPI memory can be accessed with read/write operations once it is
+            initialized.
+            Read/write operation can be performed with AHB access using the functions
+            BSP_QSPI_Read()/BSP_QSPI_Write().
+       + The function BSP_QSPI_GetInfo() returns the configuration of the QSPI memory.
+            (see the QSPI memory data sheet)
+       + Perform erase block operation using the function BSP_QSPI_EraseBlock() and by
+            specifying the block address. You can perform an erase operation of the whole
+            chip by calling the function BSP_QSPI_EraseChip().
+       + The function BSP_QSPI_GetStatus() returns the current status of the QSPI memory.
+       + The function BSP_QSPI_EnableMemoryMappedMode enables the QSPI memory mapped mode
+       + The function BSP_QSPI_DisableMemoryMappedMode disables the QSPI memory mapped mode
+       + The function BSP_QSPI_ConfigFlash() allow to configure the QSPI mode and transfer rate
+  Note:
+    Regarding the "Instance" parameter, needed for all functions, it is used to select
+    an QSPI instance. On the STM32H747I_EVAL board, there's one instance. Then, this
+    parameter should be 0.
+  @endverbatim
+  * @attention
+ * https://github.com/STMicroelectronics/STM32CubeH7/blob/master/Drivers/BSP/STM32H747I-EVAL/stm32h747i_eval_qspi.c
+#include "stm32h747i_eval_qspi.h"
+/** @addtogroup BSP
+/** @addtogroup STM32H747I_EVAL
+/** @defgroup STM32H747I_EVAL_QSPI QSPI
+/** @defgroup STM32H747I_EVAL_QSPI_Exported_Variables Exported Variables
+QSPI_HandleTypeDef hqspi;
+BSP_QSPI_Ctx_t     QSPI_Ctx[QSPI_INSTANCES_NUMBER];
+/* Private functions ---------------------------------------------------------*/
+/** @defgroup STM32H747I_EVAL_QSPI_Private_Functions Private Functions
+static void QSPI_MspInit(QSPI_HandleTypeDef *hQspi);
+static void QSPI_MspDeInit(QSPI_HandleTypeDef *hSspi);
+static int32_t QSPI_ResetMemory(uint32_t Instance);
+static int32_t QSPI_DummyCyclesCfg(uint32_t Instance);
+/** @defgroup STM32H747I_EVAL_QSPI_Exported_Functions Exported Functions
+  * @brief  Initializes the QSPI interface.
+  * @param  Instance   QSPI Instance
+  * @param  Init       QSPI Init structure
+  * @retval BSP status
+int32_t BSP_QSPI_Init(uint32_t Instance, BSP_QSPI_Init_t *Init)
+  int32_t ret = BSP_ERROR_NONE;
+  BSP_QSPI_Info_t pInfo;
+  MX_QSPI_Init_t qspi_init;
+  /* Table to handle clock prescalers:
+  1: For STR mode to reach max 100Mhz
+  3: For DTR mode to reach max 50Mhz
+  static const uint32_t PrescalerTab[2] = {1, 3};
+  /* Check if the instance is supported */
+  if(Instance >= QSPI_INSTANCES_NUMBER)
+    ret = BSP_ERROR_WRONG_PARAM;
+  else
+    /* Check if instance is already initialized */
+    if(QSPI_Ctx[Instance].IsInitialized == QSPI_ACCESS_NONE)
+#if (USE_HAL_QSPI_REGISTER_CALLBACKS == 1)
+      /* Register the QSPI MSP Callbacks */
+      if(QSPI_Ctx[Instance].IsMspCallbacksValid == 0UL)
+        if(BSP_QSPI_RegisterDefaultMspCallbacks(Instance) != BSP_ERROR_NONE)
+          ret = BSP_ERROR_PERIPH_FAILURE;
+#else
+      /* Msp QSPI initialization */
+      QSPI_MspInit(&hqspi);
+#endif /* USE_HAL_QSPI_REGISTER_CALLBACKS */
+      if(ret == BSP_ERROR_NONE)
+        /* STM32 QSPI interface initialization */
+        (void)MT25TL01G_GetFlashInfo(&pInfo);
+        qspi_init.ClockPrescaler = PrescalerTab[Init->TransferRate];
+        qspi_init.DualFlashMode  = QSPI_DUALFLASH_ENABLE;
+        qspi_init.FlashSize      = (uint32_t)POSITION_VAL((uint32_t)pInfo.FlashSize) - 1U;
+        qspi_init.SampleShifting = (Init->TransferRate == BSP_QSPI_STR_TRANSFER) ? QSPI_SAMPLE_SHIFTING_HALFCYCLE : QSPI_SAMPLE_SHIFTING_NONE;
+        if(MX_QSPI_Init(&hqspi, &qspi_init) != HAL_OK)
+        }/* QSPI memory reset */
+        else if(QSPI_ResetMemory(Instance) != BSP_ERROR_NONE)
+          ret = BSP_ERROR_COMPONENT_FAILURE;
+        }/* Force Flash enter 4 Byte address mode */
+        else if(MT25TL01G_AutoPollingMemReady(&hqspi, QSPI_Ctx[Instance].InterfaceMode) != MT25TL01G_OK)
+        else if(MT25TL01G_Enter4BytesAddressMode(&hqspi, QSPI_Ctx[Instance].InterfaceMode) != MT25TL01G_OK)
+        }/* Configuration of the dummy cycles on QSPI memory side */
+        else if(QSPI_DummyCyclesCfg(Instance) != BSP_ERROR_NONE)
+        else
+          /* Configure Flash to desired mode */
+          if(BSP_QSPI_ConfigFlash(Instance, Init->InterfaceMode, Init->TransferRate) != BSP_ERROR_NONE)
+  /* Return BSP status */
+  return ret;
+  * @brief  De-Initializes the QSPI interface.
+int32_t BSP_QSPI_DeInit(uint32_t Instance)
+  else
+    if(QSPI_Ctx[Instance].IsInitialized == QSPI_ACCESS_MMP)
+      if(BSP_QSPI_DisableMemoryMappedMode(Instance) != BSP_ERROR_NONE)
+      /* Set default QSPI_Ctx values */
+      QSPI_Ctx[Instance].IsInitialized = QSPI_ACCESS_NONE;
+      QSPI_Ctx[Instance].InterfaceMode = BSP_QSPI_SPI_MODE;
+      QSPI_Ctx[Instance].TransferRate  = BSP_QSPI_STR_TRANSFER;
+      QSPI_Ctx[Instance].DualFlashMode = QSPI_DUALFLASH_ENABLE;
+#if (USE_HAL_QSPI_REGISTER_CALLBACKS == 0)
+      QSPI_MspDeInit(&hqspi);
+#endif /* (USE_HAL_QSPI_REGISTER_CALLBACKS == 0) */
+      /* Call the DeInit function to reset the driver */
+      if (HAL_QSPI_DeInit(&hqspi) != HAL_OK)
+  return ret;
+  * @param  hQspi       QSPI handle
+  * @param  Config      QSPI configuration structure
+__weak HAL_StatusTypeDef MX_QSPI_Init(QSPI_HandleTypeDef *hQspi, MX_QSPI_Init_t *Config)
+  /* QSPI initialization */
+  /* QSPI freq = HCLK /(1 + ClockPrescaler) Mhz */
+  hQspi->Instance                = QUADSPI;
+  hQspi->Init.ClockPrescaler     = Config->ClockPrescaler;
+  hQspi->Init.FifoThreshold      = 1;
+  hQspi->Init.SampleShifting     = Config->SampleShifting;
+  hQspi->Init.FlashSize          = Config->FlashSize;
+  hQspi->Init.ChipSelectHighTime = QSPI_CS_HIGH_TIME_4_CYCLE; /* Min 50ns for nonRead */
+  hQspi->Init.ClockMode          = QSPI_CLOCK_MODE_0;
+  hQspi->Init.FlashID            = QSPI_FLASH_ID_1;
+  hQspi->Init.DualFlash          = Config->DualFlashMode;
+  return HAL_QSPI_Init(hQspi);
+  * @brief Default BSP QSPI Msp Callbacks
+int32_t BSP_QSPI_RegisterDefaultMspCallbacks (uint32_t Instance)
+  else
+    /* Register MspInit/MspDeInit Callbacks */
+    if(HAL_QSPI_RegisterCallback(&hqspi, HAL_QSPI_MSPINIT_CB_ID, QSPI_MspInit) != HAL_OK)
+    else if(HAL_QSPI_RegisterCallback(&hqspi, HAL_QSPI_MSPDEINIT_CB_ID, QSPI_MspDeInit) != HAL_OK)
+    else
+      QSPI_Ctx[Instance].IsMspCallbacksValid = 1U;
+  return ret;
+  * @brief BSP QSPI Msp Callback registering
+  * @param CallBacks    pointer to MspInit/MspDeInit callbacks functions
+int32_t BSP_QSPI_RegisterMspCallbacks (uint32_t Instance, BSP_QSPI_Cb_t *CallBacks)
+  else
+    if(HAL_QSPI_RegisterCallback(&hqspi, HAL_QSPI_MSPINIT_CB_ID, CallBacks->pMspInitCb) != HAL_OK)
+    else if(HAL_QSPI_RegisterCallback(&hqspi, HAL_QSPI_MSPDEINIT_CB_ID, CallBacks->pMspDeInitCb) != HAL_OK)
+    else
+  return ret;
+#endif /* (USE_HAL_QSPI_REGISTER_CALLBACKS == 1) */
+  * @brief  Reads an amount of data from the QSPI memory.
+  * @param  Instance  QSPI instance
+  * @param  pData     Pointer to data to be read
+  * @param  ReadAddr  Read start address
+  * @param  Size      Size of data to read
+int32_t BSP_QSPI_Read(uint32_t Instance, uint8_t *pData, uint32_t ReadAddr, uint32_t Size)
+  else
+    if(QSPI_Ctx[Instance].TransferRate == BSP_QSPI_STR_TRANSFER)
+      if(MT25TL01G_ReadSTR(&hqspi, QSPI_Ctx[Instance].InterfaceMode, pData, ReadAddr, Size) != MT25TL01G_OK)
+    else
+      if(MT25TL01G_ReadDTR(&hqspi, QSPI_Ctx[Instance].InterfaceMode, pData, ReadAddr, Size) != MT25TL01G_OK)
+  return ret;
+  * @brief  Writes an amount of data to the QSPI memory.
+  * @param  pData      Pointer to data to be written
+  * @param  WriteAddr  Write start address
+  * @param  Size       Size of data to write
+int32_t BSP_QSPI_Write(uint32_t Instance, uint8_t *pData, uint32_t WriteAddr, uint32_t Size)
+  uint32_t end_addr, current_size, current_addr;
+  uint8_t *write_data;
+  else
+    /* Calculation of the size between the write address and the end of the page */
+    current_size = MT25TL01G_PAGE_SIZE - (WriteAddr % MT25TL01G_PAGE_SIZE);
+    /* Check if the size of the data is less than the remaining place in the page */
+    if (current_size > Size)
+      current_size = Size;
+    /* Initialize the address variables */
+    current_addr = WriteAddr;
+    end_addr = WriteAddr + Size;
+    write_data = pData;
+    /* Perform the write page by page */
+    do
+      /* Check if Flash busy ? */
+      if(MT25TL01G_AutoPollingMemReady(&hqspi, QSPI_Ctx[Instance].InterfaceMode) != MT25TL01G_OK)
+      }/* Enable write operations */
+      else if(MT25TL01G_WriteEnable(&hqspi, QSPI_Ctx[Instance].InterfaceMode) != MT25TL01G_OK)
+      }/* Issue page program command */
+      else if(MT25TL01G_PageProgram(&hqspi, QSPI_Ctx[Instance].InterfaceMode, write_data, current_addr, current_size) != MT25TL01G_OK)
+      }/* Configure automatic polling mode to wait for end of program */
+      else if (MT25TL01G_AutoPollingMemReady(&hqspi, QSPI_Ctx[Instance].InterfaceMode) != MT25TL01G_OK)
+      else
+        /* Update the address and size variables for next page programming */
+        current_addr += current_size;
+        write_data += current_size;
+        current_size = ((current_addr + MT25TL01G_PAGE_SIZE) > end_addr) ? (end_addr - current_addr) : MT25TL01G_PAGE_SIZE;
+    } while ((current_addr < end_addr) && (ret == BSP_ERROR_NONE));
+  return ret;
+  * @brief  Erases the specified block of the QSPI memory.
+  *         MT25TL01G support 4K, 32K, 64K size block erase commands for each Die.
+  *           i.e 8K, 64K, 128K at BSP level (see BSP_QSPI_Erase_t type definition)
+  * @param  BlockAddress Block address to erase
+  * @param  BlockSize    Erase Block size
+int32_t BSP_QSPI_EraseBlock(uint32_t Instance, uint32_t BlockAddress, BSP_QSPI_Erase_t BlockSize)
+  else
+    /* Check Flash busy ? */
+    else
+      /* Issue Block Erase command */
+      if(MT25TL01G_BlockErase(&hqspi, QSPI_Ctx[Instance].InterfaceMode, BlockAddress, (MT25TL01G_Erase_t)BlockSize) != MT25TL01G_OK)
+  return ret;
+  * @brief  Erases the entire QSPI memory.
+int32_t BSP_QSPI_EraseChip(uint32_t Instance)
+  else
+    else if (MT25TL01G_WriteEnable(&hqspi, QSPI_Ctx[Instance].InterfaceMode) != MT25TL01G_OK)
+    else
+      /* Issue Chip erase command */
+      if(MT25TL01G_ChipErase(&hqspi, QSPI_Ctx[Instance].InterfaceMode) != MT25TL01G_OK)
+  return ret;
+  * @brief  Reads current status of the QSPI memory.
+  *         If WIP != 0 then return busy.
+  * @retval QSPI memory status: whether busy or not
+int32_t BSP_QSPI_GetStatus(uint32_t Instance)
+  uint8_t reg;
+  else
+    if(MT25TL01G_ReadStatusRegister(&hqspi, QSPI_Ctx[Instance].InterfaceMode, &reg) != MT25TL01G_OK)
+    else
+      /* Check the value of the register */
+      if ((reg & MT25TL01G_SR_WIP) != 0U)
+        ret = BSP_ERROR_BUSY;
+  return ret;
+  * @brief  Return the configuration of the QSPI memory.
+  * @param  pInfo     pointer on the configuration structure
+int32_t BSP_QSPI_GetInfo(uint32_t Instance, BSP_QSPI_Info_t *pInfo)
+  else
+    (void)MT25TL01G_GetFlashInfo(pInfo);
+  return ret;
+  * @brief  Configure the QSPI in memory-mapped mode
+  *         Only 1 Instance can running MMP mode. And it will lock system at this mode.
+int32_t BSP_QSPI_EnableMemoryMappedMode(uint32_t Instance)
+  else
+      if(MT25TL01G_EnableMemoryMappedModeSTR(&hqspi, QSPI_Ctx[Instance].InterfaceMode) != MT25TL01G_OK)
+      else /* Update QSPI context if all operations are well done */
+        QSPI_Ctx[Instance].IsInitialized = QSPI_ACCESS_MMP;
+    else
+      if(MT25TL01G_EnableMemoryMappedModeDTR(&hqspi, QSPI_Ctx[Instance].InterfaceMode) != MT25TL01G_OK)
+  return ret;
+  * @brief  Exit form memory-mapped mode
+int32_t BSP_QSPI_DisableMemoryMappedMode(uint32_t Instance)
+  uint8_t Dummy;
+  else
+    if(QSPI_Ctx[Instance].IsInitialized != QSPI_ACCESS_MMP)
+      ret = BSP_ERROR_QSPI_MMP_UNLOCK_FAILURE;
+    }/* Abort MMP back to indirect mode */
+    else if(HAL_QSPI_Abort(&hqspi) != HAL_OK)
+    else
+      /* Force QSPI interface Sampling Shift to half cycle */
+      hqspi.Init.SampleShifting = QSPI_SAMPLE_SHIFTING_HALFCYCLE;
+      if(HAL_QSPI_Init(&hqspi)!= HAL_OK)
+      /* Dummy read for exit from Performance Enhance mode */
+      else if(MT25TL01G_ReadSTR(&hqspi, QSPI_Ctx[Instance].InterfaceMode, &Dummy, 0, 1) != MT25TL01G_OK)
+        QSPI_Ctx[Instance].IsInitialized = QSPI_ACCESS_INDIRECT;
+  return ret;
+  * @brief  Get flash ID, 3 Byte
+  *         Manufacturer ID, Memory type, Memory density
+  * @param  Id QSPI Identifier
+int32_t BSP_QSPI_ReadID(uint32_t Instance, uint8_t *Id)
+  else
+    if(MT25TL01G_ReadID(&hqspi, QSPI_Ctx[Instance].InterfaceMode, Id) != MT25TL01G_OK)
+  return ret;
+  * @brief  Set Flash to desired Interface mode. And this instance becomes current instance.
+  *         If current instance running at MMP mode then this function isn't work.
+  *         Indirect -> Indirect
+  * @param  Mode      QSPI mode
+  * @param  Rate      QSPI transfer rate
+int32_t BSP_QSPI_ConfigFlash(uint32_t Instance, BSP_QSPI_Interface_t Mode, BSP_QSPI_Transfer_t Rate)
+  else
+    /* Check if MMP mode locked ************************************************/
+      ret = BSP_ERROR_QSPI_MMP_LOCK_FAILURE;
+    else
+      /* Setup MCU transfer rate setting ***************************************************/
+      hqspi.Init.SampleShifting = (Rate == BSP_QSPI_STR_TRANSFER) ? QSPI_SAMPLE_SHIFTING_HALFCYCLE : QSPI_SAMPLE_SHIFTING_NONE;
+      else
+        /* Setup Flash interface ***************************************************/
+        switch(QSPI_Ctx[Instance].InterfaceMode)
+        case MT25TL01G_QPI_MODE :               /* 4-4-4 commands */
+          if(Mode != MT25TL01G_QPI_MODE)
+            if(MT25TL01G_ExitQPIMode(&hqspi) != MT25TL01G_OK)
+          break;
+        case BSP_QSPI_SPI_MODE :               /* 1-1-1 commands, Power on H/W default setting */
+        case BSP_QSPI_SPI_2IO_MODE :           /* 1-2-2 read commands */
+        case BSP_QSPI_SPI_4IO_MODE :           /* 1-4-4 read commands */
+        default :
+          if(Mode == MT25TL01G_QPI_MODE)
+            if(MT25TL01G_EnterQPIMode(&hqspi) != MT25TL01G_OK)
+          break;
+        /* Update QSPI context if all operations are well done */
+          /* Update current status parameter *****************************************/
+          QSPI_Ctx[Instance].InterfaceMode = Mode;
+          QSPI_Ctx[Instance].TransferRate  = Rate;
+  return ret;
+  * @brief QSPI MSP Initialization
+  * @param hQspi : QSPI handle
+  *        This function configures the hardware resources used in this example:
+  *           - Peripheral's clock enable
+  *           - Peripheral's GPIO Configuration
+  *           - NVIC configuration for QSPI interrupt
+  * @retval None
+  GPIO_InitTypeDef gpio_init_structure;
+  /* Prevent unused argument(s) compilation warning */
+  UNUSED(hQspi);
+  /*##-1- Enable peripherals and GPIO Clocks #################################*/
+  /* Enable the QuadSPI memory interface clock */
+  QSPI_CLK_ENABLE();
+  /* Reset the QuadSPI memory interface */
+  QSPI_FORCE_RESET();
+  QSPI_RELEASE_RESET();
+  /* Enable GPIO clocks */
+  QSPI_CLK_GPIO_CLK_ENABLE();
+  QSPI_BK1_CS_GPIO_CLK_ENABLE();
+  QSPI_BK1_D0_GPIO_CLK_ENABLE();
+  QSPI_BK1_D1_GPIO_CLK_ENABLE();
+  QSPI_BK1_D2_GPIO_CLK_ENABLE();
+  QSPI_BK1_D3_GPIO_CLK_ENABLE();
+  QSPI_BK2_CS_GPIO_CLK_ENABLE();
+  QSPI_BK2_D0_GPIO_CLK_ENABLE();
+  QSPI_BK2_D1_GPIO_CLK_ENABLE();
+  QSPI_BK2_D2_GPIO_CLK_ENABLE();
+  QSPI_BK2_D3_GPIO_CLK_ENABLE();
+  /*##-2- Configure peripheral GPIO ##########################################*/
+  /* QSPI CLK GPIO pin configuration  */
+  gpio_init_structure.Pin       = QSPI_CLK_PIN;
+  gpio_init_structure.Mode      = GPIO_MODE_AF_PP;
+  gpio_init_structure.Speed     = GPIO_SPEED_FREQ_VERY_HIGH;
+  gpio_init_structure.Pull      = GPIO_NOPULL;
+  gpio_init_structure.Alternate = GPIO_AF9_QUADSPI;
+  HAL_GPIO_Init(QSPI_CLK_GPIO_PORT, &gpio_init_structure);
+  /* QSPI CS GPIO pin configuration  */
+  gpio_init_structure.Pin       = QSPI_BK1_CS_PIN;
+  gpio_init_structure.Pull      = GPIO_PULLUP;
+  gpio_init_structure.Alternate = GPIO_AF10_QUADSPI;
+  HAL_GPIO_Init(QSPI_BK1_CS_GPIO_PORT, &gpio_init_structure);
+  gpio_init_structure.Pin       = QSPI_BK2_CS_PIN;
+  HAL_GPIO_Init(QSPI_BK2_CS_GPIO_PORT, &gpio_init_structure);
+  /* QSPI D0 GPIO pin configuration  */
+  gpio_init_structure.Pin       = QSPI_BK1_D0_PIN;
+  HAL_GPIO_Init(QSPI_BK1_D0_GPIO_PORT, &gpio_init_structure);
+  gpio_init_structure.Pin       = QSPI_BK2_D0_PIN;
+  HAL_GPIO_Init(QSPI_BK2_D0_GPIO_PORT, &gpio_init_structure);
+  /* QSPI D1 GPIO pin configuration  */
+  gpio_init_structure.Pin       = QSPI_BK1_D1_PIN;
+  HAL_GPIO_Init(QSPI_BK1_D1_GPIO_PORT, &gpio_init_structure);
+  gpio_init_structure.Pin       = QSPI_BK2_D1_PIN;
+  HAL_GPIO_Init(QSPI_BK2_D1_GPIO_PORT, &gpio_init_structure);
+  /* QSPI D2 GPIO pin configuration  */
+  gpio_init_structure.Pin       = QSPI_BK1_D2_PIN;
+  HAL_GPIO_Init(QSPI_BK1_D2_GPIO_PORT, &gpio_init_structure);
+  gpio_init_structure.Pin       = QSPI_BK2_D2_PIN;
+  HAL_GPIO_Init(QSPI_BK2_D2_GPIO_PORT, &gpio_init_structure);
+  /* QSPI D3 GPIO pin configuration  */
+  gpio_init_structure.Pin       = QSPI_BK1_D3_PIN;
+  HAL_GPIO_Init(QSPI_BK1_D3_GPIO_PORT, &gpio_init_structure);
+  gpio_init_structure.Pin       = QSPI_BK2_D3_PIN;
+  HAL_GPIO_Init(QSPI_BK2_D3_GPIO_PORT, &gpio_init_structure);
+  /*##-3- Configure the NVIC for QSPI #########################################*/
+  /* NVIC configuration for QSPI interrupt */
+  HAL_NVIC_SetPriority(QUADSPI_IRQn, 0x0F, 0);
+  HAL_NVIC_EnableIRQ(QUADSPI_IRQn);
+  * @brief QSPI MSP De-Initialization
+  *        This function frees the hardware resources used in this example:
+  *          - Disable the Peripheral's clock
+  *          - Revert GPIO and NVIC configuration to their default state
+  * @retval None
+static void QSPI_MspDeInit(QSPI_HandleTypeDef *hQspi)
+  UNUSED(hQspi);
+  /*##-2- Disable peripherals and GPIO Clocks ################################*/
+  /* De-Configure QSPI pins */
+  HAL_GPIO_DeInit(QSPI_CLK_GPIO_PORT, QSPI_CLK_PIN);
+  HAL_GPIO_DeInit(QSPI_BK1_CS_GPIO_PORT, QSPI_BK1_CS_PIN);
+  HAL_GPIO_DeInit(QSPI_BK1_D0_GPIO_PORT, QSPI_BK1_D0_PIN);
+  HAL_GPIO_DeInit(QSPI_BK1_D1_GPIO_PORT, QSPI_BK1_D1_PIN);
+  HAL_GPIO_DeInit(QSPI_BK1_D2_GPIO_PORT, QSPI_BK1_D2_PIN);
+  HAL_GPIO_DeInit(QSPI_BK1_D3_GPIO_PORT, QSPI_BK1_D3_PIN);
+  HAL_GPIO_DeInit(QSPI_BK2_CS_GPIO_PORT, QSPI_BK2_CS_PIN);
+  HAL_GPIO_DeInit(QSPI_BK2_D0_GPIO_PORT, QSPI_BK2_D0_PIN);
+  HAL_GPIO_DeInit(QSPI_BK2_D1_GPIO_PORT, QSPI_BK2_D1_PIN);
+  HAL_GPIO_DeInit(QSPI_BK2_D2_GPIO_PORT, QSPI_BK2_D2_PIN);
+  HAL_GPIO_DeInit(QSPI_BK2_D3_GPIO_PORT, QSPI_BK2_D3_PIN);
+  /*##-3- Reset peripherals ##################################################*/
+  /* Disable the QuadSPI memory interface clock */
+  QSPI_CLK_DISABLE();
+  * @brief  This function reset the QSPI Flash memory.
+  *         Fore QPI+SPI reset to avoid system come from unknown status.
+  *         Flash accept 1-1-1, 1-1-2, 1-2-2 commands after reset.
+  /* Send RESET ENABLE command in QPI mode (QUAD I/Os, 4-4-4) */
+  if(MT25TL01G_ResetEnable(&hqspi, MT25TL01G_QPI_MODE) != MT25TL01G_OK)
+    ret =BSP_ERROR_COMPONENT_FAILURE;
+  }/* Send RESET memory command in QPI mode (QUAD I/Os, 4-4-4) */
+  else if(MT25TL01G_ResetMemory(&hqspi, MT25TL01G_QPI_MODE) != MT25TL01G_OK)
+  }/* Wait Flash ready */
+  }/* Send RESET ENABLE command in SPI mode (1-1-1) */
+  else if(MT25TL01G_ResetEnable(&hqspi, BSP_QSPI_SPI_MODE) != MT25TL01G_OK)
+  }/* Send RESET memory command in SPI mode (1-1-1) */
+  else if(MT25TL01G_ResetMemory(&hqspi, BSP_QSPI_SPI_MODE) != MT25TL01G_OK)
+  else
+    QSPI_Ctx[Instance].IsInitialized = QSPI_ACCESS_INDIRECT;  /* After reset S/W setting to indirect access   */
+    QSPI_Ctx[Instance].InterfaceMode = BSP_QSPI_SPI_MODE;     /* After reset H/W back to SPI mode by default  */
+    QSPI_Ctx[Instance].TransferRate  = BSP_QSPI_STR_TRANSFER; /* After reset S/W setting to STR mode          */
+  return ret;
+  * @brief  This function configure the dummy cycles on memory side.
+  *         Dummy cycle bit locate in Configuration Register[7:6]
+    int32_t ret= BSP_ERROR_NONE;
+    QSPI_CommandTypeDef s_command;
+  uint16_t reg=0;
+  /* Initialize the read volatile configuration register command */
+  s_command.InstructionMode   = QSPI_INSTRUCTION_4_LINES;
+  s_command.Instruction       = MT25TL01G_READ_VOL_CFG_REG_CMD;
+  s_command.AddressMode       = QSPI_ADDRESS_NONE;
+  s_command.AlternateByteMode = QSPI_ALTERNATE_BYTES_NONE;
+  s_command.DataMode          = QSPI_DATA_4_LINES;
+  s_command.DummyCycles       = 0;
+  s_command.NbData            = 2;
+  s_command.DdrMode           = QSPI_DDR_MODE_DISABLE;
+  s_command.DdrHoldHalfCycle  = QSPI_DDR_HHC_ANALOG_DELAY;
+  s_command.SIOOMode          = QSPI_SIOO_INST_EVERY_CMD;
+  /* Configure the command */
+  if (HAL_QSPI_Command(&hqspi, &s_command, HAL_QPSI_TIMEOUT_DEFAULT_VALUE) != HAL_OK)
+    return BSP_ERROR_COMPONENT_FAILURE;
+  /* Reception of the data */
+  if (HAL_QSPI_Receive(&hqspi, (uint8_t *)(&reg), HAL_QPSI_TIMEOUT_DEFAULT_VALUE) != HAL_OK)
+  /* Enable write operations */
+  if (MT25TL01G_WriteEnable(&hqspi, QSPI_Ctx[Instance].InterfaceMode) != MT25TL01G_OK)
+  /* Update volatile configuration register (with new dummy cycles) */
+  s_command.Instruction = MT25TL01G_WRITE_VOL_CFG_REG_CMD;
+  MODIFY_REG(reg, 0xF0F0, ((MT25TL01G_DUMMY_CYCLES_READ_QUAD << 4) |
+                               (MT25TL01G_DUMMY_CYCLES_READ_QUAD << 12)));
+  /* Configure the write volatile configuration register command */
+  /* Transmission of the data */
+  if (HAL_QSPI_Transmit(&hqspi, (uint8_t *)(&reg), HAL_QPSI_TIMEOUT_DEFAULT_VALUE) != HAL_OK)
+  return ret;
diff --git a/bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h747i_eval_qspi.h b/bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h747i_eval_qspi.h
index 0000000000..52293dba89
--- /dev/null
+++ b/bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h747i_eval_qspi.h
@@ -0,0 +1,284 @@
+  * @file    stm32h747i_eval_qspi.h
+  * @brief   This file contains the common defines and functions prototypes for
+  *          the stm32h747i_eval_qspi.c driver.
+  * @attention
+ * https://github.com/STMicroelectronics/STM32CubeH7/blob/master/Drivers/BSP/STM32H747I-EVAL/stm32h747i_eval_qspi.h
+#ifndef STM32H747I_EVAL_QSPI_H
+#define STM32H747I_EVAL_QSPI_H
+#ifdef __cplusplus
+ extern "C" {
+#endif
+#include "stm32h747i_eval_conf.h"
+#include "stm32h747i_eval_errno.h"
+#include "../Components/mt25tl01g/mt25tl01g.h"
+/** @addtogroup STM32H747I_EVAL_QSPI
+/* Exported types ------------------------------------------------------------*/
+/** @defgroup STM32H747I_EVAL_QSPI_Exported_Types QSPI Exported Types
+#define BSP_QSPI_Info_t                 MT25TL01G_Info_t
+#define BSP_QSPI_Interface_t            MT25TL01G_Interface_t
+#define BSP_QSPI_Transfer_t             MT25TL01G_Transfer_t
+#define BSP_QSPI_DualFlash_t            MT25TL01G_DualFlash_t
+#define BSP_QSPI_ODS_t                  MT25TL01G_ODS_t
+typedef enum
+  BSP_QSPI_ERASE_8K   =  MT25TL01G_ERASE_4K ,       /*!< 8K size Sector erase = 2 x 4K as Dual flash mode is used for this board   */
+  BSP_QSPI_ERASE_64K  =  MT25TL01G_ERASE_32K ,      /*!< 64K size Sector erase = 2 x 32K as Dual flash mode is used for this board */
+  BSP_QSPI_ERASE_128K =  MT25TL01G_ERASE_64K ,      /*!< 128K size Sector erase = 2 x 64K as Dual mode is used for this board      */
+  BSP_QSPI_ERASE_CHIP =  MT25TL01G_ERASE_CHIP       /*!< Whole chip erase */
+} BSP_QSPI_Erase_t;
+typedef enum
+  QSPI_ACCESS_NONE = 0,          /*!<  Instance not initialized,             */
+  QSPI_ACCESS_INDIRECT,          /*!<  Instance use indirect mode access     */
+  QSPI_ACCESS_MMP                /*!<  Instance use Memory Mapped Mode read  */
+} BSP_QSPI_Access_t;
+typedef struct
+  BSP_QSPI_Access_t    IsInitialized;   /*!<  Instance access Flash method     */
+  BSP_QSPI_Interface_t InterfaceMode;   /*!<  Flash Interface mode of Instance */
+  BSP_QSPI_Transfer_t  TransferRate;    /*!<  Flash Transfer mode of Instance  */
+  uint32_t             DualFlashMode;   /*!<  Flash dual mode                  */
+  uint32_t             IsMspCallbacksValid;
+} BSP_QSPI_Ctx_t;
+typedef struct
+  BSP_QSPI_Interface_t        InterfaceMode;   /*!<  Current Flash Interface mode */
+  BSP_QSPI_Transfer_t         TransferRate;    /*!<  Current Flash Transfer mode  */
+  BSP_QSPI_DualFlash_t        DualFlashMode;   /*!<  Dual Flash mode              */
+} BSP_QSPI_Init_t;
+typedef struct
+  uint32_t FlashSize;
+  uint32_t ClockPrescaler;
+  uint32_t SampleShifting;
+}MX_QSPI_Init_t;
+typedef struct
+ void(*pMspInitCb)(pQSPI_CallbackTypeDef);
+ void(*pMspDeInitCb)(pQSPI_CallbackTypeDef);
+}BSP_QSPI_Cb_t;
+/* Exported constants --------------------------------------------------------*/
+/** @defgroup STM32H747I_EVAL_QSPI_Exported_Constants QSPI Exported Constants
+/* QSPI instances number */
+#define QSPI_INSTANCES_NUMBER         1U
+/* Definition for QSPI modes */
+#define BSP_QSPI_SPI_MODE            (BSP_QSPI_Interface_t)MT25TL01G_SPI_MODE      /* 1 Cmd Line, 1 Address Line and 1 Data Line    */
+#define BSP_QSPI_SPI_1I2O_MODE       (BSP_QSPI_Interface_t)MT25TL01G_SPI_1I2O_MODE /* 1 Cmd Line, 1 Address Line and 2 Data Lines   */
+#define BSP_QSPI_SPI_2IO_MODE        (BSP_QSPI_Interface_t)MT25TL01G_SPI_2IO_MODE  /* 1 Cmd Line, 2 Address Lines and 2 Data Lines  */
+#define BSP_QSPI_SPI_1I4O_MODE       (BSP_QSPI_Interface_t)MT25TL01G_SPI_1I4O_MODE /* 1 Cmd Line, 1 Address Line and 4 Data Lines   */
+#define BSP_QSPI_SPI_4IO_MODE        (BSP_QSPI_Interface_t)MT25TL01G_SPI_4IO_MODE  /* 1 Cmd Line, 4 Address Lines and 4 Data Lines  */
+#define BSP_QSPI_DPI_MODE            (BSP_QSPI_Interface_t)MT25TL01G_DPI_MODE      /* 2 Cmd Lines, 2 Address Lines and 2 Data Lines */
+#define BSP_QSPI_QPI_MODE            (BSP_QSPI_Interface_t)MT25TL01G_QPI_MODE      /* 4 Cmd Lines, 4 Address Lines and 4 Data Lines */
+/* Definition for QSPI transfer rates */
+#define BSP_QSPI_STR_TRANSFER        (BSP_QSPI_Transfer_t)MT25TL01G_STR_TRANSFER /* Single Transfer Rate */
+#define BSP_QSPI_DTR_TRANSFER        (BSP_QSPI_Transfer_t)MT25TL01G_DTR_TRANSFER /* Double Transfer Rate */
+/* Definition for QSPI dual flash mode */
+#define BSP_QSPI_DUALFLASH_DISABLE   (BSP_QSPI_DualFlash_t)MT25TL01G_DUALFLASH_DISABLE   /* Dual flash mode enabled  */
+/* Definition for QSPI Flash ID */
+#define BSP_QSPI_FLASH_ID            QSPI_FLASH_ID_1
+/* QSPI block sizes for dual flash */
+#define BSP_QSPI_BLOCK_8K            MT25TL01G_SECTOR_4K
+#define BSP_QSPI_BLOCK_64K           MT25TL01G_BLOCK_32K
+#define BSP_QSPI_BLOCK_128K          MT25TL01G_BLOCK_64K
+/* Definition for QSPI clock resources */
+#define QSPI_CLK_ENABLE()              __HAL_RCC_QSPI_CLK_ENABLE()
+#define QSPI_CLK_DISABLE()             __HAL_RCC_QSPI_CLK_DISABLE()
+#define QSPI_CLK_GPIO_CLK_ENABLE()     __HAL_RCC_GPIOB_CLK_ENABLE()
+#define QSPI_BK1_CS_GPIO_CLK_ENABLE()  __HAL_RCC_GPIOG_CLK_ENABLE()
+#define QSPI_BK1_D0_GPIO_CLK_ENABLE()  __HAL_RCC_GPIOF_CLK_ENABLE()
+#define QSPI_BK1_D1_GPIO_CLK_ENABLE()  __HAL_RCC_GPIOF_CLK_ENABLE()
+#define QSPI_BK1_D2_GPIO_CLK_ENABLE()  __HAL_RCC_GPIOF_CLK_ENABLE()
+#define QSPI_BK1_D3_GPIO_CLK_ENABLE()  __HAL_RCC_GPIOF_CLK_ENABLE()
+#define QSPI_BK2_CS_GPIO_CLK_ENABLE()  __HAL_RCC_GPIOC_CLK_ENABLE()
+#define QSPI_BK2_D0_GPIO_CLK_ENABLE()  __HAL_RCC_GPIOH_CLK_ENABLE()
+#define QSPI_BK2_D1_GPIO_CLK_ENABLE()  __HAL_RCC_GPIOH_CLK_ENABLE()
+#define QSPI_BK2_D2_GPIO_CLK_ENABLE()  __HAL_RCC_GPIOG_CLK_ENABLE()
+#define QSPI_BK2_D3_GPIO_CLK_ENABLE()  __HAL_RCC_GPIOG_CLK_ENABLE()
+#define QSPI_FORCE_RESET()         __HAL_RCC_QSPI_FORCE_RESET()
+#define QSPI_RELEASE_RESET()       __HAL_RCC_QSPI_RELEASE_RESET()
+/* Definition for QSPI Pins */
+#define QSPI_CLK_PIN               GPIO_PIN_2
+#define QSPI_CLK_GPIO_PORT         GPIOB
+/* Bank 1 */
+#define QSPI_BK1_CS_PIN            GPIO_PIN_6
+#define QSPI_BK1_CS_GPIO_PORT      GPIOG
+#define QSPI_BK1_D0_PIN            GPIO_PIN_8
+#define QSPI_BK1_D0_GPIO_PORT      GPIOF
+#define QSPI_BK1_D1_PIN            GPIO_PIN_9
+#define QSPI_BK1_D1_GPIO_PORT      GPIOF
+#define QSPI_BK1_D2_PIN            GPIO_PIN_7
+#define QSPI_BK1_D2_GPIO_PORT      GPIOF
+#define QSPI_BK1_D3_PIN            GPIO_PIN_6
+#define QSPI_BK1_D3_GPIO_PORT      GPIOF
+/* Bank 2 */
+#define QSPI_BK2_CS_PIN            GPIO_PIN_11
+#define QSPI_BK2_CS_GPIO_PORT      GPIOC
+#define QSPI_BK2_D0_PIN            GPIO_PIN_2
+#define QSPI_BK2_D0_GPIO_PORT      GPIOH
+#define QSPI_BK2_D1_PIN            GPIO_PIN_3
+#define QSPI_BK2_D1_GPIO_PORT      GPIOH
+#define QSPI_BK2_D2_PIN            GPIO_PIN_9
+#define QSPI_BK2_D2_GPIO_PORT      GPIOG
+#define QSPI_BK2_D3_PIN            GPIO_PIN_14
+#define QSPI_BK2_D3_GPIO_PORT      GPIOG
+/* MT25TL01G Micron memory */
+/* Size of the flash */
+#define QSPI_FLASH_SIZE            26     /* Address bus width to access whole memory space */
+#define QSPI_PAGE_SIZE             256
+/* QSPI Base Address */
+#define QSPI_BASE_ADDRESS          0x90000000
+/** @addtogroup STM32H747I_EVAL_QSPI_Exported_Variables
+extern QSPI_HandleTypeDef hqspi;
+extern BSP_QSPI_Ctx_t     QSPI_Ctx[];
+/* Exported functions --------------------------------------------------------*/
+/** @addtogroup STM32H747I_EVAL_QSPI_Exported_Functions
+int32_t BSP_QSPI_Init(uint32_t Instance, BSP_QSPI_Init_t *Init);
+int32_t BSP_QSPI_DeInit(uint32_t Instance);
+int32_t BSP_QSPI_RegisterMspCallbacks (uint32_t Instance, BSP_QSPI_Cb_t *CallBacks);
+int32_t BSP_QSPI_RegisterDefaultMspCallbacks (uint32_t Instance);
+int32_t BSP_QSPI_Read(uint32_t Instance, uint8_t *pData, uint32_t ReadAddr, uint32_t Size);
+int32_t BSP_QSPI_Write(uint32_t Instance, uint8_t *pData, uint32_t WriteAddr, uint32_t Size);
+int32_t BSP_QSPI_EraseBlock(uint32_t Instance, uint32_t BlockAddress, BSP_QSPI_Erase_t BlockSize);
+int32_t BSP_QSPI_EraseChip(uint32_t Instance);
+int32_t BSP_QSPI_GetStatus(uint32_t Instance);
+int32_t BSP_QSPI_GetInfo(uint32_t Instance, BSP_QSPI_Info_t *pInfo);
+int32_t BSP_QSPI_EnableMemoryMappedMode(uint32_t Instance);
+int32_t BSP_QSPI_DisableMemoryMappedMode(uint32_t Instance);
+int32_t BSP_QSPI_ReadID(uint32_t Instance, uint8_t *Id);
+int32_t BSP_QSPI_ConfigFlash(uint32_t Instance, BSP_QSPI_Interface_t Mode, BSP_QSPI_Transfer_t Rate);
+/* These functions can be modified in case the current settings
+   need to be changed for specific application needs */
+HAL_StatusTypeDef MX_QSPI_Init(QSPI_HandleTypeDef *hQspi, MX_QSPI_Init_t *Config);
+#ifdef __cplusplus
+#endif
+#endif /* __STM32H747I_EVAL_QSPI_H */
2.25.1
